Vimeo Download Issues with 6.1.0.134
achugh
Post by achugh »
Dear Support,
It seems Vimeo has recently updated their playlist.json file where the URLs now have pathsig as a querystring parameter. I believe this is breaking the download of Viemo videos.
The videos I am trying to download are from a private embedded page. VSO detects them in the radar mode but it is not able to download them.
Is the team aware about this change breaking things and is someone going to work on fixing this issue?
Best Regards,
achugh
Re: Vimeo Download Issues with 6.1.0.134
Thank you for the info.
I have opened an official bug report with VSO:
https://bugs.vso-software.fr/view.php?id=14452
Let’s see what they say !
Version 135 fixed some Facebook issues for me, I also use Firefox...
There was also an Engine Update, wonder if those 2 updates would also fix your Vimeo issues...
https://www.vso-software.fr/products/do ... istory.php
Downloader 6.1.0.135 - released Wed December 4, 2024
0014432 [Bug] Getting an error trying to download playlist
0014439 [Bug] Generic error on youtube
0014448 [Bug] Downloading from facebook doesn't work
0014449 [Bug] Firefox browser not detected
0014450 [Feature Request] automatic rename playlist item in case of duplicates
0014451 [Suggestion] change visibility level of option "cookie from browser"
achugh
Post by achugh »
Hi Cougar_II
Thank you for helping with creation of the ticket. I responded to the ticket that got opened using the Bug Reporting via the app.
When I opened the app just now, it downloaded some update. This is what's shown after the update.
Program version: 6.1.0.134
Engine Version: 2024.12.06
I believe 135 version is a beta version hence it did not get downloaded. These Vimeo videos are private and embedded. I can login to see and view them. Because they are private VSO is not able to download them. This is a defect in VSO because Vimeo is looking for some specific Origin and Referrer HTTP headers that VSO should be able to capture using its built-in proxy and use them but it does not and hence gets into an error. I do not believe 135 fixes this issue.
I was not using Firefox because RADAR was detecting the media so I don't believe this 135 update fixes anything for me yet.
-achugh
Hello, added your comments to the bug report. Let’s see what Jacques says, and/or when the bug will get resolved :D
achugh
Post by achugh »
Thank you for updating the Bug report.
There was a time in VSO v5.x where one could manually specify the HTTP headers via the INFO window that opens. It will be great if this ability is added again so that I could send the headers I know will work when VSO is not able to figure them out on its own like what is happening right now.
Good news, comment from Wesson on the bug site …
Adding specific headers to request will be available soon.
achugh
Post by achugh »
Thank you for this update.
Today my version was updated to 6.1.0.135 with engine version of 2024.12.06. Is the custom header in this version? If yes, how to set them up?
I tried to download the video from this temporary public page at https://f64elite.com/public-live/ and all I got was bunch of errors. The media is detected but the yt downloader is not able to download this media. This temporary public page will disappear after 26-Dec-2024 so please take a look at it before it disappears to understand this defect.
When I turn on RADAR mode, the media is detected and VSO makes some assumption to download the file and fails. I have not started playing this media so the headers VSO is assuming are not correct.
Next I start playing this media and I was hoping VSO will now see correct headers via its proxy but it still does not understand and sends the wrong headers and fails to download.
Can you some at least investigate this issue before this page is locked even if the fix comes later? Thank you.
V6.1.0.136 with an engine update was released but the Vimeo bug is still assigned, to be added soon it says. I can advise when the heathers are added and I assume .137 or .138 will be released…
Check the version that
Bug #14452
will be fixed in ;)
