Skipped due to settings (BUG or not ? )
Hello Katia,
Before I open a bug report, can you ask Dictator if this is a bug or not please ?
I am trying to make a Print Screen but it's not working :(
I have my settings set to 'Automatic' so it should check for updates on EVERY START of the application....
I see a message that gets displayed 'skipped due to settings'
#1 I should NOT see this message
#2 if it actually skips, I still get the software & engine updates
I changed it to check ONCE A DAY and still saw the message...
Please open a bug report if Dictator says it needs to be looked into :)
v6.0.0.100 Contacting Upgrade Server - Skipped due to settings (Set to Automatic).jpg
Katia
Re: Skipped due to settings (BUG or not ? )
Post by Katia »
Hello!
Jacques has just looked at the code, there is actually a bug in Downloader with updates and settings.
I had an other user with the same message today, but in his case the program really doesn't get updates :x
We will fix it quickly. Thank you for your message!
VSO Support Team
