re thumbnails
reddwarf4ever
re thumbnails
Post by reddwarf4ever »
[attachment=0]convertx2dvd.png[/attachment]
Posted this problem before , but need to try and make my point clear..
I the video episode creator there is an option to change the start time (a) and duration (b) of each thumbnail PLUS the padding method
If I aet the first thumbnail to e.g. 50 seconds (a) and 30 seconds (b) then apply to all titles it actually DOES change all the thumbnails...BUT if i then change ( a ) and ( b ) of an individual thumbnail and click apply to all titles it does not change the others.....Curious ???
Also the padding method also needs an Apply to all titles ( thumbnails) as if i change a thumbnail to pan & scan I would like all the thumbnails to be pan & scan....there is no logical reason to have one thumbnail to pan & scan another to stretch and another to user setting etc etc.........
Hope you can help in this matter
Re: re thumbnails
reddwarf4ever wrote: I the video episode creator there is an option to change the start time (a) and duration (b) of each thumbnail PLUS the padding method
I cannot reproduce with 7.0.0.40
reddwarf4ever wrote:Also the padding method also needs an Apply to all titles ( thumbnails) as if i change a thumbnail to pan & scan I would like all the thumbnails to be pan & scan....there is no logical reason to have one thumbnail to pan & scan another to stretch and another to user setting etc etc.........
I've entered this as a feature request here
http://bugs.vso-software.fr/view.php?id=13101
reddwarf4ever
Re: re thumbnails
Thanks.....this would be a great feature....
Still have problems in conversion of long episode projects.....sometimes just gets stuck, the timer at several hours and doesn't go down, so I terminate it.....or get exception error ( this happens less when the source files HDD and target HDD are different.....
Tried safe mode and seems to fail less....one point is if I use the pc for anything or pause convertx2dvd then resume, this seems to cause a failure...
So try to leave the pc alone whilst converting
Re: re thumbnails
reddwarf4ever
Re: re thumbnails
Thank you so much
Will download and try
