Please help Bluray crash to main menu
eryoung2k
Post by eryoung2k »
Purchased a Pioneer BDR-XD07B Bluray burner, trying to make playable Blu rays in my player. Have made a few successful ones but have been making nothing but coasters lately (like 10 of them!) Haven't installed any software since purchasing ConvertXtoHD. Every time I make one it load up in my blu ray player and computer (using VLC and Cyberlink) when I press play it just dumps to the main menu of the disc? I have uninstalled and reinstalled many times. Also no subtitles checked in settings.
:crash_log='C:\Users\eryou.000\AppData\Roaming\VSO\ConvertXtoHD\3\Log\ConvertXtoHD 3_crashlog.20200124.133828.359.log'
:library=false
:app_name=ConvertXToHD.exe
:app_version=3.0.0.71
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
15:33:25.325 Info Disc name: "Contagion"
15:16:02.036 Info Burned folder: "C:\Users\eryou.000\Documents\ConvertXtoHD\Contagion", Min. media size 12.9 GB.
15:16:01.594 Info Conversion completed in 01:36:29
13:39:32.458 Info [ ] Loop playback
13:39:32.457 Info [ ] Play titles one after the other
13:39:32.456 Info [x] Don't create title menu for single video
13:39:32.455 Info [ ] Return to title menu after titleset playback
13:39:32.454 Info [ ] Skip root menu initially
13:39:32.453 Info [ ] Auto-start playback
13:39:32.453 Info Template: Metallic (open style), contains 4 page(s)
13:39:32.453 Group Blu-ray/AVCHD menu options
13:39:32.452 Info Output target size : BD-25 (23000 MB)
13:39:32.451 Info Number of core(s) used for encoding : 8
13:39:32.450 Info Number of core(s) used for decoding : 8
13:39:32.449 Info [x] Use 2 pass encoding
13:39:32.448 Info [ ] Use best video quality settings
13:39:32.447 Info [x] Use hardware encoding (if possible)
13:39:32.447 Info [x] Use hardware decoding (if possible)
13:39:32.446 Info Max simultaneous conversions: 4
13:39:32.446 Group Advanced encoding options
15:15:59.215 ------------ *****************************************File encoded successfully: 00000.m2ts******************************************
15:15:59.206 Info "SETTINGS 1/1 (Global 8/8)" menu built successfully
15:15:22.788 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
15:15:22.621 Info "CHAPTERS 6/6 (Global 7/8)" menu built successfully
15:13:59.799 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
15:13:54.983 Info "CHAPTERS 5/6 (Global 6/8)" menu built successfully
15:12:25.295 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
15:12:17.423 Info "CHAPTERS 4/6 (Global 5/8)" menu built successfully
15:10:47.058 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
15:10:38.253 Info "CHAPTERS 3/6 (Global 4/8)" menu built successfully
15:09:02.080 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
15:08:53.883 Info "CHAPTERS 2/6 (Global 3/8)" menu built successfully
15:07:28.973 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
15:07:21.688 Info "CHAPTERS 1/6 (Global 2/8)" menu built successfully
15:05:56.642 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
15:05:52.247 Info "ROOT 1/1 (Global 1/8)" menu built successfully
15:05:00.460 Info H264 settings for stream #1: codec=h264,width=1920,height=1080,dar=16/9,user_b=12000000,bt=12000000,maxrate=40000000,threads=2,preset=superfast,time_base=1/24,g=24,fake_interlaced=0,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,slices=4,refs=4,bf=3,bufsize=30000000,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=12000000,pixel_format=yuv420p
15:04:58.682 Important Starting BD root menu encoding: [Memory load 21%] [Available virtual memory 3401 Mb.]
15:04:58.679 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Metallic (open style)
15:04:58.376 Info subtitle #3 - Encoded subtitles frames: 89
15:04:58.374 Info video #1 - Processed video frames: 153088 (153090 frames encoded, 0 frames dropped, 3 frames duplicated)
13:39:33.186 Warning [muxer][bd]: Using AVStream.codec.time_base as a timebase hint to the muxer is deprecated. Set AVStream.time_base instead.
13:39:33.100 Error [encoder][h264_nvenc]: Error when opening NVENC encoder
13:39:32.902 Warning [encoder][h264_nvenc]: Nvidia graphic card selected for NVENC: #0 NVIDIA GeForce GTX 660M
15:04:58.369 Group FFmpeg encoder Log
13:39:33.102 Info H264 settings for stream #1: preset=superfast,qmin=-1,lmin=118,mblmin=118,b=16000000,bt=50M,maxrate=40000000,minrate=0,me_method=epzs,codec=h264_nvenc,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=30000000,rc_init_occupancy=20000000,slices=4,language=en,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,gpu_id=0,qmax=-1,pass_number=1,bitrate_control=multipass_vbr,threads=8
13:39:33.101 Warning Hardware encoder failed to initialize, will use software encoder for the remaining encodings
13:39:32.900 Info H264 settings for stream #1: preset=superfast,qmin=-1,lmin=118,mblmin=118,b=16000000,bt=50M,maxrate=40000000,minrate=0,me_method=epzs,codec=h264_nvenc,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=30000000,rc_init_occupancy=20000000,slices=4,language=en,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,gpu_id=0,qmax=-1,pass_number=1,bitrate_control=multipass_vbr,threads=8
13:39:32.897 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [English]]
+-[subtitle #3 - mov_text subtitle]
+--> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch., 640000 bps [English]]
+-[audio [eng] ac3 main audio 6 Ch. 48000Hz , 640 Kbps]
+--> [video #1 - h264_nvenc video, 1920x1080, yuv420p, 16x9, 23.98Fps, 16000Kbps]
+-[video dxva2 [eng] h264 1920x1080 16:9 dxva2_vld, 23.98Fps, 4499Kbps ]
Output file: C:\Users\eryou.000\Documents\ConvertXtoHD\Contagion\BDMV\STREAM\00000.m2ts (Blu-ray)
Input file: D:\Movies\Contagion.2011.mp4
Video filters used:
- DeInterlace filter: VSO
13:39:32.896 Info Chapters to generate: 36 (0h00m00s, 0h04m33s, 0h07m26s, 0h11m08s, 0h14m20s, 0h16m01s, 0h17m44s, 0h20m15s, 0h22m23s, 0h24m11s, 0h26m55s, 0h30m31s, 0h34m17s, 0h36m35s, 0h38m40s, 0h41m28s, 0h42m51s, 0h46m55s, 0h49m49s, 0h52m00s, 0h53m57s, 0h57m30s, 1h00m54s, 1h03m22s, 1h07m42s, 1h10m21s, 1h12m34s, 1h15m35s, 1h18m10s, 1h22m34s, 1h25m23s, 1h31m28s, 1h34m35s, 1h36m10s, 1h38m28s, 1h41m28s, )
13:39:32.895 Important Starting video encoding: [Memory load 21%] [Available virtual memory 3441 Mb.]
13:39:32.841 Info Hardware decoding: H.264 variable-length decoder, no film grain technology using Adapter #0 - NVIDIA GeForce GTX 660M, converting h264 to yuv420p
13:39:32.468 Verbose FFmpeg Opening file D:\Movies\Contagion.2011.mp4
13:39:32.842 Info [decoder][h264]: Hardware decoding: H.264 variable-length decoder, no film grain technology using Adapter #0 - NVIDIA GeForce GTX 660M, converting h264 to yuv420p
13:39:32.842 Error [decoder][h264]: no frame!
13:39:32.520 Info [decoder][mjpeg]: Single field
13:39:32.520 Warning [demuxer][mov,mp4,m4a,3gp,3g2,mj2]: Stream #2: not enough frames to estimate rate; consider increasing probesize
13:39:32.511 Error [decoder][h264]: no frame!
13:39:32.511 Critical [decoder][mjpeg]: No JPEG data found in image
13:39:32.510 Warning [demuxer][mov,mp4,m4a,3gp,3g2,mj2]: stream 0, timescale not set
13:39:31.648 Info [decoder][mjpeg]: Single field
13:39:31.648 Warning [demuxer][mov,mp4,m4a,3gp,3g2,mj2]: Stream #2: not enough frames to estimate rate; consider increasing probesize
13:39:31.639 Error [decoder][h264]: no frame!
13:39:31.639 Critical [decoder][mjpeg]: No JPEG data found in image
13:39:31.638 Warning [demuxer][mov,mp4,m4a,3gp,3g2,mj2]: stream 0, timescale not set
13:39:31.653 Group FFmpeg Decoder: "D:\Movies\Contagion.2011.mp4"
13:39:31.651 Warning Stream 0, mjpeg not found in D:\Movies\Contagion.2011.mp4
13:39:31.597 Verbose FFmpeg Opening file D:\Movies\Contagion.2011.mp4
13:39:31.595 Group ******************** Titleset #1 - ~106 min. File: "Contagion" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
13:39:31.592 Info Encoding options: Very short Project (Automatic)
13:39:31.592 Info Target size: 23000 Mb.
13:39:31.591 Important Setting queuer for Blu-ray output: [Wait: 4000], [ld: 1000], [Hd: 10000], [MAM: 600], [RM: 500], [ALL: True]
13:39:31.590 Info Don't log FFMpeg log events
13:39:31.589 ------------ ***************************************************Burn settings end****************************************************
13:39:31.588 Info Default speed selected: 6x
13:39:31.588 Info [ ] Delete vsomsl files after burn complete
13:39:31.587 Info [ ] Delete output folder after burn complete
13:39:31.586 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
13:39:31.586 Info SAO setting: Automatic
13:39:31.585 Info [x] Burn result to disk / as ISO file in working folder
13:39:31.584 ------------ **************************************************Burn settings begin***************************************************
13:39:31.584 Group Encoding session started at 1:39:31 PM: 1 titleset(s) to encode -> Completed in 01:36:29|GK_CONVERT_SESSION|
13:38:47.070 Important Loaded with result [File ]
13:38:46.425 Info Loading: "D:\Movies\Contagion.2011.mp4 - File" 1/1
13:38:46.212 Info Sources filtered, found 1 protocols
13:38:45.785 Info Added protocol D:\Movies\Contagion.2011.mp4, candidate 1/1
13:38:45.556 Info Found 1 candidates
13:38:45.054 Info Filtering sources
13:38:45.054 Group Loading file(s)
13:38:34.541 Info Personnal resources size (C:\Users\eryou.000\Documents\ConvertXtoHD_Resources\): 0MB, 0 file(s)
13:38:34.322 Info Monotonizer size (C:\ProgramData\vso\vsomsl): 0MB, 0 file(s)
13:38:34.104 Info Thumb cache size (C:\ProgramData\VSO\vsothumbs): 2MB, 1 file(s)
13:38:33.884 Info Logs and templates size (C:\ProgramData\VSO\ConvertXtoHD\3\): 74MB, 665 file(s)
13:38:33.641 Group Folder data
13:38:33.632 Info Menu templates loaded: 20
13:38:32.292 Info License status: active customer license
13:38:32.291 Info License type: commercial (online activated)
13:38:32.291 Info Computer ID: 109072
13:38:32.291 Group License
13:38:28.930 Info Loading templates from: "C:\Users\eryou.000\Documents\ConvertXtoHD_Resources\Templates\"
13:38:28.929 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoHD\3\Templates\"
13:38:28.923 ------------ ***************************ConvertXToHD.exe:5196 Log session start 2020-01-24 at 13:38:27.250***************************
15:32:51.902 Info Disc (bd-r sequential recording) not empty.
15:32:45.650 Info Parsing disc ...
15:31:07.104 Info WRITE SUCCESS: Disc written
15:31:00.577 Info Burning process completed successfully.
15:31:00.563 Info Finalization Time 00:00:15.569 - Total completion time 00:14:39.957
15:31:00.550 Info Finalize: Finalisation completed
15:31:00.533 Info Finalize: Close disc - Completed
15:30:51.817 Info Finalize: Start Close media
15:30:51.795 Info Finalize: Close session - Completed
15:30:49.217 Info Finalize: Start Close session
15:30:49.192 Info Finalize: Close track - Completed
15:30:46.627 Info Finalize: Start Close track
15:30:46.606 Info Finalize: Flush device cache - Completed
15:30:45.031 Info Finalize: Flushing burner cache
15:30:44.991 Info Write finished in 00:14:24.389 - Finalization start here. Avg. burn rate 3.55
15:30:44.981 Info Finalize: Start disc finalisation
15:16:43.631 Info WRITING: Lead-in burning time required 00:00:23.031
15:16:20.600 Info Write started 6742880 sectors to write
15:16:20.593 Info Init BD-R: Success
15:16:20.577 Info Write speed set at x6.0 (26970 kB/s)
15:16:20.543 Info Available write speed: x6.0 (26970 kB/s) *, x4.0 (17980 kB/s), x2.0 (8990 kB/s)
15:16:20.537 Info Media ID: VERBAT-IMe-7D
15:16:20.351 Info Scanned files #82, folder #16 - total size 13807447039 b. (12.9 GB.)
15:16:20.344 Info Inserted media type : bd-r sequential recording
15:16:20.327 Info Volume ID: Contagion
15:16:20.322 Info Folder: C:\USERS\ERYOU.000\DOCUMENTS\CONVERTXTOHD\CONTAGION\
15:16:20.316 Info Write started
15:16:19.124 Info Blu-ray/AVCHD structure burn process started
15:16:04.196 Info Writable disc bd-r sequential recording inserted. Ready to write
15:16:02.122 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu-Ray-R, Blu-Ray-RE (V1), Blu-Ray-RE (V2)
15:16:02.121 Info Drive has Serial ATA physical interface
15:16:02.120 Info New Drive selected : [G] PIONEER BD-RW BDR-XD07 1.02 (USB)
13:38:28.916 Info 2 writer(s) found.
13:38:28.360 Group Burn engine events
Video filters used:
eryoung2k
Re: Please help Bluray crash to main menu
Post by eryoung2k »
Okay so I think I fixed it on my own I shut off Hardware encoding put it back to Software and I've made three perfect Blu-ray movies looks like I'm all set!
Thanks for the solution!
Will help if somebody suffers from the same issue.
Cheers,
