Error-PGC Position
Blade Runner
Error-PGC Position
Post by Blade Runner »
Using DVD Converter v3.6.0.47 to convert ISO image to mkv and the following error message appeared: PGC position (66496) is invalid.
Program freezes. Suggestions?
Re: Error-PGC Position
Try with 4.0.0.7
http://forums.vso-software.fr/dvd-conve ... 18563.html
If the problem continues post your log file here and the name of the movie.
Are you sure the file is correctly decrytped? Maybe try ripping to your hardd rive first and then loading and converting in our software.
