Conversion errors can't complete and what settings?
carnage6
Post by carnage6 »
Ok I'm trying to convert the new Transformers movie in H264 format to AVCHD 1080p format and I'm getting to about 4% and then it fails. I'm getting the message "Access violation at address 007E67D2 in module vsoVideoConverter.exe. Read of address 00000000."
What the heck is going on? Every time I click to close the error it keeps popping up after like 1 second.
I'm am trying to make a Blu-Ray out of this and I heard you should set it to AVCHD1080p for best compatibility. I also used the hardware decoders but after the first error it told me not to use that and I did but it didn't make a difference. I also set the target at 25G and the program said the estimate was around 11G.
If I'm making a Blu Ray and don't want loss of quality what should me settings be? I can't seem to find any threads or guides as to what I should be having my settings at.
Can anybody help me with these problems?
MyMojo
Re: Conversion errors can't complete and what settings?
Post by MyMojo »
Hi carnage, you'll probably need to post the log file. Do you know how to obtain it?
carnage6
Post by carnage6 »
No I don't.
MyMojo
Post by MyMojo »
No problem... To get a log/crash file, go to: "Help/Tools" -> "Show Log Events" -> "Open log folder..."
Once the folder is open, close VSO. This will allow you to copy the file if VSO is still attached to it.
Find the log that corresponds to the crash and post it as an attachment. You may need to duplicate the problem again to get a 'clean' log.
carnage6
Post by carnage6 »
Is this what I'm supposed to post? This is 2 different sessions.
00:31:27.942 Info Conversion process has been aborted by user
00:11:13.385 Info [ ] Loop playback
00:11:13.385 Info [x] Play titles one after the other
00:11:13.384 Info [ ] Don't create title menu for single video
00:11:13.383 Info [x] Return to title menu after titleset playback
00:11:13.382 Info [ ] Skip root menu initially
00:11:13.382 Info [x] Auto-start playback
00:11:13.381 Info Template: Black Mirror with video in top 1/3 of screen in root menu, contains 4 page(s)
00:11:13.381 Group Blu-ray/AVCHD menu options
00:11:13.381 Info Output target size : BD-25 (23000 MB)
00:11:13.380 Info Number of core(s) used for encoding : 8
00:11:13.380 Info Number of core(s) used for decoding : 8
00:11:13.379 Info [ ] Use 2 pass encoding
00:11:13.379 Info [x] Use best video quality settings
00:11:13.378 Info [ ] Use hardware encoding (if possible)
00:11:13.378 Info [ ] Use hardware decoding (if possible)
00:11:13.377 Info Max simultaneous conversions: 8
00:11:13.377 Group Advanced encoding options
00:31:27.873 Warning File encoding cancelled by user: 00000.m2ts
00:11:13.454 ------------ +--> [audio #2 - RAW copy]
+-[audio [eng] ac3 main audio 6 Ch., 48000 Hz, 384 Kbps]
+--> [video #1 - h264 video, 1920x1080, yuv420p, 245x102, 24.00Fps, 8640 Kbps [en]]
+-[video [eng] h264 1912x796 245:102 yuv420p, 23.98 fps, 0 Kbps]
Output file: C:\Users\Paul\Documents\VSO Video Converter\Transformers.Age.of.Extinction.2014.1080p.WEB-DL.DD51\AVCHD\BDMV\STREAM\00000.m2ts (AVCHD structure)
Input file: C:\Users\Paul\Videos\Transformers.Age.of.Extinction.2014.1080p.WEB-DL.DD51.H264.mkv
Video filters used:
- DeInterlace filter: FFmpeg
- Scale filter: linear (vso). Fit method: automatic (Padding: top: 0, bottom: 0, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
00:11:13.453 Info Chapters to generate: 22
00:11:13.376 Info Added in conversion queue list...
00:11:13.373 Info Menu fit: Text size reduced from 26.00 to 18.00 in style "caption"
00:11:13.296 Info Menu fit: Text size reduced from 36.00 to 27.00 in style "title"
00:11:13.047 Group ******************** Titleset #1 - ~165 min. File: "Transformers.Age.of.Extinction.2014.1080p.WEB-DL.DD51.H264" -> 00000.m2ts - AVCHD structure ********************|GK_TITLESET|
00:11:13.047 Info Encoding options: Short Projects (Automatic)
00:11:13.046 Info Target size: 22.85 Gb.
00:11:08.311 Group Conversion to "HD structures AVCHD 1080p" started at 12:11:13 AM: 1 sequence(s) to encode|GK_CONVERT_SESSION|
00:08:13.333 ------------ ************************vsoVideoConverter.exe:6580 Log session start 2014-09-20 at 00:08:13.298*************************
Earlier session with different settings:
06:18:23.812 ------------ ********vsoVideoConverter.exe:6832 Log session stop after 7 hour(s) 20 minute(s) 11 second(s) 177 millisecond(s)********
06:18:12.056 Info Conversion process has been aborted by user
05:58:13.227 Info [ ] Loop playback
05:58:13.225 Info [x] Play titles one after the other
05:58:13.223 Info [ ] Don't create title menu for single video
05:58:13.221 Info [x] Return to title menu after titleset playback
05:58:13.219 Info [ ] Skip root menu initially
05:58:13.217 Info [x] Auto-start playback
05:58:13.215 Info Template: Black Mirror with video in top 1/3 of screen in root menu, contains 4 page(s)
05:58:13.215 Group Blu-ray/AVCHD menu options
05:58:13.213 Info Output target size : BD-25 (23000 MB)
05:58:13.211 Info Number of core(s) used for encoding : 8
05:58:13.210 Info Number of core(s) used for decoding : 8
05:58:13.208 Info [ ] Use 2 pass encoding
05:58:13.206 Info [x] Use best video quality settings
05:58:13.204 Info [ ] Use hardware encoding (if possible)
05:58:13.203 Info [ ] Use hardware decoding (if possible)
05:58:13.201 Info Max simultaneous conversions: 8
05:58:13.201 Group Advanced encoding options
06:18:12.017 Warning File encoding cancelled by user: 00000.m2ts
05:58:13.312 ------------ +--> [audio #2 - RAW copy]
Video filters used:
05:58:13.310 Info Chapters to generate: 22
05:58:13.198 Info Added in conversion queue list...
05:58:13.194 Info Menu fit: Text size reduced from 26.00 to 18.00 in style "caption"
05:58:13.116 Info Menu fit: Text size reduced from 36.00 to 27.00 in style "title"
05:58:12.862 Group ******************** Titleset #1 - ~165 min. File: "Transformers.Age.of.Extinction.2014.1080p.WEB-DL.DD51.H264" -> 00000.m2ts - AVCHD structure ********************|GK_TITLESET|
05:58:12.861 Info Encoding options: Short Projects (Automatic)
05:58:12.859 Info Target size: 22.85 Gb.
05:54:28.881 Group Conversion to "HD structures AVCHD 1080p" started at 5:58:13 AM: 1 sequence(s) to encode|GK_CONVERT_SESSION|
05:54:28.841 Warning Conversion failed, user requested to disable "Allow multiple instances of hardware optimization" option
05:54:10.518 Info An error occured while converting
23:02:09.429 Info [ ] Loop playback
23:02:09.429 Info [x] Play titles one after the other
23:02:09.428 Info [ ] Don't create title menu for single video
23:02:09.427 Info [x] Return to title menu after titleset playback
23:02:09.426 Info [ ] Skip root menu initially
23:02:09.426 Info [x] Auto-start playback
23:02:09.425 Info Template: Black Mirror with video in top 1/3 of screen in root menu, contains 4 page(s)
23:02:09.425 Group Blu-ray/AVCHD menu options
23:02:09.425 Info Output target size : BD-25 (23000 MB)
23:02:09.424 Info Number of core(s) used for encoding : 8
23:02:09.424 Info Number of core(s) used for decoding : 8
23:02:09.423 Info [ ] Use 2 pass encoding
23:02:09.423 Info [x] Use best video quality settings
23:02:09.422 Info [ ] Use hardware encoding (if possible)
23:02:09.422 Info [x] Use hardware decoding (if possible)
23:02:09.421 Info Max simultaneous conversions: 8
23:02:09.421 Group Advanced encoding options
05:45:59.281 ------------ *****************************************File encoded successfully: 00000.m2ts******************************************
05:45:59.278 Error Unable to initialize menu
05:45:59.172 Error [muxer][bd]: time base not set
05:45:58.703 Error Unable to initialize menu
05:45:58.594 Error [muxer][bd]: time base not set
05:45:57.946 Error Unable to initialize menu
05:45:57.838 Error [muxer][bd]: time base not set
05:45:57.140 Error Unable to initialize menu
05:45:57.032 Error [muxer][bd]: time base not set
05:45:56.149 Error Unable to initialize menu
05:45:56.046 Error [muxer][bd]: time base not set
05:45:54.961 Info Building ROOTCHAPTERS, menus using template: Black Mirror with video in top 1/3 of screen in root menu
^^^Repeated 2 Times in 1 millisecond(s)^^^
05:45:54.611 Info video #1 - Processed video frames: 238378 (238614 frames encoded, 0 frames dropped, 238 frames duplicated)
23:02:09.687 Info h264: using hardware decoder adapter #0 - ATI Radeon HD 4800 Series , vendor 0x1002 (ATI), device 0x9440, revision 0
23:02:09.507 ------------ +--> [audio #2 - RAW copy]
+-[video dxva2 [eng] h264 1912x796 245:102 yuv420p, 23.98 fps, 0 Kbps]
Video filters used:
23:02:09.506 Info Chapters to generate: 22
23:02:09.418 Info Added in conversion queue list...
23:02:09.415 Info Menu fit: Text size reduced from 26.00 to 18.00 in style "caption"
23:02:09.339 Info Menu fit: Text size reduced from 36.00 to 27.00 in style "title"
23:02:09.088 Group ******************** Titleset #1 - ~165 min. File: "Transformers.Age.of.Extinction.2014.1080p.WEB-DL.DD51.H264" -> 00000.m2ts - AVCHD structure ********************|GK_TITLESET|
23:02:09.088 Info Encoding options: Short Projects (Automatic)
23:02:09.087 Info Target size: 22.85 Gb.
23:02:08.645 Group Conversion to "HD structures AVCHD 1080p" started at 11:02:09 PM: 1 sequence(s) to encode|GK_CONVERT_SESSION|
22:58:00.914 ------------ ************************vsoVideoConverter.exe:6832 Log session start 2014-09-18 at 22:58:00.879*************************
MyMojo
Post by MyMojo »
That should work, but the top portion of the log isn't there...are you using the latest version? If not, you can get it here and try again and see if it works: http://forums.vso-software.fr/latest-beta-t18294.html
Otherwise, Claire or Cedric will take a look at it when they can...probably Monday.
carnage6
Post by carnage6 »
Not sure what other information you need. I just copied and pasted. It is the latest version. Also tried converting Edge of Tomorrow MKV 1080p and it fails right away. What am I doing wrong here? Both things I tried failed. I love VSO products but I can't see why other people have no problems and everything I try to convert has problems. :(
carnage6
Post by carnage6 »
Nobody knows???
Any suggestions???
Hello carnage6,
Can you try with the last beta version (1.5.0.2)?
Thank you.
carnage6
Post by carnage6 »
You want me to downgrade?
1.5.0.2 is the very last version...
