Menu Customization
Goodgold1987
Menu Customization
Post by Goodgold1987 »
Trying to make a BluRay with a menu that will allow me to play videos in two ways. For instance, I want a play all button. But I also want a button that will play videos in a different order or even just skip videos if wanted. Is this possible?
Re: Menu Customization
There is a option to play all videos, see screenshot bellow.
I am not sure I understand your second request. Different order or skip videos?
You can directly change the order before convert/burn with ConvertXtoHD, just drag&drop the file in the order you want them to be played.
As regards skipping videos it won't be possible unless you go back to the menu and play the next one, manually.
Hope it helps!
Cheers,
