Even when the files are removed from ConverXtoVideo, after a conversion, they cannot be deleted until ConvertXtoVideo is closed.
Anyone else seeing this, or should I uninstall and reinstall again?
Anyone else experiencing locking errors with B47
Dirkmaster
Re: Anyone else experiencing locking errors with B47
A new beta version is out: http://forums.vso-software.fr/convertxt ... 18977.html
Dirkmaster
Yes, indeed. B49 fixes it. Thanx Cedric, you're the best!
Thank you for your initial report and your (positive) feedback!
