DVD Converter change video size from 720x480 to 1920x1080
SailorGuy
Post by SailorGuy »
I have DVD Converter Ultimate 4.0.0.102
I am converting my "Jaws" DVD as MP4 (Mpeg4+AAC) and the image size defaults to 720x480. I want to change it 1920x1080 but I can't seem to find the spot to make the adjustment. I expected the "Video settings" screen to provide a simple way to make the change but no luck.
Where can I change the default video image size?
In a previous post, someone said to create a custom profile. However, I don't find any options for profiles.
Thank you!
Sailor Guy
Re: DVD Converter change video size from 720x480 to 1920x1080
That is simply because DVD does not support FullHD.
DVD Video resolution (maximum) 720×480 (NTSC) 720×576 (PAL)
SailorGuy
Post by SailorGuy »
Thank you for your response.
So there is no way to force an upscale on the MP4 video resolution so the resulting video is larger on my screens (iPad, Apple TV)?
SailorGuy
Sure there is, but not with ConvertXtoDVD.
VSO has other products for that.
SailorGuy
Post by SailorGuy »
What other VSO product will let me do the upscaling?
For example ConvertXtoHD, ConvertXtoVideo Ultimate.
Mostly depends on your sources, but those can do it.
