Bought new Blu-Ray Writer to solve an issue AND it got worse
ink
Post by ink »
You guys have been so helpful - on my other thread... I decided to give up on the other blu-ray - as LG seemed to suggest it was not compatible with Windows 10.
I couldn't afford a new one so I actually bought a second hand Blu-Ray (new to me) and an upgrade
LG wh14ns40
It was sold as reconditioned.
If it is faulty - it would be good to know for sure so I can contact the seller
I have tried multiple times with XtoHD3
I have also tried with XtoVideo Ultimate 2, and ImgBurn
I think the issue might be that the laser is dirty [?] maybe [?]
I will post a full log but....
Some of the errors [on different attempts] I got were:
ONE of the burns:
Sense at LBA 32 (32) - 05 21 02 [ILLEGAL REQUEST, invalid address for Write]
00:36:21.361 Warning Defered Write error
00:36:21.355 Info Sense at LBA 0 (32) - 03 0C 00 [MEDIUM ERROR, write error]
Another:
power Calibration Area Error - Medium Error" [03/73/03]
Error Code 22
MEDIUM ERROR, power calibration fail "CD-burner is dirty"
And the error on my ImgBurn attempt:
W 02:51:30 Optimum Power Calibration Failed! - Reason: Power Calibration Area Error
W 02:58:56 Retrying (20 of 20)...
W 02:59:18 Retry Failed - Reason: Power Calibration Area Error
E 02:59:36 Failed to Write Sectors 0 - 31 - Reason: Power Calibration Area Error
I 02:59:36 Synchronising Cache...
E 02:59:47 Failed to Write Image!
ink
Re: Bought new Blu-Ray Writer to solve an issue AND it got worse
Post by ink »
A full log:
:crash_log='C:\Users\inkey\AppData\Roaming\VSO\ConvertXtoHD\3\Log\ConvertXtoHD 3_crashlog.20201029.213614.478.log'
:library=false
:app_name=ConvertXToHD.exe
:app_version=3.0.0.73
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
02:09:20.184 Info Disc name: "Enola Holmes"
00:35:49.343 Info Burned folder: "C:\Users\inkey\Documents\ConvertXtoHD\Enola Holmes", Min. media size 43.4 GB.
00:35:49.109 Info Conversion completed in 02:34:20
00:35:43.423 Info "TITLE 2/2 (Global 2/2)" menu built successfully
00:35:15.339 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:35:14.819 Info "TITLE 1/2 (Global 1/2)" menu built successfully
00:34:42.932 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:34:42.452 Important Starting BD title menus encoding: [Memory load 19%] [Available virtual memory 2770 Mb.]
00:34:42.449 Info Building TITLE menu
22:01:28.711 Info [ ] Loop playback
22:01:28.709 Info [ ] Play titles one after the other
22:01:28.708 Info [ ] Don't create title menu for single video
22:01:28.707 Info [x] Return to title menu after titleset playback
22:01:28.706 Info [x] Skip root menu initially
22:01:28.705 Info [ ] Auto-start playback
22:01:28.704 Info Template: Metallic (open style), contains 4 page(s)
22:01:28.704 Group Blu-ray/AVCHD menu options
22:01:28.702 Info Output target size : BD-50 (46000 MB)
22:01:28.701 Info Number of core(s) used for encoding : 16
22:01:28.700 Info Number of core(s) used for decoding : 16
22:01:28.699 Info [ ] Use 2 pass encoding
22:01:28.698 Info [ ] Use best video quality settings
22:01:28.697 Info [ ] Use hardware encoding (if possible)
22:01:28.695 Info [ ] Use hardware decoding (if possible)
22:01:28.694 Info Max simultaneous conversions: 4
22:01:28.694 Group Advanced encoding options
00:34:36.791 ------------ *****************************************File encoded successfully: 00011.m2ts******************************************
00:34:36.785 Info "SETTINGS 1/1 (Global 5/5)" menu built successfully
00:34:19.745 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:34:19.657 Info "CHAPTERS 3/3 (Global 4/5)" menu built successfully
00:33:51.972 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:33:50.679 Info "CHAPTERS 2/3 (Global 3/5)" menu built successfully
00:33:06.226 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:33:05.240 Info "CHAPTERS 1/3 (Global 2/5)" menu built successfully
00:32:21.858 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:32:20.912 Info "ROOT 1/1 (Global 1/5)" menu built successfully
00:31:58.795 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:31:56.712 Important Starting BD root menu encoding: [Memory load 19%] [Available virtual memory 2769 Mb.]
00:31:56.710 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Metallic (open style)
00:31:56.645 Info subtitle #3 - Encoded subtitles frames: 4645
00:31:56.642 Info video #1 - Processed video frames: 188353 (188352 frames encoded, 0 frames dropped, 0 frames duplicated)
00:01:03.149 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3700000,bt=50M,maxrate=40000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=30000000,rc_init_occupancy=20000000,slices=4,language=en,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
00:01:03.143 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
+-[subtitle #2 - hdmv_pgs_subtitle subtitle]
+--> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch., 640000 bps [English]]
+-[audio [eng] DTS HD-Master main audio 6 Ch. 48000Hz ]
+--> [video #1 - h264 video, 1920x1080, yuv420p, 16x9, 23.98Fps, 3700Kbps]
+-[video [eng] h264 1920x1080 16:9 yuv420p, 23.98Fps, 0Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Enola Holmes\BDMV\STREAM\00011.m2ts (Blu-ray)
Input file: D:\VUZE downloads\Richard.Jewell.2019.Bluray.1080p.DTS-HD.x264-GrymLegacy\Richard.Jewell.2019.Bluray.1080p.DTS-HD.x264-GrymLegacy.mkv
Video filters used:
- DeInterlace filter: VSO
00:01:03.133 Info Chapters to generate: 15 (0h00m00s, 0h09m51s, 0h20m03s, 0h29m55s, 0h40m03s, 0h48m21s, 0h57m52s, 1h06m35s, 1h14m34s, 1h24m33s, 1h34m04s, 1h44m01s, 1h52m20s, 2h02m28s, 2h04m53s, )
00:01:03.128 Important Starting video encoding: [Memory load 21%] [Available virtual memory 1719 Mb.]
00:01:02.703 Verbose FFmpeg Opening file D:\VUZE downloads\Richard.Jewell.2019.Bluray.1080p.DTS-HD.x264-GrymLegacy\Richard.Jewell.2019.Bluray.1080p.DTS-HD.x264-GrymLegacy.mkv
22:01:28.688 Info Menu fit: Text size reduced from 13.00 to 13.00 in style "Captions in title menu pages"
22:01:28.681 Info Menu fit: Text size reduced from 18.00 to 13.00 in style "Captions in title menu pages"
22:01:28.641 Info Menu fit: Text size reduced from 18.00 to 18.00 in style "Captions in title menu pages"
^^^Repeated 2 Times in 6 millisecond(s)^^^
22:01:28.634 Info Menu fit: Text size reduced from 23.00 to 18.00 in style "Captions in title menu pages"
22:01:28.598 Info Menu fit: Text size reduced from 27.00 to 23.00 in style "Captions in title menu pages"
22:01:26.790 Verbose FFmpeg Opening file D:\VUZE downloads\Richard.Jewell.2019.Bluray.1080p.DTS-HD.x264-GrymLegacy\Richard.Jewell.2019.Bluray.1080p.DTS-HD.x264-GrymLegacy.mkv
22:01:26.789 Group ******************** Titleset #12 - ~130 min. File: "Richard.Jewell.2019.Bluray.1080p.DTS-HD.x264-GrymLegacy" -> 00011.m2ts - Blu-ray ********************|GK_TITLESET|
00:12:21.419 ------------ *****************************************File encoded successfully: 00010.m2ts******************************************
00:12:21.411 Info "SETTINGS 1/1 (Global 4/4)" menu built successfully
00:12:01.564 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:12:01.415 Info "CHAPTERS 2/2 (Global 3/4)" menu built successfully
00:11:14.730 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:11:10.571 Info "CHAPTERS 1/2 (Global 2/4)" menu built successfully
00:10:17.840 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:10:09.277 Info "ROOT 1/1 (Global 1/4)" menu built successfully
00:09:36.496 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:09:32.184 Important Starting BD root menu encoding: [Memory load 21%] [Available virtual memory 1834 Mb.]
00:09:32.180 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Metallic (open style)
00:09:32.084 Info subtitle #3 - Encoded subtitles frames: 1839
00:09:32.078 Info video #1 - Processed video frames: 174555 (174554 frames encoded, 0 frames dropped, 0 frames duplicated)
23:28:10.334 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3700000,bt=50M,maxrate=20000000,minrate=0,me_method=epzs,codec=h264,width=1280,height=720,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=15000000,rc_init_occupancy=15000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
23:28:10.327 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
+--> [video #1 - h264 video, 1280x720, yuv420p, 16x9, 23.98Fps, 3700Kbps]
+-[video h264 1920x802 79:33 yuv420p, 23.98Fps, 0Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Enola Holmes\BDMV\STREAM\00010.m2ts (Blu-ray)
Input file: D:\VUZE downloads\Resistance.2020.1080p.BluRay.x264-GECKOS[TGx]\resistance.2020.1080p.bluray.x264-geckos.mkv
Video filters used:
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 92, bottom: 92, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
23:28:10.321 Info Chapters to generate: 12 (0h00m00s, 0h10m10s, 0h22m19s, 0h32m50s, 0h40m27s, 0h51m29s, 1h00m17s, 1h12m19s, 1h21m58s, 1h33m52s, 1h46m57s, 1h55m20s, )
23:28:10.306 Important Starting video encoding: [Memory load 20%] [Available virtual memory 1826 Mb.]
23:28:10.216 Verbose FFmpeg Opening file D:\VUZE downloads\Resistance.2020.1080p.BluRay.x264-GECKOS[TGx]\resistance.2020.1080p.bluray.x264-geckos.mkv
22:01:26.668 Verbose FFmpeg Opening file D:\VUZE downloads\Resistance.2020.1080p.BluRay.x264-GECKOS[TGx]\resistance.2020.1080p.bluray.x264-geckos.mkv
22:01:26.668 Group ******************** Titleset #11 - ~121 min. File: "resistance.2020.1080p.bluray.x264-geckos" -> 00010.m2ts - Blu-ray ********************|GK_TITLESET|
00:07:01.985 ------------ *****************************************File encoded successfully: 00009.m2ts******************************************
00:07:01.944 Info "SETTINGS 1/1 (Global 5/5)" menu built successfully
00:06:31.115 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:06:30.806 Info "CHAPTERS 3/3 (Global 4/5)" menu built successfully
00:05:40.109 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:05:37.999 Info "CHAPTERS 2/3 (Global 3/5)" menu built successfully
00:04:30.215 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:04:26.655 Info "CHAPTERS 1/3 (Global 2/5)" menu built successfully
00:03:22.111 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:03:19.402 Info "ROOT 1/1 (Global 1/5)" menu built successfully
00:02:36.832 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:02:34.428 Important Starting BD root menu encoding: [Memory load 21%] [Available virtual memory 1530 Mb.]
00:02:34.416 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Metallic (open style)
00:02:34.125 Info subtitle #3 - Encoded subtitles frames: 3469
00:02:34.103 Info video #1 - Processed video frames: 135497 (135496 frames encoded, 0 frames dropped, 0 frames duplicated)
00:02:34.063 Error 7 subtitle frames can't be encoded. Subtitles may not be complete. You should consider integrating subtitles directly to the video stream for perfect rendering
23:28:05.483 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3700000,bt=50M,maxrate=20000000,minrate=0,me_method=epzs,codec=h264,width=1280,height=720,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=15000000,rc_init_occupancy=15000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
23:28:05.477 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
+-[subtitle #2 - subrip subtitle]
+-[audio [eng] eac3 main audio 6 Ch. 48000Hz , 640 Kbps]
+-[video h264 1920x800 12:5 yuv420p, 23.98Fps, 0Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Enola Holmes\BDMV\STREAM\00009.m2ts (Blu-ray)
Input file: D:\VUZE downloads\Honey.Boy.2019.REPACK.1080p.AMZN.WEB-DL.DDP5.1.H.264-TEPES[EtHD]\Honey.Boy.2019.REPACK.1080p.AMZN.WEB-DL.DDP5.1.H.264-TEPES[EtHD].mkv
Video filters used:
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 94, bottom: 94, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
23:28:05.471 Info Chapters to generate: 16 (0h00m00s, 0h00m44s, 0h04m26s, 0h06m04s, 0h06m07s, 0h10m22s, 0h20m23s, 0h24m07s, 0h30m29s, 0h36m25s, 0h39m48s, 0h50m30s, 0h58m43s, 1h09m16s, 1h15m20s, 1h27m24s, )
23:28:05.468 Important Starting video encoding: [Memory load 19%] [Available virtual memory 2172 Mb.]
23:28:05.400 Verbose FFmpeg Opening file D:\VUZE downloads\Honey.Boy.2019.REPACK.1080p.AMZN.WEB-DL.DDP5.1.H.264-TEPES[EtHD]\Honey.Boy.2019.REPACK.1080p.AMZN.WEB-DL.DDP5.1.H.264-TEPES[EtHD].mkv
22:01:26.653 Info Menu fit: Text size reduced from 23.00 to 18.00 in style "Title of root menu pages"
22:01:26.497 Verbose FFmpeg Opening file D:\VUZE downloads\Honey.Boy.2019.REPACK.1080p.AMZN.WEB-DL.DDP5.1.H.264-TEPES[EtHD]\Honey.Boy.2019.REPACK.1080p.AMZN.WEB-DL.DDP5.1.H.264-TEPES[EtHD].mkv
22:01:26.496 Group ******************** Titleset #10 - ~94 min. File: "Honey.Boy.2019.REPACK.1080p.AMZN.WEB-DL.DDP5.1.H.264-TEPES[EtHD]" -> 00009.m2ts - Blu-ray ********************|GK_TITLESET|
00:00:56.326 ------------ *****************************************File encoded successfully: 00008.m2ts******************************************
00:00:56.318 Info "CHAPTERS 3/3 (Global 4/4)" menu built successfully
23:59:57.876 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:59:53.796 Info "CHAPTERS 2/3 (Global 3/4)" menu built successfully
23:58:53.896 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:58:51.236 Info "CHAPTERS 1/3 (Global 2/4)" menu built successfully
23:57:51.107 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:57:46.726 Info "ROOT 1/1 (Global 1/4)" menu built successfully
23:57:10.044 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:57:09.184 Important Starting BD root menu encoding: [Memory load 20%] [Available virtual memory 1822 Mb.]
23:57:09.181 Info Building ROOT, CHAPTERS, menus using template: Metallic (open style)
23:57:09.023 Info video #1 - Processed video frames: 128940 (128940 frames encoded, 0 frames dropped, 1 frames duplicated)
23:28:00.753 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3700000,bt=50M,maxrate=20000000,minrate=0,me_method=epzs,codec=h264,width=1280,height=720,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=15000000,rc_init_occupancy=15000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
23:28:00.744 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 224000 bps]
+-[audio aac main audio 2 Ch. 48000Hz , 128 Kbps]
+-[video h264 1920x800 12:5 yuv420p, 23.98Fps, 2099Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Enola Holmes\BDMV\STREAM\00008.m2ts (Blu-ray)
Input file: D:\VUZE downloads\Good Boys (2019) [BluRay] [1080p] [YTS.LT]\Good.Boys.2019.1080p.BluRay.x264-[YTS.LT].mp4
Video filters used:
23:28:00.741 Info Chapters to generate: 18 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, )
23:28:00.738 Important Starting video encoding: [Memory load 18%] [Available virtual memory 2507 Mb.]
23:28:00.577 Verbose FFmpeg Opening file D:\VUZE downloads\Good Boys (2019) [BluRay] [1080p] [YTS.LT]\Good.Boys.2019.1080p.BluRay.x264-[YTS.LT].mp4
22:01:26.323 Verbose FFmpeg Opening file D:\VUZE downloads\Good Boys (2019) [BluRay] [1080p] [YTS.LT]\Good.Boys.2019.1080p.BluRay.x264-[YTS.LT].mp4
22:01:26.322 Group ******************** Titleset #9 - ~89 min. File: "Good.Boys.2019.1080p.BluRay.x264-[YTS.LT]" -> 00008.m2ts - Blu-ray ********************|GK_TITLESET|
00:12:05.859 ------------ *****************************************File encoded successfully: 00007.m2ts******************************************
00:12:05.855 Info "SETTINGS 1/1 (Global 6/6)" menu built successfully
00:11:41.943 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:11:41.810 Info "CHAPTERS 4/4 (Global 5/6)" menu built successfully
00:11:04.237 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:11:02.432 Info "CHAPTERS 3/4 (Global 4/6)" menu built successfully
00:10:20.530 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:10:18.341 Info "CHAPTERS 2/4 (Global 3/6)" menu built successfully
00:09:41.280 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:09:37.799 Info "CHAPTERS 1/4 (Global 2/6)" menu built successfully
00:08:59.926 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:08:56.374 Info "ROOT 1/1 (Global 1/6)" menu built successfully
00:08:26.576 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
00:08:26.197 Important Starting BD root menu encoding: [Memory load 20%] [Available virtual memory 1812 Mb.]
00:08:26.194 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Metallic (open style)
00:08:25.991 Info subtitle #3 - Encoded subtitles frames: 9
00:08:25.988 Info video #1 - Processed video frames: 159906 (159906 frames encoded, 0 frames dropped, 1 frames duplicated)
23:27:55.888 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3700000,bt=50M,maxrate=20000000,minrate=0,me_method=epzs,codec=h264,width=1280,height=720,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=15000000,rc_init_occupancy=15000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
23:27:55.885 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 (Default)]
+-[subtitle #0 - srt subtitle]
+-[video h264 1280x694 24:13 yuv420p, 23.98Fps, 1150Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Enola Holmes\BDMV\STREAM\00007.m2ts (Blu-ray)
Input file: D:\VUZE downloads\Give Me Liberty (2019) [720p] [BluRay] [YTS.MX]\Give.Me.Liberty.2019.720p.BluRay.x264.AAC-[YTS.MX].mp4
Video filters used:
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 14, bottom: 14, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
23:27:55.883 Info Chapters to generate: 23 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, 1h30m00s, 1h35m00s, 1h40m00s, 1h45m00s, 1h50m00s, )
23:27:55.881 Important Starting video encoding: [Memory load 17%] [Available virtual memory 2824 Mb.]
23:27:55.879 Verbose FFmpeg Opening file D:\VUZE downloads\Give Me Liberty (2019) [720p] [BluRay] [YTS.MX]\Give.Me.Liberty.2019.720p.BluRay.x264.AAC-[YTS.MX].srt
23:27:55.774 Verbose FFmpeg Opening file D:\VUZE downloads\Give Me Liberty (2019) [720p] [BluRay] [YTS.MX]\Give.Me.Liberty.2019.720p.BluRay.x264.AAC-[YTS.MX].mp4
22:01:26.165 Verbose FFmpeg Opening file D:\VUZE downloads\Give Me Liberty (2019) [720p] [BluRay] [YTS.MX]\Give.Me.Liberty.2019.720p.BluRay.x264.AAC-[YTS.MX].srt
22:01:26.120 Verbose FFmpeg Opening file D:\VUZE downloads\Give Me Liberty (2019) [720p] [BluRay] [YTS.MX]\Give.Me.Liberty.2019.720p.BluRay.x264.AAC-[YTS.MX].mp4
22:01:26.119 Group ******************** Titleset #8 - ~111 min. File: "Give.Me.Liberty.2019.720p.BluRay.x264.AAC-[YTS.MX]" -> 00007.m2ts - Blu-ray ********************|GK_TITLESET|
23:20:26.826 ------------ *****************************************File encoded successfully: 00006.m2ts******************************************
23:20:26.819 Info "CHAPTERS 4/4 (Global 5/5)" menu built successfully
23:19:56.304 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:19:54.630 Info "CHAPTERS 3/4 (Global 4/5)" menu built successfully
23:19:04.372 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:18:58.617 Info "CHAPTERS 2/4 (Global 3/5)" menu built successfully
23:18:08.281 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:18:03.803 Info "CHAPTERS 1/4 (Global 2/5)" menu built successfully
23:17:14.013 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:17:09.683 Info "ROOT 1/1 (Global 1/5)" menu built successfully
23:16:37.017 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:16:34.702 Important Starting BD root menu encoding: [Memory load 21%] [Available virtual memory 1355 Mb.]
23:16:34.697 Info Building ROOT, CHAPTERS, menus using template: Metallic (open style)
23:16:34.566 Info video #1 - Processed video frames: 138048 (138048 frames encoded, 0 frames dropped, 1 frames duplicated)
22:46:46.391 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3700000,bt=50M,maxrate=20000000,minrate=0,me_method=epzs,codec=h264,width=1280,height=720,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1/24,bf=3,refs=4,h264_level=4.1,bufsize=15000000,rc_init_occupancy=15000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
22:46:46.380 ------------ +--> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch. back, 640000 bps]
+-[audio aac main audio 6 Ch. 48000Hz , 384 Kbps]
+--> [video #1 - h264 video, 1280x720, yuv420p, 16x9, 24.00Fps, 3700Kbps]
+-[video h264 1920x800 12:5 yuv420p, 24.00Fps, 2249Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Enola Holmes\BDMV\STREAM\00006.m2ts (Blu-ray)
Input file: D:\VUZE downloads\End Of Sentence (2019) [1080p] [BluRay] [5.1] [YTS.MX]\End.Of.Sentence.2019.1080p.BluRay.x264.AAC5.1-[YTS.MX].mp4
Video filters used:
22:46:46.373 Info Chapters to generate: 20 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, 1h30m00s, 1h35m00s, )
22:46:46.369 Important Starting video encoding: [Memory load 20%] [Available virtual memory 1483 Mb.]
22:46:46.139 Verbose FFmpeg Opening file D:\VUZE downloads\End Of Sentence (2019) [1080p] [BluRay] [5.1] [YTS.MX]\End.Of.Sentence.2019.1080p.BluRay.x264.AAC5.1-[YTS.MX].mp4
22:01:26.106 Info Menu fit: Text size reduced from 29.00 to 23.00 in style "Title of root menu pages"
22:01:25.896 Verbose FFmpeg Opening file D:\VUZE downloads\End Of Sentence (2019) [1080p] [BluRay] [5.1] [YTS.MX]\End.Of.Sentence.2019.1080p.BluRay.x264.AAC5.1-[YTS.MX].mp4
22:01:25.895 Group ******************** Titleset #7 - ~95 min. File: "End.Of.Sentence.2019.1080p.BluRay.x264.AAC5.1-[YTS.MX]" -> 00006.m2ts - Blu-ray ********************|GK_TITLESET|
23:21:05.720 ------------ *****************************************File encoded successfully: 00005.m2ts******************************************
23:21:05.711 Info "SETTINGS 1/1 (Global 8/8)" menu built successfully
23:20:46.890 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:20:46.768 Info "CHAPTERS 6/6 (Global 7/8)" menu built successfully
23:20:08.925 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:20:08.075 Info "CHAPTERS 5/6 (Global 6/8)" menu built successfully
23:19:23.842 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:19:22.395 Info "CHAPTERS 4/6 (Global 5/8)" menu built successfully
23:18:36.818 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:18:35.432 Info "CHAPTERS 3/6 (Global 4/8)" menu built successfully
23:17:49.697 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:17:48.132 Info "CHAPTERS 2/6 (Global 3/8)" menu built successfully
23:17:03.204 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:17:01.777 Info "CHAPTERS 1/6 (Global 2/8)" menu built successfully
23:16:11.286 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:16:03.528 Info "ROOT 1/1 (Global 1/8)" menu built successfully
23:15:31.242 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:15:30.622 Important Starting BD root menu encoding: [Memory load 20%] [Available virtual memory 1610 Mb.]
23:15:30.619 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Metallic (open style)
23:15:30.282 Info subtitle #3 - Encoded subtitles frames: 107
23:15:30.279 Info video #1 - Processed video frames: 124605 (124604 frames encoded, 0 frames dropped, 0 frames duplicated)
22:46:41.402 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3700000,bt=50M,maxrate=20000000,minrate=0,me_method=epzs,codec=h264,width=1280,height=720,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=15000000,rc_init_occupancy=15000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
22:46:41.396 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 (Default)]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Enola Holmes\BDMV\STREAM\00005.m2ts (Blu-ray)
Input file: D:\VUZE downloads\COMANDO.TO - Get Duked 2020 [1080p] DUAL\Get.Duked.2019.1080p.WEB-DL.6CH.x264.DUAL-COMANDO.TO.mkv
Video filters used:
22:46:41.393 Info Chapters to generate: 35 (0h00m00s, 0h00m23s, 0h00m32s, 0h01m56s, 0h02m56s, 0h05m59s, 0h09m07s, 0h09m21s, 0h16m45s, 0h19m18s, 0h26m23s, 0h27m53s, 0h34m13s, 0h36m33s, 0h37m32s, 0h39m13s, 0h40m47s, 0h42m36s, 0h43m25s, 0h44m22s, 0h45m21s, 0h46m28s, 0h47m02s, 0h48m18s, 0h49m48s, 0h56m01s, 0h59m30s, 1h02m51s, 1h04m12s, 1h04m56s, 1h07m42s, 1h15m29s, 1h21m07s, 1h22m32s, 1h23m10s, )
22:46:41.389 Important Starting video encoding: [Memory load 19%] [Available virtual memory 1833 Mb.]
22:46:41.386 Verbose FFmpeg Opening file D:\VUZE downloads\COMANDO.TO - Get Duked 2020 [1080p] DUAL\Get.Duked.2019.1080p.WEB-DL.6CH.x264.DUAL-COMANDO.TO.srt
22:46:41.291 Verbose FFmpeg Opening file D:\VUZE downloads\COMANDO.TO - Get Duked 2020 [1080p] DUAL\Get.Duked.2019.1080p.WEB-DL.6CH.x264.DUAL-COMANDO.TO.mkv
22:01:25.702 Verbose FFmpeg Opening file D:\VUZE downloads\COMANDO.TO - Get Duked 2020 [1080p] DUAL\Get.Duked.2019.1080p.WEB-DL.6CH.x264.DUAL-COMANDO.TO.srt
22:01:25.697 Verbose FFmpeg Opening file D:\VUZE downloads\COMANDO.TO - Get Duked 2020 [1080p] DUAL\Get.Duked.2019.1080p.WEB-DL.6CH.x264.DUAL-COMANDO.TO.mkv
22:01:25.696 Group ******************** Titleset #6 - ~86 min. File: "Get Duked" -> 00005.m2ts - Blu-ray ********************|GK_TITLESET|
23:27:49.481 ------------ *****************************************File encoded successfully: 00004.m2ts******************************************
23:27:49.477 Info "SETTINGS 1/1 (Global 6/6)" menu built successfully
23:27:32.492 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:27:32.404 Info "CHAPTERS 4/4 (Global 5/6)" menu built successfully
23:27:04.351 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:27:03.226 Info "CHAPTERS 3/4 (Global 4/6)" menu built successfully
23:26:15.753 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:26:11.470 Info "CHAPTERS 2/4 (Global 3/6)" menu built successfully
23:25:30.276 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:25:27.715 Info "CHAPTERS 1/4 (Global 2/6)" menu built successfully
23:24:43.167 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:24:40.272 Info "ROOT 1/1 (Global 1/6)" menu built successfully
ink
Post by ink »
23:24:17.598 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:24:16.431 Important Starting BD root menu encoding: [Memory load 17%] [Available virtual memory 2874 Mb.]
23:24:16.429 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Metallic (open style)
23:24:16.353 Info subtitle #3 - Encoded subtitles frames: 4639
23:24:16.350 Info video #1 - Processed video frames: 147374 (147373 frames encoded, 0 frames dropped, 0 frames duplicated)
23:24:16.336 Error 8 subtitle frames can't be encoded. Subtitles may not be complete. You should consider integrating subtitles directly to the video stream for perfect rendering
22:37:35.614 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3700000,bt=50M,maxrate=40000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1/24,bf=3,refs=4,h264_level=4.1,bufsize=30000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
22:37:35.610 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English] (Default)]
+--> [video #1 - h264 video, 1920x1080, yuv420p, 16x9, 24.00Fps, 3700Kbps]
+-[video h264 1920x1080 16:9 yuv420p, 24.00Fps, 0Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Enola Holmes\BDMV\STREAM\00004.m2ts (Blu-ray)
Input file: D:\VUZE downloads\Booksmart.2019.1080p.NF.WEB-DL.DD5.1.H264-CMRG[EtHD]\Booksmart.2019.1080p.NF.WEB-DL.DD5.1.H264-CMRG[EtHD].mkv
Video filters used:
22:37:35.608 Info Chapters to generate: 21 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, 1h30m00s, 1h35m00s, 1h40m00s, )
22:37:35.605 Important Starting video encoding: [Memory load 20%] [Available virtual memory 1835 Mb.]
22:37:35.514 Verbose FFmpeg Opening file D:\VUZE downloads\Booksmart.2019.1080p.NF.WEB-DL.DD5.1.H264-CMRG[EtHD]\Booksmart.2019.1080p.NF.WEB-DL.DD5.1.H264-CMRG[EtHD].mkv
22:01:25.544 Verbose FFmpeg Opening file D:\VUZE downloads\Booksmart.2019.1080p.NF.WEB-DL.DD5.1.H264-CMRG[EtHD]\Booksmart.2019.1080p.NF.WEB-DL.DD5.1.H264-CMRG[EtHD].mkv
22:01:25.543 Group ******************** Titleset #5 - ~102 min. File: "Booksmart" -> 00004.m2ts - Blu-ray ********************|GK_TITLESET|
22:46:35.146 ------------ *****************************************File encoded successfully: 00003.m2ts******************************************
22:46:35.137 Info "SETTINGS 1/1 (Global 5/5)" menu built successfully
22:46:08.732 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
22:46:08.588 Info "CHAPTERS 3/3 (Global 4/5)" menu built successfully
22:45:39.307 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
22:45:39.103 Info "CHAPTERS 2/3 (Global 3/5)" menu built successfully
22:44:49.553 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
22:44:48.755 Info "CHAPTERS 1/3 (Global 2/5)" menu built successfully
22:44:00.402 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
22:43:59.175 Info "ROOT 1/1 (Global 1/5)" menu built successfully
22:43:20.115 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
22:43:18.053 Important Starting BD root menu encoding: [Memory load 20%] [Available virtual memory 1609 Mb.]
22:43:18.050 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Metallic (open style)
22:43:17.875 Info video #1 - Processed video frames: 156664 (156665 frames encoded, 0 frames dropped, 2 frames duplicated)
22:01:43.466 Warning [decoder][truehd]: Lossless check failed - expected 0 , calculated fe.
22:01:43.463 Error [demuxer][matroska,webm]: File is broken, keyframes not correctly marked!
22:43:17.871 Group FFmpeg Decoder: "D:\VUZE downloads\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO.mkv"
22:01:43.443 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3700000,bt=50M,maxrate=20000000,minrate=0,me_method=epzs,codec=h264,width=1280,height=720,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=15000000,rc_init_occupancy=15000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
22:01:43.436 ------------ +--> [audio #3 - ac3 audio, 48000Hz, 5.1 Ch., 640000 bps [English]]
+-[audio [eng] ac3 main audio 6 Ch. 48000Hz , 640 Kbps]
+-[audio [eng] truehd main audio 8 Ch. 48000Hz ]
+-[video h264 1920x804 160:67 yuv420p, 23.98Fps, 0Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Enola Holmes\BDMV\STREAM\00003.m2ts (Blu-ray)
Input file: D:\VUZE downloads\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO.mkv
Video filters used:
22:01:43.428 Info Chapters to generate: 13 (0h00m00s, 0h08m08s, 0h17m53s, 0h27m11s, 0h35m40s, 0h44m48s, 0h53m43s, 1h01m15s, 1h10m56s, 1h19m06s, 1h24m28s, 1h34m28s, 1h41m27s, )
22:01:43.426 Important Starting video encoding: [Memory load 18%] [Available virtual memory 2141 Mb.]
22:01:43.326 Verbose FFmpeg Opening file D:\VUZE downloads\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO.mkv
22:01:25.421 Verbose FFmpeg Opening file D:\VUZE downloads\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO.mkv
22:01:25.420 Group ******************** Titleset #4 - ~108 min. File: "Birds of Prey" -> 00003.m2ts - Blu-ray ********************|GK_TITLESET|
22:37:28.904 ------------ *****************************************File encoded successfully: 00002.m2ts******************************************
22:37:28.901 Info "CHAPTERS 1/1 (Global 2/2)" menu built successfully
22:36:38.217 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
22:36:37.613 Info "ROOT 1/1 (Global 1/2)" menu built successfully
22:35:56.856 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
22:35:55.681 Important Starting BD root menu encoding: [Memory load 19%] [Available virtual memory 1941 Mb.]
22:35:55.679 Info Building ROOT & CHAPTERS, menus using template: Metallic (open style)
22:35:55.614 Info video #1 - Processed video frames: 128129 (128127 frames encoded, 1 frames dropped, 0 frames duplicated)
22:01:38.493 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3700000,bt=50M,maxrate=20000000,minrate=0,me_method=epzs,codec=h264,width=1280,height=720,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1/24,bf=3,refs=4,h264_level=4.1,bufsize=15000000,rc_init_occupancy=15000000,slices=4,language=en,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
22:01:38.489 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 224000 bps [English]]
+-[audio [eng] ac3 main audio 2 Ch. 48000Hz , 192 Kbps]
+-[video [eng] h264 1416x1076 254:193 yuv420p, 24.00Fps, 0Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Enola Holmes\BDMV\STREAM\00002.m2ts (Blu-ray)
Input file: D:\VUZE downloads\Bait.2019.1080p.WEB-DL.H264.AC3-EVO[TGx]\Bait.2019.1080p.WEB-DL.H264.AC3-EVO.mkv
Video filters used:
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 0, bottom: 0, left: 166, right: 166. Cropping: top: 0, bottom: 0, left: 0, right: 0)
22:01:38.486 Info Chapters to generate: 5 (0h00m00s, 0h21m07s, 0h42m37s, 1h04m09s, 1h24m36s, )
22:01:38.485 Important Starting video encoding: [Memory load 17%] [Available virtual memory 2521 Mb.]
22:01:38.415 Verbose FFmpeg Opening file D:\VUZE downloads\Bait.2019.1080p.WEB-DL.H264.AC3-EVO[TGx]\Bait.2019.1080p.WEB-DL.H264.AC3-EVO.mkv
22:01:25.308 Verbose FFmpeg Opening file D:\VUZE downloads\Bait.2019.1080p.WEB-DL.H264.AC3-EVO[TGx]\Bait.2019.1080p.WEB-DL.H264.AC3-EVO.mkv
22:01:25.307 Group ******************** Titleset #3 - ~88 min. File: "Bait.2019.1080p.WEB-DL.H264.AC3-EVO" -> 00002.m2ts - Blu-ray ********************|GK_TITLESET|
22:44:21.074 ------------ *****************************************File encoded successfully: 00001.m2ts******************************************
22:44:21.065 Info "SETTINGS 1/1 (Global 6/6)" menu built successfully
22:43:52.936 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
22:43:52.779 Info "CHAPTERS 4/4 (Global 5/6)" menu built successfully
22:43:11.343 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
22:43:10.412 Info "CHAPTERS 3/4 (Global 4/6)" menu built successfully
22:42:17.303 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
22:42:15.012 Info "CHAPTERS 2/4 (Global 3/6)" menu built successfully
22:41:21.947 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
22:41:19.190 Info "CHAPTERS 1/4 (Global 2/6)" menu built successfully
22:40:25.630 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
22:40:22.705 Info "ROOT 1/1 (Global 1/6)" menu built successfully
22:39:43.266 Info H264 settings for stream #1: codec=h264,width=1280,height=720,dar=16/9,user_b=12000000,bt=12000000,maxrate=20000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,minrate=0,bufsize=15000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
22:39:41.395 Important Starting BD root menu encoding: [Memory load 20%] [Available virtual memory 1615 Mb.]
22:39:41.390 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Metallic (open style)
22:39:41.090 Info subtitle #4 - Encoded subtitles frames: 3813
22:39:41.088 Info subtitle #3 - Encoded subtitles frames: 3523
22:39:41.084 Info video #1 - Processed video frames: 156264 (156263 frames encoded, 0 frames dropped, 0 frames duplicated)
22:39:41.064 Error 8 subtitle frames can't be encoded. Subtitles may not be complete. You should consider integrating subtitles directly to the video stream for perfect rendering
22:39:41.061 Error 27 subtitle frames can't be encoded. Subtitles may not be complete. You should consider integrating subtitles directly to the video stream for perfect rendering
22:01:33.614 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3700000,bt=50M,maxrate=20000000,minrate=0,me_method=epzs,codec=h264,width=1280,height=720,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=15000000,rc_init_occupancy=15000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
22:01:33.611 ------------ +--> [subtitle #4 - hdmv_pgs_subtitle subtitle, 1920x1080 [English]]
+-[subtitle #3 - subrip subtitle]
+-[video h264 1920x816 47:20 yuv420p, 23.98Fps, 0Kbps ]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Enola Holmes\BDMV\STREAM\00001.m2ts (Blu-ray)
Input file: D:\VUZE downloads\Bad.Education.2019.1080p.WEB.H264-SECRECY[TGx]\Bad.Education.2019.1080p.WEB.H264-SECRECY.mkv
Video filters used:
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 88, bottom: 88, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
22:01:33.607 Info Chapters to generate: 22 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, 1h30m00s, 1h35m00s, 1h40m00s, 1h45m00s, )
22:01:33.605 Important Starting video encoding: [Memory load 16%] [Available virtual memory 2892 Mb.]
22:01:33.559 Verbose FFmpeg Opening file D:\VUZE downloads\Bad.Education.2019.1080p.WEB.H264-SECRECY[TGx]\Bad.Education.2019.1080p.WEB.H264-SECRECY.mkv
22:01:25.294 Info Menu fit: Text size reduced from 36.00 to 29.00 in style "Title of root menu pages"
22:01:25.102 Verbose FFmpeg Opening file D:\VUZE downloads\Bad.Education.2019.1080p.WEB.H264-SECRECY[TGx]\Bad.Education.2019.1080p.WEB.H264-SECRECY.mkv
22:01:25.101 Group ******************** Titleset #2 - ~108 min. File: "Bad.Education.2019.1080p.WEB.H264-SECRECY" -> 00001.m2ts - Blu-ray ********************|GK_TITLESET|
23:23:49.137 ------------ *****************************************File encoded successfully: 00000.m2ts******************************************
23:23:49.127 Info "SETTINGS 1/1 (Global 7/7)" menu built successfully
23:23:21.713 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:23:21.580 Info "CHAPTERS 5/5 (Global 6/7)" menu built successfully
23:22:44.097 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:22:43.947 Info "CHAPTERS 4/5 (Global 5/7)" menu built successfully
23:21:17.480 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:21:16.992 Info "CHAPTERS 3/5 (Global 4/7)" menu built successfully
23:19:38.528 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:19:37.604 Info "CHAPTERS 2/5 (Global 3/7)" menu built successfully
23:17:43.799 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:17:42.500 Info "CHAPTERS 1/5 (Global 2/7)" menu built successfully
23:15:53.730 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:15:52.612 Info "ROOT 1/1 (Global 1/7)" menu built successfully
23:14:54.676 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
23:14:53.350 Important Starting BD root menu encoding: [Memory load 20%] [Available virtual memory 1639 Mb.]
23:14:53.348 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Metallic (open style)
23:14:52.975 Info subtitle #3 - Encoded subtitles frames: 3213
23:14:52.969 Info video #1 - Processed video frames: 178429 (178428 frames encoded, 0 frames dropped, 0 frames duplicated)
22:01:28.775 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3700000,bt=50M,maxrate=40000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1/24,bf=3,refs=4,h264_level=4.1,bufsize=30000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
22:01:28.774 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 (Default)]
+--> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch., 640000 bps [English]]
+-[audio [eng] ac3 main audio 6 Ch. 48000Hz , 384 Kbps]
Output file: C:\Users\inkey\Documents\ConvertXtoHD\Enola Holmes\BDMV\STREAM\00000.m2ts (Blu-ray)
Input file: D:\VUZE downloads\COMANDOTORRENTSHD.NET - Enola Holmes 2020 [1080p-FULL] [DUAL]\COMANDOTORRENTSHD.NET - Enola.Holmes.2020.1080p.NF.WEB-DL.6CH.x264.DUAL.mkv
Video filters used:
- DeInterlace filter: VSO
22:01:28.772 Info Chapters to generate: 25 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, 1h30m00s, 1h35m00s, 1h40m00s, 1h45m00s, 1h50m00s, 1h55m00s, 2h00m00s, )
22:01:28.771 Important Starting video encoding: [Memory load 14%] [Available virtual memory 3517 Mb.]
22:01:28.756 Verbose FFmpeg Opening file D:\VUZE downloads\COMANDOTORRENTSHD.NET - Enola Holmes 2020 [1080p-FULL] [DUAL]\COMANDOTORRENTSHD.NET - Enola.Holmes.2020.1080p.NF.WEB-DL.6CH.x264.DUAL.srt
22:01:28.718 Verbose FFmpeg Opening file D:\VUZE downloads\COMANDOTORRENTSHD.NET - Enola Holmes 2020 [1080p-FULL] [DUAL]\COMANDOTORRENTSHD.NET - Enola.Holmes.2020.1080p.NF.WEB-DL.6CH.x264.DUAL.mkv
22:01:24.933 Verbose FFmpeg Opening file D:\VUZE downloads\COMANDOTORRENTSHD.NET - Enola Holmes 2020 [1080p-FULL] [DUAL]\COMANDOTORRENTSHD.NET - Enola.Holmes.2020.1080p.NF.WEB-DL.6CH.x264.DUAL.srt
22:01:24.927 Verbose FFmpeg Opening file D:\VUZE downloads\COMANDOTORRENTSHD.NET - Enola Holmes 2020 [1080p-FULL] [DUAL]\COMANDOTORRENTSHD.NET - Enola.Holmes.2020.1080p.NF.WEB-DL.6CH.x264.DUAL.mkv
22:01:24.926 Group ******************** Titleset #1 - ~123 min. File: "Enola Holmes" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
22:01:24.919 Info Encoding options: Long Project (Automatic)
22:01:24.918 Info Target size: 46000 Mb.
22:01:24.916 Important Setting queuer for Blu-ray output: [Wait: 4000], [ld: 1000], [Hd: 10000], [MAM: 600], [RM: 500], [ALL: True]
22:01:24.915 Important Reduced simultaneous conversions to 4 because the output is a Blu-ray Full HD
22:01:24.913 Info Don't log FFMpeg log events
22:01:24.912 ------------ ***************************************************Burn settings end****************************************************
22:01:24.911 Info Default speed selected: 2x
22:01:24.910 Info [ ] Delete vsomsl files after burn complete
22:01:24.909 Info [ ] Delete output folder after burn complete
22:01:24.908 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
22:01:24.907 Info SAO setting: Automatic
22:01:24.906 Info [x] Burn result to disk / as ISO file in working folder
22:01:24.905 ------------ **************************************************Burn settings begin***************************************************
22:01:24.905 Group Encoding session started at 22:01:24: 12 titleset(s) to encode -> Completed in 02:34:20|GK_CONVERT_SESSION|
22:01:03.590 Info User requested cancellation
22:01:04.184 Info Conversion cancelled after 00:00:04
22:00:59.551 Info [ ] Loop playback
22:00:59.550 Info [ ] Play titles one after the other
22:00:59.549 Info [ ] Don't create title menu for single video
22:00:59.548 Info [x] Return to title menu after titleset playback
22:00:59.547 Info [x] Skip root menu initially
22:00:59.546 Info [ ] Auto-start playback
22:00:59.546 Info Template: Metallic (open style), contains 4 page(s)
22:00:59.546 Group Blu-ray/AVCHD menu options
22:00:59.545 Info Output target size : BD-50 (46000 MB)
22:00:59.544 Info Number of core(s) used for encoding : 16
22:00:59.543 Info Number of core(s) used for decoding : 16
22:00:59.542 Info [ ] Use 2 pass encoding
22:00:59.541 Info [ ] Use best video quality settings
22:00:59.541 Info [ ] Use hardware encoding (if possible)
22:00:59.540 Info [ ] Use hardware decoding (if possible)
22:00:59.539 Info Max simultaneous conversions: 4
22:00:59.539 Group Advanced encoding options
22:00:59.536 Info Menu fit: Text size reduced from 13.00 to 13.00 in style "Captions in title menu pages"
22:00:59.530 Info Menu fit: Text size reduced from 18.00 to 13.00 in style "Captions in title menu pages"
22:00:59.490 Info Menu fit: Text size reduced from 18.00 to 18.00 in style "Captions in title menu pages"
^^^Repeated 2 Times in 6 millisecond(s)^^^
22:00:59.484 Info Menu fit: Text size reduced from 23.00 to 18.00 in style "Captions in title menu pages"
22:00:59.448 Info Menu fit: Text size reduced from 27.00 to 23.00 in style "Captions in title menu pages"
22:00:57.608 Verbose FFmpeg Opening file D:\VUZE downloads\Richard.Jewell.2019.Bluray.1080p.DTS-HD.x264-GrymLegacy\Richard.Jewell.2019.Bluray.1080p.DTS-HD.x264-GrymLegacy.mkv
22:00:57.479 Verbose FFmpeg Opening file D:\VUZE downloads\Resistance.2020.1080p.BluRay.x264-GECKOS[TGx]\resistance.2020.1080p.bluray.x264-geckos.mkv
22:00:57.459 Info Menu fit: Text size reduced from 23.00 to 18.00 in style "Title of root menu pages"
22:00:57.305 Verbose FFmpeg Opening file D:\VUZE downloads\Honey.Boy.2019.REPACK.1080p.AMZN.WEB-DL.DDP5.1.H.264-TEPES[EtHD]\Honey.Boy.2019.REPACK.1080p.AMZN.WEB-DL.DDP5.1.H.264-TEPES[EtHD].mkv
22:00:57.124 Verbose FFmpeg Opening file D:\VUZE downloads\Good Boys (2019) [BluRay] [1080p] [YTS.LT]\Good.Boys.2019.1080p.BluRay.x264-[YTS.LT].mp4
22:00:56.963 Verbose FFmpeg Opening file D:\VUZE downloads\Give Me Liberty (2019) [720p] [BluRay] [YTS.MX]\Give.Me.Liberty.2019.720p.BluRay.x264.AAC-[YTS.MX].srt
22:00:56.917 Verbose FFmpeg Opening file D:\VUZE downloads\Give Me Liberty (2019) [720p] [BluRay] [YTS.MX]\Give.Me.Liberty.2019.720p.BluRay.x264.AAC-[YTS.MX].mp4
22:00:56.898 Info Menu fit: Text size reduced from 29.00 to 23.00 in style "Title of root menu pages"
22:00:56.686 Verbose FFmpeg Opening file D:\VUZE downloads\End Of Sentence (2019) [1080p] [BluRay] [5.1] [YTS.MX]\End.Of.Sentence.2019.1080p.BluRay.x264.AAC5.1-[YTS.MX].mp4
22:00:56.492 Verbose FFmpeg Opening file D:\VUZE downloads\COMANDO.TO - Get Duked 2020 [1080p] DUAL\Get.Duked.2019.1080p.WEB-DL.6CH.x264.DUAL-COMANDO.TO.srt
22:00:56.487 Verbose FFmpeg Opening file D:\VUZE downloads\COMANDO.TO - Get Duked 2020 [1080p] DUAL\Get.Duked.2019.1080p.WEB-DL.6CH.x264.DUAL-COMANDO.TO.mkv
22:00:56.330 Verbose FFmpeg Opening file D:\VUZE downloads\Booksmart.2019.1080p.NF.WEB-DL.DD5.1.H264-CMRG[EtHD]\Booksmart.2019.1080p.NF.WEB-DL.DD5.1.H264-CMRG[EtHD].mkv
22:00:56.201 Verbose FFmpeg Opening file D:\VUZE downloads\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO.mkv
22:00:56.089 Verbose FFmpeg Opening file D:\VUZE downloads\Bait.2019.1080p.WEB-DL.H264.AC3-EVO[TGx]\Bait.2019.1080p.WEB-DL.H264.AC3-EVO.mkv
22:00:56.071 Info Menu fit: Text size reduced from 36.00 to 29.00 in style "Title of root menu pages"
22:00:55.880 Verbose FFmpeg Opening file D:\VUZE downloads\Bad.Education.2019.1080p.WEB.H264-SECRECY[TGx]\Bad.Education.2019.1080p.WEB.H264-SECRECY.mkv
22:01:03.643 Warning File encoding cancelled by user: 00000.m2ts - step preparing titles
22:00:59.625 Info H264 settings for stream #1: preset=superfast,qmin=3,lmin=354,mblmin=354,b=3700000,bt=50M,maxrate=40000000,minrate=0,me_method=epzs,codec=h264,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1/24,bf=3,refs=4,h264_level=4.1,bufsize=30000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,threads=8
22:00:59.621 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 (Default)]
Video filters used:
22:00:59.619 Info Chapters to generate: 25 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, 1h30m00s, 1h35m00s, 1h40m00s, 1h45m00s, 1h50m00s, 1h55m00s, 2h00m00s, )
22:00:59.618 Important Starting video encoding: [Memory load 14%] [Available virtual memory 3521 Mb.]
22:00:59.602 Verbose FFmpeg Opening file D:\VUZE downloads\COMANDOTORRENTSHD.NET - Enola Holmes 2020 [1080p-FULL] [DUAL]\COMANDOTORRENTSHD.NET - Enola.Holmes.2020.1080p.NF.WEB-DL.6CH.x264.DUAL.srt
22:00:59.560 Verbose FFmpeg Opening file D:\VUZE downloads\COMANDOTORRENTSHD.NET - Enola Holmes 2020 [1080p-FULL] [DUAL]\COMANDOTORRENTSHD.NET - Enola.Holmes.2020.1080p.NF.WEB-DL.6CH.x264.DUAL.mkv
22:00:55.705 Verbose FFmpeg Opening file D:\VUZE downloads\COMANDOTORRENTSHD.NET - Enola Holmes 2020 [1080p-FULL] [DUAL]\COMANDOTORRENTSHD.NET - Enola.Holmes.2020.1080p.NF.WEB-DL.6CH.x264.DUAL.srt
22:00:55.700 Verbose FFmpeg Opening file D:\VUZE downloads\COMANDOTORRENTSHD.NET - Enola Holmes 2020 [1080p-FULL] [DUAL]\COMANDOTORRENTSHD.NET - Enola.Holmes.2020.1080p.NF.WEB-DL.6CH.x264.DUAL.mkv
22:00:55.699 Group ******************** Titleset #1 - ~123 min. File: "Enola Holmes" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
22:00:55.691 Info Encoding options: Long Project (Automatic)
22:00:55.691 Info Target size: 46000 Mb.
22:00:55.689 Important Setting queuer for Blu-ray output: [Wait: 4000], [ld: 1000], [Hd: 10000], [MAM: 600], [RM: 500], [ALL: True]
22:00:55.689 Important Reduced simultaneous conversions to 4 because the output is a Blu-ray Full HD
22:00:55.687 Info Don't log FFMpeg log events
22:00:55.686 ------------ ***************************************************Burn settings end****************************************************
22:00:55.686 Info Default speed selected: 2x
22:00:55.685 Info [ ] Delete vsomsl files after burn complete
22:00:55.684 Info [ ] Delete output folder after burn complete
22:00:55.684 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
22:00:55.683 Info SAO setting: Automatic
22:00:55.682 Info [x] Burn result to disk / as ISO file in working folder
22:00:55.682 ------------ **************************************************Burn settings begin***************************************************
22:00:55.681 Group Encoding session started at 22:00:55: 12 titleset(s) to encode -> Cancelled after 00:00:04|GK_CONVERT_SESSION|
21:59:38.296 Info Removed segment: Saint.Frances.2019.1080p.WEB-DL.H264.AC3-EVO
21:59:34.468 Important Loaded with result [File ]
21:59:34.258 Info Loading: "D:\VUZE downloads\Saint.Frances.2019.1080p.WEB-DL.H264.AC3-EVO[TGx]\Saint.Frances.2019.1080p.WEB-DL.H264.AC3-EVO.mkv - File" 1/1
21:59:34.118 Info Sources filtered, found 1 protocols
21:59:33.774 Info Added protocol D:\VUZE downloads\Saint.Frances.2019.1080p.WEB-DL.H264.AC3-EVO[TGx]\Saint.Frances.2019.1080p.WEB-DL.H264.AC3-EVO.mkv, candidate 1/1
21:59:33.621 Info Found 1 candidates
21:59:33.454 Info Filtering sources
21:59:33.454 Group Loading file(s)
21:59:14.378 Important Loaded with result [File ]
21:59:14.169 Info Loading: "D:\VUZE downloads\Richard.Jewell.2019.Bluray.1080p.DTS-HD.x264-GrymLegacy\Richard.Jewell.2019.Bluray.1080p.DTS-HD.x264-GrymLegacy.mkv - File" 1/1
21:59:14.013 Info Sources filtered, found 1 protocols
21:59:13.678 Info Added protocol D:\VUZE downloads\Richard.Jewell.2019.Bluray.1080p.DTS-HD.x264-GrymLegacy\Richard.Jewell.2019.Bluray.1080p.DTS-HD.x264-GrymLegacy.mkv, candidate 1/1
21:59:13.521 Info Found 1 candidates
21:59:13.343 Info Filtering sources
21:59:13.343 Group Loading file(s)
21:59:00.549 Important Loaded with result [File ]
21:59:00.328 Info Loading: "D:\VUZE downloads\Resistance.2020.1080p.BluRay.x264-GECKOS[TGx]\resistance.2020.1080p.bluray.x264-geckos.mkv - File" 1/1
21:59:00.160 Info Sources filtered, found 1 protocols
21:59:00.050 Info Added protocol D:\VUZE downloads\Resistance.2020.1080p.BluRay.x264-GECKOS[TGx]\resistance.2020.1080p.bluray.x264-geckos.mkv, candidate 1/1
21:58:59.905 Info Found 1 candidates
21:58:59.667 Info Filtering sources
21:58:59.667 Group Loading file(s)
21:58:32.049 Hint File "D:\VUZE downloads\Honey.Boy.2019.REPACK.1080p.AMZN.WEB-DL.DDP5.1.H.264-TEPES[EtHD]\Downloaded from www.ETTV.tv .txt" ignored. Ancillary files will eventually be loaded later.
21:58:32.049 Group Ignored file(s)
21:58:31.658 Important Loaded with result [File ]
21:58:31.443 Info Loading: "D:\VUZE downloads\Honey.Boy.2019.REPACK.1080p.AMZN.WEB-DL.DDP5.1.H.264-TEPES[EtHD]\Honey.Boy.2019.REPACK.1080p.AMZN.WEB-DL.DDP5.1.H.264-TEPES[EtHD].mkv - File" 2/2
21:58:31.442 Info Loading: "D:\VUZE downloads\Honey.Boy.2019.REPACK.1080p.AMZN.WEB-DL.DDP5.1.H.264-TEPES[EtHD]\Downloaded from www.ETTV.tv .txt - File" 1/2
21:58:31.306 Info Sources filtered, found 2 protocols
21:58:31.211 Info Added protocol D:\VUZE downloads\Honey.Boy.2019.REPACK.1080p.AMZN.WEB-DL.DDP5.1.H.264-TEPES[EtHD]\Honey.Boy.2019.REPACK.1080p.AMZN.WEB-DL.DDP5.1.H.264-TEPES[EtHD].mkv, candidate 2/2
21:58:31.211 Info Added protocol D:\VUZE downloads\Honey.Boy.2019.REPACK.1080p.AMZN.WEB-DL.DDP5.1.H.264-TEPES[EtHD]\Downloaded from www.ETTV.tv .txt, candidate 1/2
21:58:31.041 Info Found 2 candidates
21:58:30.764 Info Filtering sources
21:58:30.764 Group Loading file(s)
21:58:22.502 Important Loaded with result [File ]
21:58:22.285 Info Loading: "D:\VUZE downloads\Good Boys (2019) [BluRay] [1080p] [YTS.LT]\Good.Boys.2019.1080p.BluRay.x264-[YTS.LT].mp4 - File" 1/1
21:58:22.137 Info Sources filtered, found 1 protocols
21:58:22.035 Info Added protocol D:\VUZE downloads\Good Boys (2019) [BluRay] [1080p] [YTS.LT]\Good.Boys.2019.1080p.BluRay.x264-[YTS.LT].mp4, candidate 1/1
21:58:21.860 Info Found 1 candidates
21:58:21.594 Info Filtering sources
21:58:21.594 Group Loading file(s)
21:58:12.345 Important Loaded with result [File ]
21:58:12.120 Info Loading: "D:\VUZE downloads\Give Me Liberty (2019) [720p] [BluRay] [YTS.MX]\Give.Me.Liberty.2019.720p.BluRay.x264.AAC-[YTS.MX].mp4 - File" 1/1
21:58:11.977 Info Sources filtered, found 1 protocols
21:58:11.628 Info Added protocol D:\VUZE downloads\Give Me Liberty (2019) [720p] [BluRay] [YTS.MX]\Give.Me.Liberty.2019.720p.BluRay.x264.AAC-[YTS.MX].mp4, candidate 1/1
21:58:11.485 Info Found 1 candidates
21:58:11.331 Info Filtering sources
21:58:11.330 Group Loading file(s)
21:57:50.099 Important Loaded with result [File ]
21:57:49.848 Info Loading: "D:\VUZE downloads\End Of Sentence (2019) [1080p] [BluRay] [5.1] [YTS.MX]\End.Of.Sentence.2019.1080p.BluRay.x264.AAC5.1-[YTS.MX].mp4 - File" 1/1
21:57:49.704 Info Sources filtered, found 1 protocols
21:57:49.391 Info Added protocol D:\VUZE downloads\End Of Sentence (2019) [1080p] [BluRay] [5.1] [YTS.MX]\End.Of.Sentence.2019.1080p.BluRay.x264.AAC5.1-[YTS.MX].mp4, candidate 1/1
21:57:49.231 Info Found 1 candidates
21:57:49.081 Info Filtering sources
21:57:49.081 Group Loading file(s)
21:57:26.209 Info Removed segment: 1XBET.COM_promo_SHREK_dinheiro_livre
21:57:18.358 Hint File "D:\VUZE downloads\COMANDO.TO - Get Duked 2020 [1080p] DUAL\Get.Duked.2019.1080p.WEB-DL.6CH.x264.DUAL-COMANDO.TO.srt" ignored. Ancillary files will eventually be loaded later.
21:57:17.965 Hint File "D:\VUZE downloads\COMANDO.TO - Get Duked 2020 [1080p] DUAL\Get.Duked.2019.1080p.WEB-DL.6CH.x264.DUAL-COMANDO.TO-FULL.srt" ignored. Ancillary files will eventually be loaded later.
21:57:17.965 Group Ignored file(s)
21:57:17.511 Important Loaded with result [File ]
21:57:17.268 Info Loading: "D:\VUZE downloads\COMANDO.TO - Get Duked 2020 [1080p] DUAL\Get.Duked.2019.1080p.WEB-DL.6CH.x264.DUAL-COMANDO.TO.srt - File" 4/4
21:57:17.268 Info Loading: "D:\VUZE downloads\COMANDO.TO - Get Duked 2020 [1080p] DUAL\Get.Duked.2019.1080p.WEB-DL.6CH.x264.DUAL-COMANDO.TO.mkv - File" 3/4
21:57:17.267 Info Loading: "D:\VUZE downloads\COMANDO.TO - Get Duked 2020 [1080p] DUAL\Get.Duked.2019.1080p.WEB-DL.6CH.x264.DUAL-COMANDO.TO-FULL.srt - File" 2/4
21:57:17.267 Info Loading: "D:\VUZE downloads\COMANDO.TO - Get Duked 2020 [1080p] DUAL\1XBET.COM_promo_SHREK_dinheiro_livre.mp4 - File" 1/4
21:57:17.127 Info Sources filtered, found 4 protocols
21:57:17.008 Info Added protocol D:\VUZE downloads\COMANDO.TO - Get Duked 2020 [1080p] DUAL\Get.Duked.2019.1080p.WEB-DL.6CH.x264.DUAL-COMANDO.TO.srt, candidate 4/4
21:57:17.008 Info Added protocol D:\VUZE downloads\COMANDO.TO - Get Duked 2020 [1080p] DUAL\Get.Duked.2019.1080p.WEB-DL.6CH.x264.DUAL-COMANDO.TO.mkv, candidate 3/4
21:57:17.007 Info Added protocol D:\VUZE downloads\COMANDO.TO - Get Duked 2020 [1080p] DUAL\Get.Duked.2019.1080p.WEB-DL.6CH.x264.DUAL-COMANDO.TO-FULL.srt, candidate 2/4
21:57:16.802 Info Added protocol D:\VUZE downloads\COMANDO.TO - Get Duked 2020 [1080p] DUAL\1XBET.COM_promo_SHREK_dinheiro_livre.mp4, candidate 1/4
21:57:16.610 Info Found 4 candidates
21:57:16.404 Info Filtering sources
21:57:16.404 Group Loading file(s)
21:56:58.293 Important Loaded with result [File ]
ink
Re: Bought new Blu-Ray Writer to solve an issue AND it got worse
Post by ink »
21:56:58.052 Info Loading: "D:\VUZE downloads\Booksmart.2019.1080p.NF.WEB-DL.DD5.1.H264-CMRG[EtHD]\Booksmart.2019.1080p.NF.WEB-DL.DD5.1.H264-CMRG[EtHD].mkv - File" 1/1
21:56:57.880 Info Sources filtered, found 1 protocols
21:56:57.532 Info Added protocol D:\VUZE downloads\Booksmart.2019.1080p.NF.WEB-DL.DD5.1.H264-CMRG[EtHD]\Booksmart.2019.1080p.NF.WEB-DL.DD5.1.H264-CMRG[EtHD].mkv, candidate 1/1
21:56:57.377 Info Found 1 candidates
21:56:57.190 Info Filtering sources
21:56:57.190 Group Loading file(s)
21:56:29.658 Important Loaded with result [File ]
21:56:29.437 Info Loading: "D:\VUZE downloads\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO.mkv - File" 1/1
21:56:29.283 Info Sources filtered, found 1 protocols
21:56:29.189 Info Added protocol D:\VUZE downloads\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO\Birds.of.Prey.And.the.Fantabulous.Emancipation.of.One.Harley.Quinn.2020.1080p.Bluray.Atmos.TrueHD.7.1.x264-EVO.mkv, candidate 1/1
21:56:29.020 Info Found 1 candidates
21:56:28.752 Info Filtering sources
21:56:28.752 Group Loading file(s)
21:56:18.722 Important Loaded with result [File ]
21:56:18.474 Info Loading: "D:\VUZE downloads\Bait.2019.1080p.WEB-DL.H264.AC3-EVO[TGx]\Bait.2019.1080p.WEB-DL.H264.AC3-EVO.mkv - File" 1/1
21:56:18.309 Info Sources filtered, found 1 protocols
21:56:18.008 Info Added protocol D:\VUZE downloads\Bait.2019.1080p.WEB-DL.H264.AC3-EVO[TGx]\Bait.2019.1080p.WEB-DL.H264.AC3-EVO.mkv, candidate 1/1
21:56:17.844 Info Found 1 candidates
21:56:17.694 Info Filtering sources
21:56:17.694 Group Loading file(s)
21:55:59.405 Important Loaded with result [File ]
21:55:59.180 Info Loading: "D:\VUZE downloads\Bad.Education.2019.1080p.WEB.H264-SECRECY[TGx]\Bad.Education.2019.1080p.WEB.H264-SECRECY.mkv - File" 1/1
21:55:59.016 Info Sources filtered, found 1 protocols
21:55:58.715 Info Added protocol D:\VUZE downloads\Bad.Education.2019.1080p.WEB.H264-SECRECY[TGx]\Bad.Education.2019.1080p.WEB.H264-SECRECY.mkv, candidate 1/1
21:55:58.576 Info Found 1 candidates
21:55:58.431 Info Filtering sources
21:55:58.431 Group Loading file(s)
21:55:16.907 Important Loaded with result [File ]
21:55:16.668 Info Loading: "D:\VUZE downloads\COMANDOTORRENTSHD.NET - Enola Holmes 2020 [1080p-FULL] [DUAL]\COMANDOTORRENTSHD.NET - Enola.Holmes.2020.1080p.NF.WEB-DL.6CH.x264.DUAL.mkv - File" 1/1
21:55:16.526 Info Sources filtered, found 1 protocols
21:55:16.220 Info Added protocol D:\VUZE downloads\COMANDOTORRENTSHD.NET - Enola Holmes 2020 [1080p-FULL] [DUAL]\COMANDOTORRENTSHD.NET - Enola.Holmes.2020.1080p.NF.WEB-DL.6CH.x264.DUAL.mkv, candidate 1/1
21:55:16.052 Info Found 1 candidates
21:55:15.903 Info Filtering sources
21:55:15.903 Group Loading file(s)
21:55:07.131 Info Removed segment: Bad.Education.2019.1080p.WEB.H264-SECRECY
21:55:00.164 Important Loaded with result [File ]
21:54:59.934 Info Loading: "D:\VUZE downloads\Bad.Education.2019.1080p.WEB.H264-SECRECY[TGx]\Bad.Education.2019.1080p.WEB.H264-SECRECY.mkv - File" 1/1
21:54:59.782 Info Sources filtered, found 1 protocols
21:54:59.488 Info Added protocol D:\VUZE downloads\Bad.Education.2019.1080p.WEB.H264-SECRECY[TGx]\Bad.Education.2019.1080p.WEB.H264-SECRECY.mkv, candidate 1/1
21:54:59.319 Info Found 1 candidates
21:54:59.165 Info Filtering sources
21:54:59.165 Group Loading file(s)
21:36:18.121 Info Personnal resources size (C:\Users\inkey\Documents\ConvertXtoHD_Resources\): 0MB, 0 file(s)
21:36:17.916 Info Monotonizer size (C:\ProgramData\vso\vsomsl): 0MB, 1 file(s)
21:36:17.714 Info Thumb cache size (C:\ProgramData\VSO\vsothumbs): 34MB, 44 file(s)
21:36:17.510 Info Logs and templates size (C:\ProgramData\VSO\ConvertXtoHD\3\): 74MB, 663 file(s)
21:36:17.299 Group Folder data
21:36:17.294 Info Menu templates loaded: 20
21:36:16.617 Info License status: active customer license
21:36:16.617 Info License type: commercial (online activated)
21:36:16.617 Info Computer ID: 4050210
21:36:16.617 Group License
21:36:14.494 Info Loading templates from: "C:\Users\inkey\Documents\ConvertXtoHD_Resources\Templates\"
21:36:14.494 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoHD\3\Templates\"
21:36:14.493 ------------ ***************************ConvertXToHD.exe:8176 Log session start 2020-10-29 at 21:36:14.129***************************
02:09:10.131 Info Parsing disc ...
02:06:41.418 Info WRITE SUCCESS: Disc written
02:06:31.068 Info Burning process completed successfully.
02:06:31.061 Info Finalization Time 00:00:40.230 - Total completion time 01:30:21.323
02:06:31.054 Info Finalize: Finalisation completed
02:06:31.046 Info Finalize: Close disc - Completed
02:06:08.455 Info Finalize: Start Close media
02:06:08.449 Info Finalize: Close session - Completed
02:06:00.417 Info Finalize: Start Close session
02:06:00.406 Info Finalize: Close track - Completed
02:05:51.368 Info Finalize: Start Close track
02:05:51.349 Info Finalize: Flush device cache - Completed
02:05:50.837 Info Finalize: Flushing burner cache
02:05:50.833 Info Write finished in 01:29:41.096 - Finalization start here. Avg. burn rate 1.93
02:05:50.825 Info Finalize: Start disc finalisation
02:05:44.550 Info resuming write at address (22771808)
02:05:44.539 Info Sense at LBA 22771840 (32) - 05 21 02 [ILLEGAL REQUEST, invalid address for Write]
02:05:44.518 Warning Defered Write error
02:05:44.511 Info Sense at LBA 22771808 (32) - 03 0C 00 [MEDIUM ERROR, write error]
02:05:33.580 Error Exception encountered in read thread [Index de liste hors limites (-2147483643)]
02:05:33.575 Error Exception encountered in read thread [Index de liste hors limites (-2147483644)]
02:05:33.567 Error Exception encountered in read thread [Index de liste hors limites (-2147483645)]
02:05:33.559 Error Exception encountered in read thread [Index de liste hors limites (-2147483646)]
02:05:33.553 Error Exception encountered in read thread [Index de liste hors limites (-2147483647)]
02:05:33.544 Error Exception encountered in read thread [Index de liste hors limites (-2147483648)]
00:36:27.007 Info WRITING: Lead-in burning time required 00:00:17.268
00:36:21.392 Info resuming write at address (0)
00:36:21.381 Info Sense at LBA 32 (32) - 05 21 02 [ILLEGAL REQUEST, invalid address for Write]
00:36:21.361 Warning Defered Write error
00:36:21.355 Info Sense at LBA 0 (32) - 03 0C 00 [MEDIUM ERROR, write error]
00:36:09.736 Info Write started 22774112 sectors to write
00:36:09.731 Info Init BD-R: Success
00:36:09.727 Info Write speed set at x2.0 (8992 kB/s)
00:36:09.707 Info Available write speed: x6.0 (26976 kB/s) CAV *, x4.0 (17984 kB/s), x2.0 (8992 kB/s)
00:36:09.702 Info Media ID: RITEK-DR3-00
00:36:09.647 Info Scanned files #652, folder #16 - total size 46636159418 b. (43.4 GB.)
00:36:09.642 Info Inserted media type : bd-r sequential recording
00:36:09.633 Info Volume ID: Enola Holmes
00:36:09.623 Info Folder: C:\USERS\INKEY\DOCUMENTS\CONVERTXTOHD\ENOLA HOLMES\
00:36:09.618 Info Write started
00:36:08.386 Info Blu-ray/AVCHD structure burn process started
00:35:53.608 Info Writable disc bd-r sequential recording inserted. Ready to write
00:35:49.378 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu-Ray-R, Blu-Ray-RE (V1), Blu-Ray-RE (V2)
00:35:49.378 Info Drive has Serial ATA physical interface
00:35:49.377 Info New Drive selected : [G] HL-DT-ST BD-RE WH14NS40 1.03 (USB)
21:36:14.493 Info 2 writer(s) found.
21:36:14.478 Group Burn engine events
ink
Post by ink »
I have tried some fixes
Stopped using the GPU [as someone on the web suggested that was a solution]
Took out most the subtitles
If it looks like it's the Burner that's a problem - that would be great to know
As I would like to alert the seller ASAP
I am really bad at technical stuff - so wanted to check first
Thanks for any help
x
ink
Post by ink »
As a weird note...
After the conversion
After a burn [where the drive seems to be working all the time]
Once it's all finished
The Blu-Ray disc will show up [on my PC] as having 45.1 GB free of 45.1 GB ... so basically it will show up as a blank disc [?]
So maybe it never burns anything at all onto the disc
sorry I can't help with tech issues. But if doing testing, worth buying a rewriteable BD 25 disk. So if burn fails, you do not lose a good (non rewriteable) BD Disk.
With BD50 disks, I always have issues with them not writing correctly.
ink
Post by ink »
Thanks anyway
I never had a problem before [with my old machine] - but going to the new one [windows 10] that drive [an older LG model] I couldn't get to work
And then this one doesn't work
I bought second hand as money is super tight [no work with the virus thing]
So I was hoping it would work with the BD50 discs I already have... rather than having to buy some new 25gb ones... but I get what you mean, as I could then try and retry
Argh
I'm also annoyed at myself for how much time I have spent on all of this... being stupid really is a tax on your [by that I mean my - as I am talking about myself being stupid] time
Thanks for you help though x
Nemesh
Post by Nemesh »
Do you have the latest firmware installed in you writer?
What kind of media are you using to write to?
Try a Verbatim BD25 or BD50.
Have here 2x Pioneer BDR-209D (internal drives) and use Omega Freestyle BD25 and BD50 to write to.
Running Windows 10 Pro x64.
Seems to me that your LG has problems writing to the media you selected.
ink
Post by ink »
Thanks again so much
The discs are meant to be compatible
https://www.opticalquantum.com/products ... dl-logotop
They are listed as being so
My worry is I bought the LG WH14NS40 on eBay as refurbished by the seller and fully working [it came in a parcel smelling of cigarettes... argh]
But the MEDIUM ERROR, power calibration fail "CD-burner is dirty" - worries me
I wish I hadn't of been so poor/stupid and just bought a new one now
I don't even know what eBay 'refund' policy is - but I want to make sure it doesn't work first
I believe it has the latest firmware: 1.03
I am also wary of messing with it too much if I want to return it
Argh...
Thanks again for all your help
Nemesh
Post by Nemesh »
If you can do it yourself: Buy a Pioneer BDR-209 DBK or 212.
For the BDR-212 is a newer firmware.
The firmwares for the Pioneer can be downloaded here: https://pioneer.jp/device_e/product-e/i ... 01r_e.html
I am using Pioneers now for 15 years.
First for DVD's and now for BD's.
Trust me, they are great.
I am using Omega Freestyle BD25 & BD50 to write to.
Don't know if you can buy them in your country.
With regards,
Nemesh
modmoomita
Post by modmoomita »
Just buy new BD burner and BD-R (CMC media are reliable enough) from AliExpress in China, they are not that expensive. I use LG burners and they have been good for me for at least 3-4 years before they drop dead but I never buy used ones though.
And I try not to update firmware as it always comes with newer limitations on the drive.
PS. Power Calibration Error often means that the burner has been through a lot and it's dead.
