Problem with remux
skypilotpete
Problem with remux
Post by skypilotpete »
I have been converting all my DVD to mkv files, using the "full remux" settings. I have converted many DVDs without any problems. However, ConvertXtoVideo seems unable to cope with one particular DVD and I cannot work out why this is happening. Usually when remuxing a DVD the resulting mkv file is around the same size as the DVD. However, with this problem DVD, remuxing a 3.33GB DVD results in a 1.5 GB mkv file. The file is unusable, as the whole thing is totally pixelated and no detail can be seen at all. I have played the original DVD on several players without any problems. I have tried playing the mkv file using a number of different players (VLC, Media player classic, Windows media player) and none of them can handle it. I have done a file conversion (rather than remux) using Handbrake, and that converts the DVD without any issues. I have also converted the DVD using ConvertXtoVideo using the "Mkv (H264 + AC3) profile, and that works fine, producing a 3.1GB file that plays perfectly.
Can anyone think of a reason that the full remux option is not working? I run Windows 7 64, ConvertXtoVideo Untimate 2.0.0.60 (I have also tried the latest beta version 2.0.0.63, and that is also unable to correctly remux the DVD.)
The video specs in MediaInfo for the DVD .vob files are as follows:
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=5, N=26
Duration : 30mn 17s
Bit rate mode : Variable
Bit rate : 4 439 Kbps
Maximum bit rate : 6 300 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 2.40:1
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.428
Time code of first frame : 10:00:00:00
Time code source : Group of pictures header
Stream size : 962 MiB (94%)
Color primaries : BT.601 PAL
Transfer characteristics : BT.470 System B, BT.470 System G
Matrix coefficients : BT.601
Re: Problem with remux
I have no idea. We'd need the source to investigate further.
