[x] Add video stream info to output file
Happy New Year everyone !
https://bugs.vso-software.fr/view.php?id=14462
I have officially made a feature request to VSO: 0014462: [x] Add video stream info to output file
Anyone else would be using this if it was implemented ?
Since I cannot yet find a software ghat does this, i would like a new feature directly in VSO Downloader.
Add a new selector on the main screen or a new setting options which you could select:
1- Download a video in Downloader
2- if a conversion option is selected: Ratio / Video / Audio / fps may change so add the new stream info in the file once the file is 100% downloaded and saved…
Danse Music Video.mkv
Could be renamed at the end as: Danse Music Video [3840x2160 - H265 - Opus - 29.97fps].mkv
*If* this is ever implemented, I would like to see it in all VSO software’s specially in VSO UHD Converter as most steams change …
Original: Danse Music Video [3840x2160 - H265 - Opus - 29.97fps].mkv
Converted in UHD using Compatible profile would have an output of
Danse Music Video [1920x1080 - H264 - AC3 - 29.97fps].mkv
Re: [x] Add video stream info to output file
Feature #2
If this WAS implemented,I would ask to add a renamer inside the softwares…
File explorer, select video file, rename to Original_Name [new video stream info].mp4 for example :)
Well well seems I had already requested this in 2021 :D
https://bugs.vso-software.fr/view.php?id=14025
