Localiation Editor - Impossible to connect to the repository
bovirus
Post by bovirus »
Hello.
I have a big problem with Localisation Editor.
The problem is very simple (tested on two fiber FTTC connection at office with consumer line and in my home).
Then I ran Localisation Editor (ex. for many VSO sofwtare) and click on Online Repository.
Then I used also
my profile (user/password)
editloc (as user) just to test reading option
I got always an error that it’s impossible to connect to the repository.
It report some suggestion like open port 3306/ check library file/etc.
Note: Please take care until one month ago I didn’t get this error and nothing is changed about connection.
Re: Localiation Editor - Impossible to connect to the reposi
Hi bovirus,
Sorry for the delay.
Please send me a message to support@vsosoftware.fr if your issue is still happening.
I'll try to sort this out with you.
Cheers,
bovirus
Post by bovirus »
Hello.
I received an information that in a near future the update about application can get directly by the app.
Now the repository for translator is active?
Yes, it is!
Please send us your user name to support@vsosoftware.fr
Thanks!
