convertX to DVD vs convertXto HD
stealle
Post by stealle »
Is there a table that shows a side by side comparison of the various vso products? It looks to me like convertX to HD can do everything that convertX to DVD can do. Only difference I can see is that convertx to hd can also burn to bluray. So it seems like it can do more only it cost $5 less. I'm sure I am missing something...
Re: convertX to DVD vs convertXto HD
https://www.vso-software.fr/guides/converter-review.php
ConvertXtoDVD only converts to DVD
ConvertXtoHD converts to various resolutions including HD and creates the output structures Blu-ray (to be burnt onto Blu-ray disks with a blu-ray burner) and AVCHD structure (HD to be burnt on DVD) . . . also supports AVCHD USB compatible
