I have a dvd where the second episode jumps part way through, just near the begiining, the screenh goes black for a few seconds then continues, missing some of the playback.
if i copy the video folder to my PC i can play this VOB file perfectly, but only plays up on a dvd player...
is there a way to repair or convert and convert back that may fix this
thanks
re playback problem
Re: re playback problem
Do you get same problem if you burn to new DVD?
If not, then it was media issue.
reddwarf4ever
Yes tried several disks, same issue
the vob file you mention here is the output created by ConvertXtoVideo? or the input?reddwarf4ever wrote: if i copy the video folder to my PC i can play this VOB file perfectly, but only plays up on a dvd player...
You can post your log file that would be helpful, you can find them here
C:\ProgramData\VSO\ConvertXtoVideo Ultimate\2\Log
reddwarf4ever
The input....
It's not an issue with cxtodvd
Don't think this program can help me with this issue
