ConvertxToHD - Audio Out Of Sync
Nemesh
Post by Nemesh »
I have recorded some video with m yHMumax 5200C settop box en tried to create a Blu-Ray disc from it.
Source is 1080i with Dolby 5.1/2.0 and subtitle for deaf and hearing impaired.
I create the menu etc. and make a BD50 compliand disc and let ConvertxToHD make a .ISO file.
Then I load the .iso file in PowerDVD 16.
The disc starts and I select Dolby Digital 5.1. and subtitle for the Deaf and Hearing Impaired.
I am not deaf of hearing impaired, but I want to know if the subtitle works.
The moment I press the play button I hear audio from the show but there is no video.
When the video starts, it's not at the beginning but several seconds later and when he speaks it clear to see that the audio is out of sync.
I can't get it to work properly.
I also tested the .iso with my Popcornhour C-200 and Mede8er-X800 and they had the same problem.
Version used: ConvertXtoHD 2.0.0.80
However when I load the .ts file in the Windows Media Player it playes fine.
Also the Popcornhour and the Mede8er will play the .ts files fine.
I did send a personal message to Claire with extra information but still haven't got a reply.
With much regards,
Nemesh
Nemesh
Re: ConvertxToHD - Audio Out Of Sync
Post by Nemesh »
Nobody can help me with this ?
I just replied now to your PM by email.
Fixing this will depend on having the source file most likely.
We will look into the problem.
Nemesh
Post by Nemesh »
Hello Claire,
I everything went okay, you should have the file.
With much regards,
Nemesh
felicia
Post by felicia »
Available beta version should fix this issue.
It can be found here: http://forums.vso-software.fr/cxtohd-be ... 18951.html
Br,
Felicià
Nemesh
Post by Nemesh »
Hello Felicia,
Have installed the latest version 2.0.0.90
After today I will have three days off from work and I will start testing.
Give you my best regards,
Nemesh
