Latest version 1.6.0.4 : something to fix
JEMA
Post by JEMA »
Version 1.6.0.4. Nice program but there is an important problem. It's not possible anymore to copy an audio track in HD (DTS HD MA for instance).
I make for example a custom profile in MKV. In step 3 (audio tracks), I choose for "Copy (remux if possible ..." (put a little "v").
It doesn't work : the final result is that the audio track looses in any cases his HD : it becomes normal AC3 or DTS without HD and if the track is in 7.1, it becomes 5.1 whatever I do.
In (and till) version 1.5.0.36, there was no problem to copy an audio track in DTS HD MA. Has someone else observed the same problem? I hope it will be fixed as soon as possible.
Thank you very much and congratulations to the whole VSO-team.
Re: Latest version 1.6.0.4 : something to fix
thanks for reporting will be fixed in the next version
http://bugs.vso-software.fr/view.php?id=9798
Hello JEMA,
Do you have this problem when trying to remux a 6 channels DTS HD-MA (not 8 channels)?
Thank you for reporting back.
JEMA
Post by JEMA »
Yes, I have the same problem : all audio tracks in DTS HD become automatically DTS "without" HD. It has become impossible to copy an HD audio track unchanged.
It should be fixed now in this beta version
http://forums.vso-software.fr/latest-co ... 18615.html
