Feature Request
Budda_357
Feature Request
Post by Budda_357 »
Hi Guys
Is there antway of adding an import to CX2V Ultimate option to the conversion field?
Budda [sic]
From Down Under
My All-rounder Rig
CPU
: I7-2600K @ 4.6 GHZ
RAM: Corsair 16 Gig DDR3 1866
HDD: 11TB
Network & BU Thecus N5550
Re: Feature Request
Are you saying currently if Convert to "other formats" is selected you suggest it be opened automatically and the files loaded, so that all you need to do is select the conversion profile and press convert?
Benjamin
Re: Feature Request
Post by Benjamin »
yes we will open CX2V if you click more format and it is installed:
http://bugs.vso-software.fr/view.php?id=10402
