Audio drop outs with MLP FBA 16-ch
dosibo51
Post by dosibo51 »
I just got the 2nd blu-ray with this audio format - BLACKkKLANSMAN ..
When I remux video (h264) and audio into .m2ts
  • VLC (3.0.4/6) plays without any problems.
  • JR Media Center 24.0.75 player (also) has permant audio drop outs.
  • VSO blu-ray converter - advanced edit also has audio drop outs (player).
Finally when I try to convert audio to AC3 - also audio drop outs on the final .m2ts result (incl. VLC of course).
Would be fine if a fix (convert audio to AC3) would be available sooner or later.
Code: Select all
Audio #1
Menu ID                                  : 1 (0x1)
Format                                   : MLP FBA 16-ch
Format/Info                              : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name                          : Dolby TrueHD with Dolby Atmos
Codec ID                                 : 131
Duration                                 : 2 h 15 min
Bit rate mode                            : Variable
Maximum bit rate                         : 4 428 kb/s
Channel(s)                               : 8 channels
Channel layout                           : L R C LFE Ls Rs Lb Rb
Sampling rate                            : 48.0 kHz
Frame rate                               : 1 200.000 FPS (40 SPF)
Delay relative to video                  : -1 ms
Language                                 : German
Number of dynamic objects                : 11
Bed channel count                        : 1 channel
Bed channel configuration                : LFE
Audio #2
Menu ID                                  : 1 (0x1)
Codec ID                                 : 131
Delay relative to video                  : 1 s 978 ms
Language                                 : German
Re: Audio drop outs with MLP FBA 16-ch
Hi there,
Could you please send me the file you used so I can try to reproduce this bug?
To: support@vsosoftware.fr
Cheers!
