Root Menu
Porsmitj2
Root Menu
Post by Porsmitj2 »
I have created a project which has a single video with multiple chapters.
As there is only one video I have chosen not to have a title menu page.
There is a root Menu page with an image background and play and chapter buttons.
There are 2 chapter menu pages.
I would like the DVD to load showing the root Menu but can't work out which menu options I need to set to achieve this.
Can anyone help?
Thank you
Re: Root Menu
Under Menu Options, does checking Don't create title menu for single file do what you want to accomplish? Try enabling that setting if it isn't, recreate the project, and see if that gets what you want.
