Conversion is IMPOSSIBLE
Zenophobe
Post by Zenophobe »
Trying to put 1 hour 1080p mkv episodes on a blu ray disk. Says Conversion is IMpossible with both 1.0.0.44B and 1.0.0.43. Idea's around the 16k bit rate issue?
Zenophobe
Re: Conversion is IMPOSSIBLE
Post by Zenophobe »
these files are hit bit rate files 16k and up. If i use smaller bit rate files I do not seem to have an issue.
It is the conversion advisor that says impossible?
What if you change the target size?
