Error while encoding file: 00000.m2ts
Does anyone know how to fix this error? I get this error before the conversion process even begin. Below are the logs, I tried this with two different video files. I was able to convert these files fine when using convertxtoHD on a different computer, I don't know why it's not working with this computer.
Thank you.
:crash_log='C:\ProgramData\VSO\ConvertXtoHD\1\Log\ConvertXtoHD 1_crashlog_.20150321.125722.869.log'
:library=false
:app_name=ConvertXtoHD.exe
:app_version=1.0.0.41
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
12:57:31.651 Error Error while encoding file: 00000.m2ts
12:57:31.551 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [un]]
+-[subtitle #2 - ssa subtitle]
+--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [un]]
+-[audio aac main audio 2 Ch., 48000 Hz, 0 Kbps]
+--> [video #1 - h264 video, 1920x1080, yuv420p, 16x9, 23.98Fps, 24800 Kbps [en]]
+-[video [eng] h264 848x480 53:30 yuv420p, 23.98 fps, 0 Kbps]
Output file: H:\ConvertXtoDVD\Baka to Test to Shokanjuu 01\BDMV\STREAM\00000.m2ts (Blu-ray)
Input file: H:\Anime\Baka Test\Baka to Test to Shokanjuu 01.mkv
Video filters used:
- DeInterlace filter: FFmpeg
- Scale filter: fast linear (vso). Fit method: letterbox (Padding: top: 0, bottom: 0, left: 6, right: 6. Cropping: top: 0, bottom: 0, left: 0, right: 0)
12:57:31.549 Info Chapters to generate: 5
12:57:31.484 Info Added in conversion queue list...
12:57:31.427 Group ******************** Titleset #1 - ~24 min. File: "Baka to Test to Shokanjuu 01" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
12:57:31.426 Info Encoding options: Short Projects (Automatic)
12:57:31.425 Info Target size: 22.5 Gb.
12:57:31.250 Info Don't log FFMpeg log events
12:57:29.768 ------------ ***************************************************Burn settings end****************************************************
12:57:29.767 Info Default speed selected: 4x
12:57:29.766 Info [ ] Delete vsomsl files after burn complete
12:57:29.765 Info [ ] Delete output folder after burn complete
12:57:29.764 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
12:57:29.763 Info SAO setting: Automatic
12:57:29.762 Info [x] Burn result to disk / as ISO file in working folder
12:57:29.761 ------------ **************************************************Burn settings begin***************************************************
12:57:29.761 Group Encoding session started at 12:57:29 PM: 1 titleset(s) to encode|GK_CONVERT_SESSION|
12:57:29.078 Info #1 [eng] h264 848x480 53:30 yuv420p, 23.98 fps, 0 Kbps
12:57:29.065 Group Video streams
12:57:29.077 Info #2 aac main audio 2 Ch., 48000 Hz, 0 Kbps - Unspecified
12:57:29.065 Group Audio streams
12:57:29.076 Info #3 0:0:2 - ssa 720x576 - Unspecified
12:57:29.065 Group Subtitle streams
12:57:29.075 Warning DISCARDED #4 -
12:57:29.075 Warning DISCARDED #5 -
12:57:29.074 Warning DISCARDED #6 -
12:57:29.074 Warning DISCARDED #7 -
12:57:29.073 Warning DISCARDED #8 -
12:57:29.072 Warning DISCARDED #9 -
12:57:29.072 Warning DISCARDED #10 -
12:57:29.071 Warning DISCARDED #11 -
12:57:29.071 Warning DISCARDED #12 -
12:57:29.070 Warning DISCARDED #13 -
12:57:29.070 Warning DISCARDED #14 -
12:57:29.069 Warning DISCARDED #15 -
12:57:29.068 Warning DISCARDED #16 -
12:57:29.067 Warning DISCARDED #17 -
12:57:29.066 Warning DISCARDED #18 -
12:57:29.066 Warning DISCARDED #19 -
12:57:29.065 Warning DISCARDED #20 -
12:57:29.065 Group Discarded streams
12:57:29.065 Group Added file: H:\Anime\Baka Test\Baka to Test to Shokanjuu 01.mkv
12:57:24.609 Info Menu templates loaded: 36
12:57:23.578 Info Total Physical Memory : 8145 Mb.
Available Physical Memory : 5683 Mb.
Memory Load : 30%
Available Virtual Memory : 3797 Mb.
Total Memory : 16289 Mb.
Available Memory : 13598 Mb.
12:57:23.577 Info Processor Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz with 4 core(s) CPU
Supported instruction set: MMX,sse,sse2,sse3,ssse3,sse41,sse42,avx,aes
12:57:23.571 Info OS : Windows 7 (64 bits), Build 7600, service pack 0.0
file name : C:\Program Files (x86)\VSO\ConvertXtoHD\1\ConvertXtoHD.exe
file version : 1.0.0.41
12:57:22.884 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoHD\1\templates"
12:57:22.883 ------------ ***************************ConvertXtoHD.exe:1256 Log session start 2015-03-21 at 12:57:22.659***************************
12:57:22.882 Info 1 writer(s) found.
12:57:22.865 Group Burn engine events
:crash_log='C:\ProgramData\VSO\ConvertXtoHD\1\Log\ConvertXtoHD 1_crashlog_.20150321.125751.212.log'
:library=false
:app_name=ConvertXToHD.exe
:most_recent=first
:status=started
:group_indent=4
12:58:13.748 Error Error while encoding file: 00000.m2ts
12:58:13.627 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [un]]
+-[audio aac main audio 2 Ch., 44100 Hz, 0 Kbps]
+--> [video #1 - h264 video, 1920x1080, yuv420p, 16x9, 23.98Fps, 24800 Kbps [un]]
+-[video h264 1280x720 16:9 yuv420p, 23.98 fps, 0 Kbps]
Output file: H:\ConvertXtoDVD\[HorribleSubs] Akame ga Kill! - 01 [720p]\BDMV\STREAM\00000.m2ts (Blu-ray)
Input file: H:\Anime\Akame ga Kill! [HorribleSubs]\[HorribleSubs] Akame ga Kill! - 01 [720p].mkv
Video filters used:
- Scale filter: fast linear (vso). Fit method: letterbox (Padding: top: 0, bottom: 0, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
12:58:13.625 Info Chapters to generate: 5
12:58:13.578 Info Added in conversion queue list...
12:58:13.527 Group ******************** Titleset #1 - ~23 min. File: "[HorribleSubs] Akame ga Kill! - 01 [720p]" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
12:58:13.526 Info Encoding options: Short Projects (Automatic)
12:58:13.525 Info Target size: 22.5 Gb.
12:58:13.490 Info Menu fit: Text size reduced from 32.00 to 31.00 in style "caption"
12:58:13.482 Info Menu fit: Text size reduced from 39.00 to 37.00 in style "title"
12:58:13.336 Info Don't log FFMpeg log events
12:58:13.334 ------------ ***************************************************Burn settings end****************************************************
12:58:13.333 Info Default speed selected: 4x
12:58:13.332 Info [ ] Delete vsomsl files after burn complete
12:58:13.332 Info [ ] Delete output folder after burn complete
12:58:13.331 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
12:58:13.330 Info SAO setting: Automatic
12:58:13.328 Info [x] Burn result to disk / as ISO file in working folder
12:58:13.327 ------------ **************************************************Burn settings begin***************************************************
12:58:13.327 Group Encoding session started at 12:58:13 PM: 1 titleset(s) to encode|GK_CONVERT_SESSION|
12:57:57.280 Info #1 h264 1280x720 16:9 yuv420p, 23.98 fps, 0 Kbps
12:57:57.278 Group Video streams
12:57:57.279 Info #2 aac main audio 2 Ch., 44100 Hz, 0 Kbps - Unspecified
12:57:57.278 Group Audio streams
12:57:57.279 Info #3 0:0:2 - ssa 720x576 - Unspecified
12:57:57.278 Group Subtitle streams
12:57:57.278 Warning DISCARDED #4 -
12:57:57.278 Group Discarded streams
12:57:57.278 Group Added file: H:\Anime\Akame ga Kill! [HorribleSubs]\[HorribleSubs] Akame ga Kill! - 01 [720p].mkv
12:57:53.023 Info Menu templates loaded: 36
12:57:51.967 Info Total Physical Memory : 8145 Mb.
Available Physical Memory : 5736 Mb.
Memory Load : 29%
Available Virtual Memory : 3796 Mb.
Available Memory : 13596 Mb.
12:57:51.966 Info Processor Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz with 4 core(s) CPU
12:57:51.959 Info OS : Windows 7 (64 bits), Build 7600, service pack 0.0
file name : C:\Program Files (x86)\VSO\ConvertXtoHD\1\ConvertXToHD.exe
12:57:51.229 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoHD\1\templates"
12:57:51.228 ------------ ***************************ConvertXToHD.exe:5612 Log session start 2015-03-21 at 12:57:51.009***************************
12:57:51.227 Info 1 writer(s) found.
12:57:51.208 Group Burn engine events
Thank you.
:library=false
:most_recent=first
:status=started
:group_indent=4
Video filters used:
Memory Load : 30%
:library=false
:most_recent=first
:status=started
:group_indent=4
Video filters used:
Memory Load : 29%
Re: Error while encoding file: 00000.m2ts
I am not sure, you could try with the latest beta version
http://forums.vso-software.fr/latest-cx ... 18560.html
I thought it could be a difference whether you are using hardware encoding or decoding. are these settings different on your other computer? Have you tried with them both off and on?
The file name has the charachter "!" what if you changed the filename to something more basic before loading it in to CXHD and converting it?
Can you play the file in the preview window of CXHD on the computer it doesn't convert in?
Is that file ok?
I've tried burning the same videos on the other computer and they converted perfectly. I was able to review the videos before clicking convert, but gets the error and freeze after clicking convert.
I've checked the 3 settings (clean registry, delete installation and cache files) during installation and unchecked hardware encoding/decoding. The same error " Error while encoding file: 00000.m2ts" still occurs (1st log below) with the beta version.
If I checked "hardware encoding/decoding/allow more than one decoder" , the file will begin to convert, but will always fail at the end of the conversion (2nd log below).
:crash_log='C:\ProgramData\VSO\ConvertXtoHD\1\Log\ConvertXtoHD 1_crashlog_.20150323.052451.269.log'
:library=false
:app_version=1.0.0.42
:most_recent=first
:status=started
:group_indent=4
05:25:15.768 Error Error while encoding file: 00000.m2ts
05:25:15.653 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [un]]
+--> [video #1 - h264 video, 1920x1080, yuv420p, 16x9, 23.98Fps, 16000 Kbps [un]]
Output file: H:\ConvertXtoHD\[HorribleSubs] Akame ga Kill! - 01 [720p]\BDMV\STREAM\00000.m2ts (Blu-ray)
Video filters used:
05:25:15.652 Info Chapters to generate: 5
05:25:15.609 Info Added in conversion queue list...
05:25:15.560 Group ******************** Titleset #1 - ~23 min. File: "[HorribleSubs] Akame ga Kill! - 01 [720p]" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
05:25:15.559 Info Encoding options: Short Projects (Automatic)
05:25:15.558 Info Target size: 22.5 Gb.
05:25:15.533 Info Menu fit: Text size reduced from 32.00 to 31.00 in style "caption"
05:25:15.524 Info Menu fit: Text size reduced from 39.00 to 37.00 in style "title"
05:25:15.406 Info Don't log FFMpeg log events
05:25:15.405 ------------ ***************************************************Burn settings end****************************************************
05:25:15.404 Info Default speed selected: 4x
05:25:15.404 Info [ ] Delete vsomsl files after burn complete
05:25:15.403 Info [ ] Delete output folder after burn complete
05:25:15.402 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
05:25:15.402 Info SAO setting: Automatic
05:25:15.401 Info [x] Burn result to disk / as ISO file in working folder
05:25:15.400 ------------ **************************************************Burn settings begin***************************************************
05:25:15.400 Group Encoding session started at 5:25:15 AM: 1 titleset(s) to encode|GK_CONVERT_SESSION|
05:25:06.322 Info #1 h264 1280x720 16:9 yuv420p, 23.98 fps, 0 Kbps
05:25:06.320 Group Video streams
05:25:06.321 Info #2 aac main audio 2 Ch., 44100 Hz, 0 Kbps - Unspecified
05:25:06.320 Group Audio streams
05:25:06.321 Info #3 0:0:2 - ssa 720x576 - Unspecified
05:25:06.320 Group Subtitle streams
05:25:06.320 Warning DISCARDED #4 -
05:25:06.320 Group Discarded streams
05:25:06.320 Group Added file: H:\Anime\Akame ga Kill! [HorribleSubs]\[HorribleSubs] Akame ga Kill! - 01 [720p].mkv
05:24:52.794 Info Menu templates loaded: 36
05:24:51.982 Info Total Physical Memory : 8145 Mb.
Available Physical Memory : 5305 Mb.
Memory Load : 34%
Available Memory : 13055 Mb.
05:24:51.982 Info Processor Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz with 4 core(s) CPU
05:24:51.975 Info OS : Windows 7 (64 bits), Build 7600, service pack 0.0
file version : 1.0.0.42
05:24:51.284 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoHD\1\templates"
05:24:51.283 ------------ ***************************ConvertXToHD.exe:5484 Log session start 2015-03-23 at 05:24:51.064***************************
05:24:51.281 Info 1 writer(s) found.
05:24:51.264 Group Burn engine events
:std_log='C:\ProgramData\VSO\ConvertXtoHD\1\Log\ConvertXtoHD 1_mainlog_.20150323.053724.950.log'
:library=false
:most_recent=first
:status=stopped
:group_indent=4
05:37:24.941 ------------ ****************ConvertXToHD.exe:3936 Log session stop after 9 minute(s) 14 second(s) 461 millisecond(s)****************
05:37:11.261 Info Conversion failed after 00:08:35
05:28:35.545 Info [ ] Loop playback
05:28:35.544 Info [x] Play titles one after the other
05:28:35.542 Info [x] Don't create title menu for single video
05:28:35.541 Info [x] Return to title menu after titleset playback
05:28:35.540 Info [x] Skip root menu initially
05:28:35.539 Info [x] Auto-start playback
05:28:35.538 Info Template: Black Mirror, contains 4 page(s)
05:28:35.538 Group Blu-ray/AVCHD menu options
05:28:35.536 Info Output target size : BD-25 (23000 MB)
05:28:35.535 Info Number of core(s) used for encoding : 4
05:28:35.534 Info Number of core(s) used for decoding : 4
05:28:35.533 Info [ ] Use 2 pass encoding
05:28:35.532 Info [x] Use best video quality settings
05:28:35.531 Info [x] Use hardware encoding (if possible)
05:28:35.528 Info [x] Use hardware decoding (if possible)
05:28:35.526 Info Max simultaneous conversions: 4
05:28:35.526 Group Advanced encoding options
05:37:10.869 ------------ *****************************************File encoded successfully: 00000.m2ts******************************************
05:37:08.246 Info Menu encoding failed
^^^Repeated 3 Times in 2 second(s) 617 millisecond(s)^^^
05:37:07.993 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Black Mirror
^^^Repeated 2 Times in 1 millisecond(s)^^^
05:37:07.925 Info subtitle #3 - Encoded subtitles frames: 1335
05:37:07.924 Info video #1 - Processed video frames: 34516 (34515 frames encoded, 1 frames dropped, 0 frames duplicated)
05:28:35.988 Info h264: using hardware decoder adapter #0 - NVIDIA GeForce GTX 660 , vendor 0x10DE (NVIDIA), device 0x11C0, revision 161
05:28:35.567 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [un]]
+--> [video #1 - h264_nvenc video, 1920x1080, yuv420p, 16x9, 23.98Fps, 16000 Kbps [en]]
+-[video dxva2 [eng] h264 848x480 53:30 yuv420p, 23.98 fps, 0 Kbps]
Output file: H:\ConvertXtoHD\Baka to Test to Shokanjuu 01\BDMV\STREAM\00000.m2ts (Blu-ray)
Video filters used:
05:28:35.565 Info Chapters to generate: 5
05:28:35.519 Info Added in conversion queue list...
05:28:35.468 Group ******************** Titleset #1 - ~24 min. File: "Baka to Test to Shokanjuu 01" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
05:28:35.466 Info Encoding options: Short Projects (Automatic)
05:28:35.465 Info Target size: 22.5 Gb.
05:28:35.342 Info Don't log FFMpeg log events
05:28:32.313 ------------ ***************************************************Burn settings end****************************************************
05:28:32.312 Info Default speed selected: 4x
05:28:32.311 Info [ ] Delete vsomsl files after burn complete
05:28:32.310 Info [ ] Delete output folder after burn complete
05:28:32.309 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
05:28:32.308 Info SAO setting: Automatic
05:28:32.307 Info [x] Burn result to disk / as ISO file in working folder
05:28:32.306 ------------ **************************************************Burn settings begin***************************************************
05:28:32.306 Group Encoding session started at 5:28:32 AM: 1 titleset(s) to encode -> Failed after 00:08:35|GK_CONVERT_SESSION|
05:28:31.215 Info #1 [eng] h264 848x480 53:30 yuv420p, 23.98 fps, 0 Kbps
05:28:31.205 Group Video streams
05:28:31.215 Info #2 aac main audio 2 Ch., 48000 Hz, 0 Kbps - Unspecified
05:28:31.205 Group Audio streams
05:28:31.214 Info #3 0:0:2 - ssa 720x576 - Unspecified
05:28:31.205 Group Subtitle streams
05:28:31.213 Warning DISCARDED #4 -
05:28:31.213 Warning DISCARDED #5 -
05:28:31.212 Warning DISCARDED #6 -
05:28:31.211 Warning DISCARDED #7 -
05:28:31.211 Warning DISCARDED #8 -
05:28:31.210 Warning DISCARDED #9 -
05:28:31.210 Warning DISCARDED #10 -
05:28:31.209 Warning DISCARDED #11 -
05:28:31.209 Warning DISCARDED #12 -
05:28:31.208 Warning DISCARDED #13 -
05:28:31.208 Warning DISCARDED #14 -
05:28:31.207 Warning DISCARDED #15 -
05:28:31.207 Warning DISCARDED #16 -
05:28:31.206 Warning DISCARDED #17 -
05:28:31.206 Warning DISCARDED #18 -
05:28:31.206 Warning DISCARDED #19 -
05:28:31.205 Warning DISCARDED #20 -
05:28:31.205 Group Discarded streams
05:28:31.205 Group Added file: H:\Anime\Baka Test\Baka to Test to Shokanjuu 01.mkv
05:27:58.537 Info Menu templates loaded: 36
05:27:57.709 Info Total Physical Memory : 8145 Mb.
Available Physical Memory : 5192 Mb.
Memory Load : 36%
Available Memory : 12929 Mb.
05:27:57.709 Info Processor Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz with 4 core(s) CPU
05:27:57.702 Info OS : Windows 7 (64 bits), Build 7600, service pack 0.0
05:27:57.010 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoHD\1\templates"
05:27:57.009 ------------ ***************************ConvertXToHD.exe:3936 Log session start 2015-03-23 at 05:27:56.800***************************
05:27:57.007 Info 1 writer(s) found.
05:27:56.991 Group Burn engine events
:library=false
:most_recent=first
:status=started
:group_indent=4
Video filters used:
Memory Load : 34%
:library=false
:most_recent=first
:status=stopped
:group_indent=4
Video filters used:
Memory Load : 36%
Something is really wrong here;
Are those mkvs protected? Or in some folder that is encrypted or protected?
If video stream is 0 Kpbs then it has no video - and it can not be converted.05:28:31.215 Info #1 [eng] h264 848x480 53:30 yuv420p, 23.98 fps, 0 Kbps
Just as a test, remove the audio and the subtitles and now try converting.
maybe it is one of these that cause the problem.
I've uploaded two videos below. The same file was dragged from a flash drive to the computer in question (test 1) and to my laptop (test 2). Removing the audio and subtitle doesn't work. I can't burn ANY video on my computer, which is bizarre.
test 1: https://youtu.be/JlIWacl5ol4
test 2: https://youtu.be/D5wKhc-2k7U
If I understood those videos correctly,
test 1 was trying to convert that movie in your desktop, and test 2 converting same movie in laptop?
In desktop you can clearly see that video stream is detected with 0Kbs stream, non-playable and can not be converted.
In laptop it works just fine? Or at least it converts...
If that is the case, then there is something wrong in your desktop. You might need someone to check on it to fix it.
Hello crazylazy89,
Your problem should be fixed in last beta version, I'm waiting for your feedback...
Hello cedric,
I've downloaded the latest beta and the problem still persists. (1st log with encoding/decoding disabled, 2nd log with encoding/decoding enabled). I doubt it's my computer as mentioned by JJ because I was able to convert the same video fine using convertxtodvd5 on the same computer. I've uploaded the video below:
Test 3: https://youtu.be/5EqisipIYmM
:crash_log='C:\ProgramData\VSO\ConvertXtoHD\1\Log\ConvertXtoHD 1_crashlog_.20150325.205423.709.log'
:library=false
:app_version=1.0.0.43
:most_recent=first
:status=started
:group_indent=4
20:56:16.588 Error Error while encoding file: 00000.m2ts
20:56:16.443 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [un]]
+--> [video #1 - h264 video, 1920x1080, yuv420p, 16x9, 23.98Fps, 16000 Kbps [en]]
Video filters used:
20:56:16.441 Info Chapters to generate: 5
20:56:16.381 Info Added in conversion queue list...
20:56:16.315 Group ******************** Titleset #1 - ~24 min. File: "Baka to Test to Shokanjuu 01" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
20:56:16.287 Info Encoding options: Short Projects (Automatic)
20:56:16.286 Info Target size: 22.5 Gb.
20:56:16.078 Info Don't log FFMpeg log events
20:56:14.585 ------------ ***************************************************Burn settings end****************************************************
20:56:14.584 Info Default speed selected: 4x
20:56:14.583 Info [ ] Delete vsomsl files after burn complete
20:56:14.582 Info [ ] Delete output folder after burn complete
20:56:14.581 Info [x] Don't eject disc or open output folder in explorer, after burn complete
20:56:14.580 Info SAO setting: Automatic
20:56:14.579 Info [x] Burn result to disk / as ISO file in working folder
20:56:14.577 ------------ **************************************************Burn settings begin***************************************************
20:56:14.577 Group Encoding session started at 8:56:14 PM: 1 titleset(s) to encode|GK_CONVERT_SESSION|
20:56:05.407 Info #1 [eng] h264 848x480 53:30 yuv420p, 23.98 fps, 0 Kbps
20:56:05.389 Group Video streams
20:56:05.406 Info #2 aac main audio 2 Ch., 48000 Hz, 0 Kbps - Unspecified
20:56:05.389 Group Audio streams
20:56:05.405 Info #3 0:0:2 - ssa 720x576 - Unspecified
20:56:05.389 Group Subtitle streams
20:56:05.404 Warning DISCARDED #4 -
20:56:05.402 Warning DISCARDED #5 -
20:56:05.401 Warning DISCARDED #6 -
20:56:05.400 Warning DISCARDED #7 -
20:56:05.400 Warning DISCARDED #8 -
20:56:05.399 Warning DISCARDED #9 -
20:56:05.398 Warning DISCARDED #10 -
20:56:05.398 Warning DISCARDED #11 -
20:56:05.397 Warning DISCARDED #12 -
20:56:05.396 Warning DISCARDED #13 -
20:56:05.395 Warning DISCARDED #14 -
20:56:05.394 Warning DISCARDED #15 -
20:56:05.394 Warning DISCARDED #16 -
20:56:05.393 Warning DISCARDED #17 -
20:56:05.392 Warning DISCARDED #18 -
20:56:05.390 Warning DISCARDED #19 -
20:56:05.389 Warning DISCARDED #20 -
20:56:05.389 Group Discarded streams
20:56:05.389 Group Added file: H:\Anime\Baka Test\Baka to Test to Shokanjuu 01.mkv
20:54:25.431 Info Menu templates loaded: 36
20:54:24.514 Info Total Physical Memory : 8145 Mb.
Available Physical Memory : 3417 Mb.
Memory Load : 58%
Available Memory : 11812 Mb.
20:54:24.513 Info Processor Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz with 4 core(s) CPU
20:54:24.504 Info OS : Windows 7 (64 bits), Build 7600, service pack 0.0
file version : 1.0.0.43
20:54:23.725 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoHD\1\templates"
20:54:23.724 ------------ ***************************ConvertXToHD.exe:5776 Log session start 2015-03-25 at 20:54:23.497***************************
20:54:23.722 Info 1 writer(s) found.
20:54:23.705 Group Burn engine events
:crash_log='C:\ProgramData\VSO\ConvertXtoHD\1\Log\ConvertXtoHD 1_crashlog_.20150325.210226.733.log'
:library=false
:most_recent=first
:status=started
:group_indent=4
21:03:13.057 Info Conversion failed after 00:00:21
21:02:51.376 Info [ ] Loop playback
21:02:51.375 Info [x] Play titles one after the other
21:02:51.374 Info [x] Don't create title menu for single video
21:02:51.373 Info [x] Return to title menu after titleset playback
21:02:51.372 Info [x] Skip root menu initially
21:02:51.371 Info [x] Auto-start playback
21:02:51.370 Info Template: Black Mirror, contains 4 page(s)
21:02:51.370 Group Blu-ray/AVCHD menu options
21:02:51.370 Info Output target size : BD-25 (23000 MB)
21:02:51.369 Info Number of core(s) used for encoding : 4
21:02:51.368 Info Number of core(s) used for decoding : 4
21:02:51.367 Info [ ] Use 2 pass encoding
21:02:51.366 Info [x] Use best video quality settings
21:02:51.365 Info [x] Use hardware encoding (if possible)
21:02:51.362 Info [x] Use hardware decoding (if possible)
21:02:51.361 Info Max simultaneous conversions: 4
21:02:51.361 Group Advanced encoding options
21:03:12.737 ------------ *****************************************File encoded successfully: 00000.m2ts******************************************
21:03:12.736 Info Menu encoding failed
21:03:12.483 Info Building ROOT menus using template: Black Mirror
21:03:12.468 Info video #1 - Processed video frames: 550 (1316 frames encoded, 0 frames dropped, 766 frames duplicated)
21:02:51.396 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Mono, 192000 bps [un]]
+-[audio mp3 main audio 1 Ch., 44100 Hz, 96 Kbps]
+--> [video #1 - h264_nvenc video, 1920x1080, yuv420p, 16x9, 23.98Fps, 16000 Kbps [un]]
+-[video flv1 1280x720 16:9 yuv420p, 10.00 fps, 0 Kbps]
Output file: H:\ConvertXtoHD\Test 3\BDMV\STREAM\00000.m2ts (Blu-ray)
Input file: H:\Test 3.flv
Video filters used:
21:02:51.350 Info Added in conversion queue list...
21:02:51.296 Group ******************** Titleset #1 - ~1 min. File: "Test 3" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
21:02:51.266 Info Encoding options: Short Projects (Automatic)
21:02:51.265 Info Target size: 22.5 Gb.
21:02:51.140 Info Don't log FFMpeg log events
21:02:51.139 ------------ ***************************************************Burn settings end****************************************************
21:02:51.139 Info Default speed selected: 4x
21:02:51.138 Info [ ] Delete vsomsl files after burn complete
21:02:51.137 Info [ ] Delete output folder after burn complete
21:02:51.137 Info [x] Don't eject disc or open output folder in explorer, after burn complete
21:02:51.136 Info SAO setting: Automatic
21:02:51.135 Info [x] Burn result to disk / as ISO file in working folder
21:02:51.134 ------------ **************************************************Burn settings begin***************************************************
21:02:51.134 Group Encoding session started at 9:02:51 PM: 1 titleset(s) to encode|GK_CONVERT_SESSION|
21:02:29.478 Info #1 flv1 1280x720 16:9 yuv420p, 10.00 fps, 0 Kbps
21:02:29.477 Group Video streams
21:02:29.477 Info #2 mp3 main audio 1 Ch., 44100 Hz, 96 Kbps - Unspecified
21:02:29.477 Group Audio streams
21:02:29.477 Group Added file: H:\Test 3.flv
21:02:29.440 Info File "file://H:\Test 3.flv" parsed successfully
21:02:29.402 Info Parsing file "file://H:\Test 3.flv"
21:02:28.584 Info Menu templates loaded: 36
21:02:27.568 Info Total Physical Memory : 8145 Mb.
Available Physical Memory : 3411 Mb.
Memory Load : 58%
Available Memory : 11310 Mb.
21:02:27.568 Info Processor Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz with 4 core(s) CPU
21:02:27.561 Info OS : Windows 7 (64 bits), Build 7600, service pack 0.0
21:02:26.749 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoHD\1\templates"
21:02:26.748 ------------ ***************************ConvertXToHD.exe:6644 Log session start 2015-03-25 at 21:02:26.517***************************
21:02:26.746 Info 1 writer(s) found.
21:02:26.728 Group Burn engine events
:library=false
:most_recent=first
:status=started
:group_indent=4
Video filters used:
Memory Load : 58%
:library=false
:most_recent=first
:status=started
:group_indent=4
Video filters used:
Memory Load : 58%
Still detecting zero streams with CxtoHD, can you provide log of CxD5 conversion?
Hello crazylazy89,
I think JJ is maybe right. I tried to convert the file you sent (Baka to Test to Shokanjuu 01.mkv) and I don't have any problem.
Can you try to manually delete your output folder (or change it to another drive), and reinstall ConvertXtoHD with the clean options checked in installer?
10:42:33.047 Info Total size 2968 Mb., Target size Personnalisé 23000 Mb., Occupation 12.91%
10:42:35.829 Info Disc name: "Baka to Test to Shokanjuu 01"
10:42:33.283 Info Burned folder: "H:\Video\Converter Output\Baka to Test to Shokanjuu 01", Min. media size 2,9 Gb.
10:42:33.040 Info Conversion completed in 00:10:03
10:32:29.685 Info [ ] Loop playback
10:32:29.680 Info [ ] Play titles one after the other
10:32:29.676 Info [x] Don't create title menu for single video
10:32:29.671 Info [x] Return to title menu after titleset playback
10:32:29.667 Info [x] Skip root menu initially
10:32:29.662 Info [ ] Auto-start playback
10:32:29.657 Info Template: Mirroir noir avec vidéo dans le 1er tiers haut du menu racine, contains 4 page(s)
10:32:29.657 Group Options de menu Blu-ray/AVCHD
10:32:29.653 Info Output target size : BD-25 (23000 MB)
10:32:29.648 Info Number of core(s) used for encoding : 8
10:32:29.644 Info Number of core(s) used for decoding : 8
10:32:29.639 Info [ ] Use 2 pass encoding
10:32:29.635 Info [ ] Use best video quality settings
10:32:29.630 Info [ ] Use hardware encoding (if possible)
10:32:29.625 Info [ ] Use hardware decoding (if possible)
10:32:29.621 Info Max simultaneous conversions: 8
10:32:29.621 Group Options d'encodage avancées
10:42:32.768 ------------ *****************************************File encoded successfully: 00000.m2ts******************************************
10:42:32.760 Info "REGLAGES" menu built successfully
10:42:21.592 Info "CHAPITRES" menu built successfully
10:42:03.667 Info "RACINE" menu built successfully
10:41:39.736 Info Building RACINE, CHAPITRES & REGLAGES menus using template: Mirroir noir avec vidéo dans le 1er tiers haut du menu racine
^^^Repeated 2 Times in 7 millisecond(s)^^^
10:41:39.659 Info subtitle #3 - Encoded subtitles frames: 1335
10:41:39.650 Info video #1 - Processed video frames: 34513 (34511 frames encoded, 1 frames dropped, 0 frames duplicated)
10:32:29.712 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1920x1080 [un]]
+-[audio aac audio principale 2 Ch., 48000 Hz, 0 Kbps]
+--> [video #1 - h264 video, 1920x1080, yuv420p, 16x9, 23,98Fps, 16000 Kbps [en]]
+-[video [eng] h264 848x480 53:30 yuv420p, 23,98 fps, 0 Kbps]
Fichier de sortie: H:\Video\Converter Output\Baka to Test to Shokanjuu 01\BDMV\STREAM\00000.m2ts (Blu-ray)
Fichier source : H:\Video\From users\crazylazy89@hotmail.com\Baka to Test to Shokanjuu 01.mkv
Video filters used:
10:32:29.706 Info Nombre de chapitres à générer: 5
10:32:29.607 Info Added in conversion queue list...
10:32:29.548 Group ******************** Titre No 1 - ~24 min. Fichier : "Baka to Test to Shokanjuu 01" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
10:32:29.543 Info Encoding options: Short Projects (Automatique)
10:32:29.538 Info Target size: 22,5 Gb.
Video filters used:
I've deleted the output file and reinstall with clean options and still got the same error. Below is the log of the CxD5.
:crash_log='C:\ProgramData\VSO\ConvertXtoDVD\5\Log\ConvertXtoDVD 5_crashlog_.20150325.205245.703.log'
:library=false
:app_name=ConvertXtoDvd.exe
:app_version=5.2.0.59
:most_recent=first
:status=started
:group_indent=4
07:06:26.021 Info Disc name: "Baka to Test to Shokanjuu 01"
07:06:22.728 Info Burned folder: "H:\ConvertXtoDVD\Baka to Test to Shokanjuu 01", Min. media size 942 Mb.
07:06:22.584 Info Conversion completed in 00:04:19
07:02:03.342 Info [ ] Loop playback
07:02:03.340 Info [x] Play titles one after the other
07:02:03.338 Info [x] Don't create title menu for single video
07:02:03.335 Info [x] Return to title menu after titleset playback
07:02:03.333 Info [x] Skip root menu initially
07:02:03.331 Info [x] Auto-start playback
07:02:03.329 Info Template: Black Mirror, contains 4 page(s)
07:02:03.329 Group Video DVD menu options
07:02:03.327 Info Video DVD format: NTSC (30 Fps)
07:02:03.325 Info Output target size : DVD-5 (4300 MB)
07:02:03.323 Info Number of core(s) used for encoding : 4
07:02:03.321 Info Number of core(s) used for decoding : 4
07:02:03.319 Info [ ] Use 2 pass encoding
07:02:03.317 Info [x] Use best video quality settings
07:02:03.315 Info [ ] Use hardware decoding (if possible)
07:02:03.313 Info Max simultaneous conversions: 4
07:02:03.313 Group Advanced encoding options
07:06:22.194 ------------ ****************************************File encoded successfully: VTS_01_1.VOB*****************************************
07:06:22.191 Info "SETTINGS" menu built successfully
07:06:21.362 Info "CHAPTERS" menu built successfully
07:06:15.646 Info "ROOT" menu built successfully
07:06:14.869 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Black Mirror
07:06:14.801 Info subtitle #3 - Encoded subtitles frames: 816
07:06:14.799 Info DVD sectors written - video: 458100, audio: 17143, subtitle: 1221
07:06:14.797 Info video #1 - Processed video frames: 34513 (43140 frames encoded, 0 frames dropped, 8627 frames duplicated)
07:02:03.362 ------------ +--> [subtitle #3 - dvd_subtitle subtitle, 720x576 [un]]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, 29.97Fps, 9000 Kbps [en]]
Output file: H:\ConvertXtoDVD\Baka to Test to Shokanjuu 01\VIDEO_TS\VTS_01_1.VOB (DVD NTSC)
Video filters used:
- Scale filter: linear (vso). Fit method: letterbox (Padding: top: 0, bottom: 0, left: 2, right: 2. Cropping: top: 0, bottom: 0, left: 0, right: 0)
07:02:03.359 Info Chapters to generate: 5
07:02:03.309 Info Added in conversion queue list...
07:02:03.261 Group ******************** Titleset #1 - ~24 min. File: "Baka to Test to Shokanjuu 01" -> VTS_01_1.VOB - DVD NTSC ********************|GK_TITLESET|
07:02:03.260 Info Encoding options: Short Projects (Automatic)
07:02:03.258 Info Target size: 4.2 Gb.
07:02:03.168 Info Don't log FFMpeg log events
07:02:03.165 ------------ ***************************************************Burn settings end****************************************************
07:02:03.164 Info Default speed selected: 4x
07:02:03.162 Info [ ] Delete vsomsl files after burn complete
07:02:03.160 Info [ ] Delete output folder after burn complete
07:02:03.158 Info [x] Don't eject disc or open output folder in explorer, after burn complete
07:02:03.157 Info SAO setting: Automatic
07:02:03.155 Info [x] Burn result to disk / as ISO file in working folder
07:02:03.153 ------------ **************************************************Burn settings begin***************************************************
07:02:03.153 Group Encoding session started at 7:02:03 AM: 1 titleset(s) to encode -> Completed in 00:04:19|GK_CONVERT_SESSION|
20:56:54.334 Info User requested cancellation
20:56:54.678 Info Conversion cancelled after 00:00:15
20:56:39.261 Info [ ] Loop playback
20:56:39.259 Info [x] Play titles one after the other
20:56:39.258 Info [x] Don't create title menu for single video
20:56:39.256 Info [x] Return to title menu after titleset playback
20:56:39.255 Info [x] Skip root menu initially
20:56:39.252 Info [x] Auto-start playback
20:56:39.251 Info Template: Black Mirror, contains 4 page(s)
20:56:39.251 Group Video DVD menu options
20:56:39.250 Info Video DVD format: NTSC (30 Fps)
20:56:39.248 Info Output target size : DVD-5 (4300 MB)
20:56:39.247 Info Number of core(s) used for encoding : 4
20:56:39.246 Info Number of core(s) used for decoding : 4
20:56:39.244 Info [ ] Use 2 pass encoding
20:56:39.243 Info [x] Use best video quality settings
20:56:39.241 Info [ ] Use hardware decoding (if possible)
20:56:39.239 Info Max simultaneous conversions: 4
20:56:39.239 Group Advanced encoding options
20:56:54.385 Warning File encoding cancelled by user: VTS_01_1.VOB
20:56:39.282 ------------ +--> [subtitle #3 - dvd_subtitle subtitle, 720x576 [un]]
Video filters used:
20:56:39.281 Info Chapters to generate: 5
20:56:39.228 Info Added in conversion queue list...
20:56:39.174 Group ******************** Titleset #1 - ~24 min. File: "Baka to Test to Shokanjuu 01" -> VTS_01_1.VOB - DVD NTSC ********************|GK_TITLESET|
20:56:39.173 Info Encoding options: Short Projects (Automatic)
20:56:39.172 Info Target size: 4.2 Gb.
20:56:39.075 Info Don't log FFMpeg log events
20:56:34.539 Info No disc in drive.
20:56:33.413 ------------ ***************************************************Burn settings end****************************************************
20:56:33.412 Info Default speed selected: 4x
20:56:33.411 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
20:56:33.410 Info Drive has Serial ATA physical interface
20:56:33.409 Info New Drive selected : [D] ASUS DRW-24B3ST 1.00 (ATAPI)
20:56:33.408 Info [ ] Delete vsomsl files after burn complete
20:56:33.407 Info [ ] Delete output folder after burn complete
20:56:33.406 Info [x] Don't eject disc or open output folder in explorer, after burn complete
20:56:33.405 Info SAO setting: Automatic
20:56:33.404 Info [x] Burn result to disk / as ISO file in working folder
20:56:33.403 ------------ **************************************************Burn settings begin***************************************************
20:56:33.403 Group Encoding session started at 8:56:33 PM: 1 titleset(s) to encode -> Cancelled after 00:00:15|GK_CONVERT_SESSION|
20:56:28.408 Info #1 [eng] h264 848x480 53:30 yuv420p, 23.98 fps, 0 Kbps
20:56:28.395 Group Video streams
20:56:28.407 Info #2 aac main audio 2 Ch., 48000 Hz, 0 Kbps - Unspecified
20:56:28.395 Group Audio streams
20:56:28.406 Info #3 0:0:2 - ssa 720x576 - Unspecified
20:56:28.395 Group Subtitle streams
20:56:28.405 Warning DISCARDED #4 -
20:56:28.405 Warning DISCARDED #5 -
20:56:28.404 Warning DISCARDED #6 -
20:56:28.403 Warning DISCARDED #7 -
20:56:28.403 Warning DISCARDED #8 -
20:56:28.402 Warning DISCARDED #9 -
20:56:28.401 Warning DISCARDED #10 -
20:56:28.400 Warning DISCARDED #11 -
20:56:28.400 Warning DISCARDED #12 -
20:56:28.399 Warning DISCARDED #13 -
20:56:28.398 Warning DISCARDED #14 -
20:56:28.398 Warning DISCARDED #15 -
20:56:28.397 Warning DISCARDED #16 -
20:56:28.397 Warning DISCARDED #17 -
20:56:28.396 Warning DISCARDED #18 -
20:56:28.396 Warning DISCARDED #19 -
20:56:28.395 Warning DISCARDED #20 -
20:56:28.395 Group Discarded streams
20:56:28.395 Group Added file: H:\Anime\Baka Test\Baka to Test to Shokanjuu 01.mkv
20:52:47.418 Info Menu templates loaded: 37
20:52:46.456 Info Total Physical Memory : 8145 Mb.
Available Physical Memory : 3539 Mb.
Memory Load : 56%
Available Virtual Memory : 3798 Mb.
Available Memory : 11896 Mb.
20:52:46.455 Info Processor Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz with 4 core(s) CPU
20:52:46.448 Info OS : Windows 7 (64 bits), Build 7600, service pack 0.0
file name : C:\Program Files (x86)\VSO\ConvertX\5\ConvertXtoDvd.exe
file version : 5.2.0.59
20:52:45.719 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoDVD\5\templates"
20:52:45.718 ------------ **************************ConvertXtoDvd.exe:5984 Log session start 2015-03-25 at 20:52:45.487***************************
20:52:45.716 Info 1 writer(s) found.
20:52:45.700 Group Burn engine events
:library=false
:most_recent=first
:status=started
:group_indent=4
Video filters used:
Video filters used:
Memory Load : 56%
What if you uncheck "Use best video quality settings"
Does this file convert on the "problem computer"
http://oasis.vso-software.fr/videos/test_vso.avi
Have you tried with 1.1.0.3?
How about those mini videos you posted on youtube, can you convert those in ConvertXtoHD?
Claire,
Using 1.1.0.3 I've tried converting with "best video quality settings" unchecked and they both failed. Below are the two fail logs and youtube video:
Test 5: https://youtu.be/HEqr6sVBpvg
1) First fail log was with "best video quality settings" unchecked. Same error.
2) Second fail log I checked use hardware encoding/decoding and it will burn but will always fail at the end.
:crash_log='C:\ProgramData\VSO\ConvertXtoHD\1\Log\ConvertXtoHD 1_crashlog_.20150515.235703.374.log'
:library=false
:app_version=1.1.0.3
:most_recent=first
:status=started
:group_indent=4
23:57:39.050 Info Conversion failed after 00:00:00
23:57:38.624 Info [ ] Loop playback
23:57:38.623 Info [ ] Play titles one after the other
23:57:38.622 Info [x] Don't create title menu for single video
23:57:38.620 Info [x] Return to title menu after titleset playback
23:57:38.619 Info [x] Skip root menu initially
23:57:38.618 Info [ ] Auto-start playback
23:57:38.617 Info Template: Black Mirror, contains 4 page(s)
23:57:38.617 Group Blu-ray/AVCHD menu options
23:57:38.616 Info Output target size : BD-25 (23000 MB)
23:57:38.615 Info Number of core(s) used for encoding : 4
23:57:38.614 Info Number of core(s) used for decoding : 4
23:57:38.613 Info [ ] Use 2 pass encoding
23:57:38.612 Info [ ] Use best video quality settings
23:57:38.611 Info [ ] Use hardware encoding (if possible)
23:57:38.608 Info [ ] Use hardware decoding (if possible)
23:57:38.607 Info Max simultaneous conversions: 4
23:57:38.607 Group Advanced encoding options
23:57:38.792 Error Error while encoding file: 00000.m2ts
23:57:38.656 Info H264 settings for stream #1: preset=superfast,qmin=1,lmin=118,mblmin=118,b=29552000,bt=29552000,maxrate=15000000,minrate=0,codec=h264,width=720,height=576,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=4/3,aspect=16/15,time_base=1/25,g=25,keyint=25,bf=3,refs=5,h264_level=4.1,bufsize=12000000,slices=1,colorprim=bt470,transfer=bt470,colormatrix=bt470,fake_interlaced=1,me_method=5,me_range=16,threads=4
23:57:38.654 ------------ +--> [audio #2 - RAW copy]
+-[audio ac3 main audio 2 Ch., 48000 Hz, 448 Kbps]
+--> [video #1 - h264 video, 720x576, yuv420p, 4x3, 25.00Fps, 29552 Kbps [un]]
+-[video mpeg4 720x576 5:4 yuv420p, 25.00 fps, 921 Kbps]
Output file: H:\Convert\test_vso\BDMV\STREAM\00000.m2ts (Blu-ray)
Input file: C:\Users\TENSAI\Downloads\test_vso.avi
Video filters used:
- DeInterlace filter: FFmpeg (used only if needed)
- Scale filter: fast linear (vso). Fit method: letterbox (Padding: top: 0, bottom: 0, left: 22, right: 22. Cropping: top: 0, bottom: 0, left: 0, right: 0)
23:57:38.590 Info Added in conversion queue list...
23:57:38.537 Group ******************** Titleset #1 - ~7 min. File: "test_vso" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
23:57:38.536 Info Encoding options: Short Projects (Automatic)
23:57:38.535 Info Target size: 22.5 Gb.
23:57:38.386 Info Don't log FFMpeg log events
23:57:38.385 ------------ ***************************************************Burn settings end****************************************************
23:57:38.384 Info Default speed selected: 4x
23:57:38.383 Info [ ] Delete vsomsl files after burn complete
23:57:38.383 Info [ ] Delete output folder after burn complete
23:57:38.382 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
23:57:38.381 Info SAO setting: Automatic
23:57:38.381 Info [x] Burn result to disk / as ISO file in working folder
23:57:38.380 ------------ **************************************************Burn settings begin***************************************************
23:57:38.380 Group Encoding session started at 11:57:38 PM: 1 titleset(s) to encode|GK_CONVERT_SESSION|
23:57:26.526 Info #1 mpeg4 720x576 5:4 yuv420p, 25.00 fps, 921 Kbps
23:57:26.526 Group Video streams
23:57:26.526 Info #2 ac3 main audio 2 Ch., 48000 Hz, 448 Kbps - Unspecified
23:57:26.526 Group Audio streams
23:57:26.526 Group Added file: C:\Users\TENSAI\Downloads\test_vso.avi
23:57:20.085 Info Removed segment: test_vso
23:57:16.841 Info #1 mpeg4 720x576 5:4 yuv420p, 25.00 fps, 921 Kbps
23:57:16.841 Group Video streams
23:57:16.841 Info #2 ac3 main audio 2 Ch., 48000 Hz, 448 Kbps - Unspecified
23:57:16.841 Group Audio streams
23:57:16.841 Group Added file: C:\Users\TENSAI\Downloads\test_vso.avi
23:57:05.329 Info Menu templates loaded: 36
23:57:04.259 Info Total Physical Memory : 8145 Mb.
Available Physical Memory : 4673 Mb.
Memory Load : 42%
Available Virtual Memory : 3792 Mb.
Available Memory : 12343 Mb.
23:57:04.258 Info Processor Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz with 4 core(s) CPU
23:57:04.251 Info OS : Windows 7 (64 bits), Build 7600, service pack 0.0
file version : 1.1.0.3
23:57:03.390 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoHD\1\templates"
23:57:03.389 ------------ ***************************ConvertXToHD.exe:1200 Log session start 2015-05-15 at 23:57:03.166***************************
23:57:03.387 Info 1 writer(s) found.
23:57:03.368 Group Burn engine events
:std_log='C:\ProgramData\VSO\ConvertXtoHD\1\Log\ConvertXtoHD 1_mainlog_.20150516.000531.145.log'
:library=false
:most_recent=first
:status=stopped
:group_indent=4
00:05:31.134 ------------ ****************ConvertXToHD.exe:1476 Log session stop after 7 minute(s) 33 second(s) 352 millisecond(s)****************
00:05:26.867 Info Removed segment: test_vso
00:05:24.199 Info Conversion failed after 00:00:37
00:04:47.149 Info [ ] Loop playback
00:04:47.148 Info [ ] Play titles one after the other
00:04:47.146 Info [x] Don't create title menu for single video
00:04:47.144 Info [x] Return to title menu after titleset playback
00:04:47.142 Info [x] Skip root menu initially
00:04:47.140 Info [ ] Auto-start playback
00:04:47.139 Info Template: Black Mirror, contains 4 page(s)
00:04:47.139 Group Blu-ray/AVCHD menu options
00:04:47.137 Info Output target size : BD-25 (23000 MB)
00:04:47.135 Info Number of core(s) used for encoding : 4
00:04:47.134 Info Number of core(s) used for decoding : 4
00:04:47.132 Info [ ] Use 2 pass encoding
00:04:47.130 Info [ ] Use best video quality settings
00:04:47.129 Info [x] Use hardware encoding (if possible)
00:04:47.125 Info [x] Use hardware decoding (if possible)
00:04:47.123 Info Max simultaneous conversions: 4
00:04:47.123 Group Advanced encoding options
00:05:23.908 ------------ *****************************************File encoded successfully: 00000.m2ts******************************************
00:05:23.903 Info Menu encoding failed
00:05:23.726 Info H264 settings for stream #1: codec=h264,width=720,height=576,dar=4/3,user_b=8000000,bt=8000000,maxrate=15000000,threads=2,preset=superfast,time_base=1/25,g=25,fake_interlaced=1,me_method=5,me_range=16,slices=1,refs=5,bf=3,minrate=0,bufsize=12000000,colorprim=bt470,transfer=bt470,colormatrix=bt470,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=8000000,keyint=25,aspect=16/15,pix_fmt=yuv420p
00:05:23.710 Info Building ROOT menus using template: Black Mirror
^^^Repeated 2 Times in 2 millisecond(s)^^^
00:05:23.704 Info video #1 - Processed video frames: 11161 (11161 frames encoded, 0 frames dropped, 0 frames duplicated)
00:04:47.176 Info H264 settings for stream #1: preset=superfast,qmin=1,lmin=118,mblmin=118,b=30000000,bt=30000000,maxrate=15000000,minrate=0,codec=h264_nvenc,width=720,height=576,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=4/3,aspect=16/15,time_base=1/25,g=25,keyint=25,bf=3,refs=5,h264_level=4.1,bufsize=12000000,slices=1,colorprim=bt470,transfer=bt470,colormatrix=bt470,fake_interlaced=1,me_method=5,me_range=16,threads=4
00:04:47.173 ------------ +--> [video #1 - h264_nvenc video, 720x576, yuv420p, 4x3, 25.00Fps, 30000 Kbps [un]]
Video filters used:
00:04:47.108 Info Added in conversion queue list...
00:04:47.059 Group ******************** Titleset #1 - ~7 min. File: "test_vso" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
00:04:47.058 Info Encoding options: Short Projects (Automatic)
00:04:47.056 Info Target size: 22.5 Gb.
00:04:46.956 Info Don't log FFMpeg log events
00:04:46.955 ------------ ***************************************************Burn settings end****************************************************
00:04:46.953 Info Default speed selected: 4x
00:04:46.952 Info [ ] Delete vsomsl files after burn complete
00:04:46.950 Info [ ] Delete output folder after burn complete
00:04:46.949 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
00:04:46.947 Info SAO setting: Automatic
00:04:46.946 Info [x] Burn result to disk / as ISO file in working folder
00:04:46.945 ------------ **************************************************Burn settings begin***************************************************
00:04:46.945 Group Encoding session started at 12:04:46 AM: 1 titleset(s) to encode -> Failed after 00:00:37|GK_CONVERT_SESSION|
23:58:54.261 Info Conversion failed after 00:00:41
23:58:12.912 Info [ ] Loop playback
23:58:12.911 Info [ ] Play titles one after the other
23:58:12.910 Info [x] Don't create title menu for single video
23:58:12.909 Info [x] Return to title menu after titleset playback
23:58:12.908 Info [x] Skip root menu initially
23:58:12.907 Info [ ] Auto-start playback
23:58:12.906 Info Template: Black Mirror, contains 4 page(s)
23:58:12.906 Group Blu-ray/AVCHD menu options
23:58:12.904 Info Output target size : BD-25 (23000 MB)
23:58:12.903 Info Number of core(s) used for encoding : 4
23:58:12.902 Info Number of core(s) used for decoding : 4
23:58:12.901 Info [ ] Use 2 pass encoding
23:58:12.900 Info [ ] Use best video quality settings
23:58:12.899 Info [x] Use hardware encoding (if possible)
23:58:12.896 Info [x] Use hardware decoding (if possible)
23:58:12.895 Info Max simultaneous conversions: 4
23:58:12.895 Group Advanced encoding options
23:58:53.997 ------------ *****************************************File encoded successfully: 00000.m2ts******************************************
23:58:53.995 Info Menu encoding failed
23:58:53.806 Info H264 settings for stream #1: codec=h264,width=720,height=576,dar=4/3,user_b=8000000,bt=8000000,maxrate=15000000,threads=2,preset=superfast,time_base=1/25,g=25,fake_interlaced=1,me_method=5,me_range=16,slices=1,refs=5,bf=3,minrate=0,bufsize=12000000,colorprim=bt470,transfer=bt470,colormatrix=bt470,strict=normal,bluray=1,flags=+loop+cgop-global_header,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,h264_level=4.1,b=8000000,keyint=25,aspect=16/15,pix_fmt=yuv420p
23:58:53.789 Info Building ROOT menus using template: Black Mirror
23:58:53.785 Info video #1 - Processed video frames: 11161 (11161 frames encoded, 0 frames dropped, 0 frames duplicated)
23:58:12.942 Info H264 settings for stream #1: preset=superfast,qmin=1,lmin=118,mblmin=118,b=29552000,bt=29552000,maxrate=15000000,minrate=0,codec=h264_nvenc,width=720,height=576,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=4/3,aspect=16/15,time_base=1/25,g=25,keyint=25,bf=3,refs=5,h264_level=4.1,bufsize=12000000,slices=1,colorprim=bt470,transfer=bt470,colormatrix=bt470,fake_interlaced=1,me_method=5,me_range=16,threads=4
23:58:12.940 ------------ +--> [audio #2 - RAW copy]
+--> [video #1 - h264_nvenc video, 720x576, yuv420p, 4x3, 25.00Fps, 29552 Kbps [un]]
Video filters used:
23:58:12.860 Info Added in conversion queue list...
23:58:12.807 Group ******************** Titleset #1 - ~7 min. File: "test_vso" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
23:58:12.806 Info Encoding options: Short Projects (Automatic)
23:58:12.805 Info Target size: 22.5 Gb.
23:58:12.685 Info Don't log FFMpeg log events
23:58:12.682 ------------ ***************************************************Burn settings end****************************************************
23:58:12.681 Info Default speed selected: 4x
23:58:12.681 Info [ ] Delete vsomsl files after burn complete
23:58:12.680 Info [ ] Delete output folder after burn complete
23:58:12.680 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
23:58:12.679 Info SAO setting: Automatic
23:58:12.679 Info [x] Burn result to disk / as ISO file in working folder
23:58:12.678 ------------ **************************************************Burn settings begin***************************************************
23:58:12.678 Group Encoding session started at 11:58:12 PM: 1 titleset(s) to encode -> Failed after 00:00:41|GK_CONVERT_SESSION|
23:57:57.550 Info #1 mpeg4 720x576 5:4 yuv420p, 25.00 fps, 921 Kbps
23:57:57.550 Group Video streams
23:57:57.550 Info #2 ac3 main audio 2 Ch., 48000 Hz, 448 Kbps - Unspecified
23:57:57.550 Group Audio streams
23:57:57.550 Group Added file: C:\Users\TENSAI\Downloads\test_vso.avi
23:57:55.580 Info Menu templates loaded: 36
23:57:54.543 Info Total Physical Memory : 8145 Mb.
Available Physical Memory : 4670 Mb.
Memory Load : 42%
Available Memory : 12336 Mb.
23:57:54.543 Info Processor Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz with 4 core(s) CPU
23:57:54.536 Info OS : Windows 7 (64 bits), Build 7600, service pack 0.0
23:57:53.742 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoHD\1\templates"
23:57:53.741 ------------ ***************************ConvertXToHD.exe:1476 Log session start 2015-05-15 at 23:57:53.515***************************
23:57:53.739 Info 1 writer(s) found.
23:57:53.721 Group Burn engine events
:library=false
:most_recent=first
:status=started
:group_indent=4
Video filters used:
Memory Load : 42%
:library=false
:most_recent=first
:status=stopped
:group_indent=4
Video filters used:
Video filters used:
Memory Load : 42%
If you use hardware decoding and encoding and select the menu template "no menu" does this video convert with success:
test_vso.avi ?
How about your initial video?
test_vso.avi ?
I had this very same problem and found it to be a bug with the latest NVidia drivers 352.86. If I uninstall these drivers and install older 350.12 drivers then my encodes start to work again. Don't know if it is a NVidia bug or ConvertXtoHD bug. Hope it gets fixed quickly tho.
It might be that, then selecting NOT to use any HW en/decoders should give good result.pottzman wrote:I had this very same problem and found it to be a bug with the latest NVidia drivers 352.86. If I uninstall these drivers and install older 350.12 drivers then my encodes start to work again. Don't know if it is a NVidia bug or ConvertXtoHD bug. Hope it gets fixed quickly tho.
I was using an older driver 347.XX so it wasn't due to the new driver installed. I updated to 350.12 and the same encoding error still appears.
I was able to burn successfully finally by enabling HW encoding/decoding and selecting the "no menu" template suggested by Claire! Below is the log!
:std_log='C:\ProgramData\VSO\ConvertXtoHD\1\Log\ConvertXtoHD 1_mainlog_.20150525.112145.577.log'
:library=false
:most_recent=first
:status=stopped
:group_indent=4
11:21:45.560 ------------ ****************ConvertXToHD.exe:5908 Log session stop after 6 minute(s) 45 second(s) 957 millisecond(s)****************
11:21:35.919 Info Total size 1708 Mb., Target size Custom 23000 Mb., Occupation 7.43%
11:21:44.000 Info Disc name: "Baka to Test to Shokanjuu 01"
11:21:36.040 Info Burned folder: "H:\Convert\[HorribleSubs] Akame ga Kill! - 01 [720p]", Min. media size 1.67 Gb.
11:21:35.913 Info Conversion completed in 00:03:52
11:17:43.739 Info [ ] Loop playback
11:17:43.737 Info [ ] Play titles one after the other
11:17:43.734 Info [ ] Return to title menu after titleset playback
11:17:43.732 Info [x] Skip root menu initially
11:17:43.729 Info [x] Auto-start playback
11:17:43.727 Info No menu generated
11:17:43.727 Group Blu-ray/AVCHD menu options
11:17:43.725 Info Output target size : BD-25 (23000 MB)
11:17:43.723 Info Number of core(s) used for encoding : 4
11:17:43.720 Info Number of core(s) used for decoding : 4
11:17:43.718 Info [ ] Use 2 pass encoding
11:17:43.716 Info [ ] Use best video quality settings
11:17:43.714 Info [x] Use hardware encoding (if possible)
11:17:43.710 Info [x] Use hardware decoding (if possible)
11:17:43.708 Info Max simultaneous conversions: 4
11:17:43.708 Group Advanced encoding options
11:21:35.776 ------------ *****************************************File encoded successfully: 00000.m2ts******************************************
11:21:35.771 Info Building menus using template: No menu
^^^Repeated 2 Times in 3 millisecond(s)^^^
11:21:35.746 Info subtitle #3 - Encoded subtitles frames: 991
11:21:35.742 Info video #1 - Processed video frames: 34091 (34089 frames encoded, 2 frames dropped, 0 frames duplicated)
11:17:43.895 Info h264: using hardware decoder adapter #0 - NVIDIA GeForce GTX 660 , vendor 0x10DE (NVIDIA), device 0x11C0, revision 161
11:17:43.768 Info H264 settings for stream #1: preset=superfast,qmin=1,lmin=118,mblmin=118,b=39800000,bt=39800000,maxrate=20000000,minrate=0,codec=h264_nvenc,width=1280,height=720,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,aspect=1/1,g=24,keyint=24,time_base=1001/24000,bf=3,refs=5,h264_level=4.1,bufsize=15000000,rc_init_occupancy=20000000,slices=4,colorprim=bt709,transfer=bt709,colormatrix=bt709,me_method=5,me_range=16,threads=4
11:17:43.764 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 1280x720 [un]]
+-[subtitle #2 - ass subtitle]
+--> [video #1 - h264_nvenc video, 1280x720, yuv420p, 16x9, 23.98Fps, 39800 Kbps [un]]
+-[video dxva2 h264 1280x720 16:9 yuv420p, 23.98 fps, 0 Kbps]
Output file: H:\Convert\[HorribleSubs] Akame ga Kill! - 01 [720p]\BDMV\STREAM\00000.m2ts (Blu-ray)
Video filters used:
11:17:43.754 Info Chapters to generate: 5
11:17:43.693 Info Added in conversion queue list...
11:17:43.681 Group ******************** Titleset #1 - ~23 min. File: "[HorribleSubs] Akame ga Kill! - 01 [720p]" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
11:17:43.678 Info Encoding options: Short Projects (Automatic)
11:17:43.676 Info Target size: 22.5 Gb.
11:17:43.584 Info Don't log FFMpeg log events
11:17:42.101 ------------ ***************************************************Burn settings end****************************************************
11:17:42.096 Info Default speed selected: 4x
11:17:42.092 Info [ ] Delete vsomsl files after burn complete
11:17:42.087 Info [ ] Delete output folder after burn complete
11:17:42.082 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
11:17:42.078 Info SAO setting: Automatic
11:17:42.073 Info [x] Burn result to disk / as ISO file in working folder
11:17:42.068 ------------ **************************************************Burn settings begin***************************************************
11:17:42.068 Group Encoding session started at 11:17:42 AM: 1 titleset(s) to encode -> Completed in 00:03:52|GK_CONVERT_SESSION|
11:17:40.595 Info Removed segment: Baka to Test to Shokanjuu 01
11:17:39.336 Info #1 h264 1280x720 16:9 yuv420p, 23.98 fps, 0 Kbps
11:17:39.330 Group Video streams
11:17:39.334 Info #2 aac main audio 2 Ch., 44100 Hz, 0 Kbps - Unspecified
11:17:39.330 Group Audio streams
11:17:39.332 Info #3 0:0:2 - ass 720x576 - Unspecified
11:17:39.330 Group Subtitle streams
11:17:39.330 Warning DISCARDED #4 -
11:17:39.330 Group Discarded streams
11:17:39.330 Group Added file: H:\Anime\Akame ga Kill! [HorribleSubs]\[HorribleSubs] Akame ga Kill! - 01 [720p].mkv
11:17:07.509 Info Total size 1337 Mb., Target size Custom 23000 Mb., Occupation 5.82%
11:17:20.153 Info Disc name: "Baka to Test to Shokanjuu 01"
11:17:07.682 Info Burned folder: "H:\Convert\Baka to Test to Shokanjuu 01", Min. media size 1.31 Gb.
11:17:07.506 Info Conversion completed in 00:01:55
11:15:12.207 Info [ ] Loop playback
11:15:12.205 Info [ ] Play titles one after the other
11:15:12.204 Info [ ] Return to title menu after titleset playback
11:15:12.203 Info [x] Skip root menu initially
11:15:12.202 Info [x] Auto-start playback
11:15:12.200 Info No menu generated
11:15:12.200 Group Blu-ray/AVCHD menu options
11:15:12.199 Info Output target size : BD-25 (23000 MB)
11:15:12.198 Info Number of core(s) used for encoding : 4
11:15:12.197 Info Number of core(s) used for decoding : 4
11:15:12.196 Info [ ] Use 2 pass encoding
11:15:12.195 Info [ ] Use best video quality settings
11:15:12.193 Info [x] Use hardware encoding (if possible)
11:15:12.191 Info [x] Use hardware decoding (if possible)
11:15:12.189 Info Max simultaneous conversions: 4
11:15:12.189 Group Advanced encoding options
11:17:07.278 ------------ *****************************************File encoded successfully: 00000.m2ts******************************************
11:17:07.261 Info Building menus using template: No menu
11:17:07.200 Info subtitle #3 - Encoded subtitles frames: 1274
11:17:07.195 Info video #1 - Processed video frames: 34516 (43143 frames encoded, 0 frames dropped, 8627 frames duplicated)
11:15:12.406 Info h264: using hardware decoder adapter #0 - NVIDIA GeForce GTX 660 , vendor 0x10DE (NVIDIA), device 0x11C0, revision 161
11:15:12.234 Info H264 settings for stream #1: preset=superfast,qmin=1,lmin=118,mblmin=118,b=29800000,bt=29800000,maxrate=15000000,minrate=0,codec=h264_nvenc,width=720,height=480,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,aspect=40/33,time_base=1001/30000,g=30,keyint=30,bf=3,refs=5,h264_level=4.1,bufsize=12000000,rc_init_occupancy=15000000,slices=1,colorprim=smpte170m,transfer=smpte170m,colormatrix=smpte170m,fake_interlaced=1,me_method=5,me_range=16,language=en,threads=4
11:15:12.233 ------------ +--> [subtitle #3 - hdmv_pgs_subtitle subtitle, 720x480 [un]]
+--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [un]]
+-[audio aac main audio 2 Ch., 48000 Hz, 0 Kbps]
+--> [video #1 - h264_nvenc video, 720x480, yuv420p, 16x9, 29.97Fps, 29800 Kbps [en]]
Output file: H:\Convert\Baka to Test to Shokanjuu 01\BDMV\STREAM\00000.m2ts (Blu-ray)
Input file: H:\Anime\Baka Test\Baka to Test to Shokanjuu 01.mkv
Video filters used:
- Scale filter: fast linear (vso). Fit method: letterbox (Padding: top: 0, bottom: 0, left: 2, right: 2. Cropping: top: 0, bottom: 0, left: 0, right: 0)
11:15:12.221 Info Chapters to generate: 5
11:15:12.177 Info Added in conversion queue list...
11:15:12.164 Group ******************** Titleset #1 - ~24 min. File: "Baka to Test to Shokanjuu 01" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
11:15:12.163 Info Encoding options: Short Projects (Automatic)
11:15:12.162 Info Target size: 22.5 Gb.
11:15:12.076 Info Don't log FFMpeg log events
11:15:10.730 ------------ ***************************************************Burn settings end****************************************************
11:15:10.729 Info Default speed selected: 4x
11:15:10.728 Info [ ] Delete vsomsl files after burn complete
11:15:10.727 Info [ ] Delete output folder after burn complete
11:15:10.725 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
11:15:10.724 Info SAO setting: Automatic
11:15:10.723 Info [x] Burn result to disk / as ISO file in working folder
11:15:10.722 ------------ **************************************************Burn settings begin***************************************************
11:15:10.722 Group Encoding session started at 11:15:10 AM: 1 titleset(s) to encode -> Completed in 00:01:55|GK_CONVERT_SESSION|
11:15:09.113 Info h264: using hardware decoder adapter #0 - NVIDIA GeForce GTX 660 , vendor 0x10DE (NVIDIA), device 0x11C0, revision 161
11:15:06.841 Info #1 [eng] h264 848x480 53:30 yuv420p, 23.98 fps, 0 Kbps
11:15:06.824 Group Video streams
11:15:06.841 Info #2 aac main audio 2 Ch., 48000 Hz, 0 Kbps - Unspecified
11:15:06.824 Group Audio streams
11:15:06.840 Info #3 0:0:2 - ass 720x576 - Unspecified
11:15:06.824 Group Subtitle streams
11:15:06.839 Warning DISCARDED #4 -
11:15:06.839 Warning DISCARDED #5 -
11:15:06.838 Warning DISCARDED #6 -
11:15:06.838 Warning DISCARDED #7 -
11:15:06.837 Warning DISCARDED #8 -
11:15:06.836 Warning DISCARDED #9 -
11:15:06.835 Warning DISCARDED #10 -
11:15:06.833 Warning DISCARDED #11 -
11:15:06.832 Warning DISCARDED #12 -
11:15:06.831 Warning DISCARDED #13 -
11:15:06.830 Warning DISCARDED #14 -
11:15:06.829 Warning DISCARDED #15 -
11:15:06.828 Warning DISCARDED #16 -
11:15:06.827 Warning DISCARDED #17 -
11:15:06.826 Warning DISCARDED #18 -
11:15:06.825 Warning DISCARDED #19 -
11:15:06.824 Warning DISCARDED #20 -
11:15:06.824 Group Discarded streams
11:15:06.824 Group Added file: H:\Anime\Baka Test\Baka to Test to Shokanjuu 01.mkv
11:14:59.837 Info Menu templates loaded: 36
11:14:59.069 Info Total Physical Memory : 8145 Mb.
Available Physical Memory : 6568 Mb.
Memory Load : 19%
Total Memory : 16289 Mb.
Available Memory : 14591 Mb.
11:14:59.069 Info Processor Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz with 4 core(s) CPU
Supported instruction set: MMX,sse,sse2,sse3,ssse3,sse41,sse42,avx,aes
11:14:59.062 Info OS : Windows 7 (64 bits), Build 7600, service pack 0.0
11:14:58.246 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoHD\1\templates"
11:14:58.245 ------------ ***************************ConvertXToHD.exe:5908 Log session start 2015-05-25 at 11:14:58.043***************************
11:17:09.002 Info No disc in drive.
11:17:07.693 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
11:17:07.693 Info Drive has Serial ATA physical interface
11:17:07.692 Info New Drive selected : [D] ASUS DRW-24B3ST 1.00 (ATAPI)
11:14:58.244 Info 1 writer(s) found.
11:14:58.228 Group Burn engine events
:library=false
:app_name=ConvertXToHD.exe
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=stopped
:group_indent=4
+-[audio aac main audio 2 Ch., 44100 Hz, 0 Kbps]
Input file: H:\Anime\Akame ga Kill! [HorribleSubs]\[HorribleSubs] Akame ga Kill! - 01 [720p].mkv
Video filters used:
- Scale filter: fast linear (vso). Fit method: letterbox (Padding: top: 0, bottom: 0, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
Video filters used:
Memory Load : 19%
