Bugs in v2.0.0.40: Button "wrong" in hardware optimizations
mue.mat
Post by mue.mat »
Hello
There are 2 bugs in new version 2.0.0.40:
1. On/off-Button in settings for hardware optimizations is not working fine (doesn't turn to green when on)
2. Again framerate is not correct when converting to BluRay 1080p (f.e. original framerate: 25; adapted framerate: 24)
Both above mentioned are working fine in previous version 2.0.0.39.
mue.mat
Re: Bugs in v2.0.0.40: Button "wrong" in hardware optimizati
Did you checked the output file, or did you only see that in hint?
mue.mat
Post by mue.mat »
No, I didn't check the output file. I even didn't convert because of the indicated wrong framerate.
mue.mat
