Timestamp
Keith
Timestamp
Post by Keith »
When converting a video it adds the date stamp, which is not visible before conversion
https://www.youtube.com/watch?v=85-wN3WRcHo
Re: Timestamp
Is this a feature you want?
Currently our software does not add any such things to the video.
Re: Timestamp
Hello Keith,
Did you posted the conversion result or your original file on YouTube?
ConvertXtoVideo never add a timestamp watermark, but your camcorder can add a subtitle track with this type of timestamp.
Can you check if a subtitle track is selected before starting the conversion?
Keith
Re: Timestamp
Post by Keith »
I would prefer the choice
This is a video using the same camera and settings, without using the converter there is no timestamp
https://www.youtube.com/watch?v=Vt8uVsZ ... e=youtu.be
The converter is very useful for youtube etc as it reduces the file size considerably
Keith
Re: Timestamp
Post by Keith »
Just converted a video from a different camera and no timestamp was added so maybe it is the other camera settings?
Re: Timestamp
Please reload your original file : https://www.youtube.com/watch?v=85-wN3WRcHo then unselect any subtitle track then start the conversion...
Keith
Re: Timestamp
Post by Keith »
Hello Cedric
That works
https://www.youtube.com/watch?v=Ls4XylaFGGE
Thank You for solving this so quickly
Re: Timestamp
Thank you for your feedback...
