ConvertXtoVideo v1.6.0.42 - Crashing with GPU Cuda Encoding
mue.mat
Post by mue.mat »
Hello
Once again, ConvertXtoVideo v1.6.0.42 is crashing while using GPU Cuda encoding with multiple video files (5 video files at once, each one resolution of 1080p, mkv, 45 min).
In former versions Cuda encoding was possible up to 10 similar video files with the same resolution.
I hope for help...
mue.mat
Re: ConvertXtoVideo v1.6.0.42 - Crashing with GPU Cuda Encod
Are you still having this problem with the latest beta version?
If you go back to an older version can you do more than 5 videos at once?
Old versions can be found here
http://www.afterdawn.com/software/audio ... r.cfm#tab3
mue.mat
Post by mue.mat »
Hello
No, I have changed to v2. Everything is working fine. Thanks.
mue.mat
ok thanks for the followup!
