Hello, I use v1.3.0.0.
When I create a custom profile (to make subtitle to be embedded), i can't edit the sub parameters (as the result, the sub will looks so tiny).
How can I fix it?
And when i try to not merge the sub, the result is so so baad...
thx, and sorry for my bad english.
Merged Subtitle is too small, can't be edited???
Re: Merged Subtitle is too small, can't be edited???
Hello deathsatans,
Have you tried with the latest beta, v1.4.0.2? Please do a fresh/clean install of it, and don't forget to have a copy of your key written down somewhere before doing so.
Thanks for reading,
Neil M
Thanks for reading,
Neil M
Yes, i have do a clean install of 1.4.0.2 but still have the same problem.
- if i choose DVD Video profile,
> i can edit the subtitle parameters
> but the result is a not good looking subtitle
- if i choose to create a new custom profile,
> i can embed / merge the sub with the video, the font look nice
> but the font size still TOO TINY, and I can't edit the parameters
What should I do? Can you show me the way?
Thank you.
Thank you.
Post log of conversion, and details of what type are your subs and video.
Video source : Advanced Video Codec 1.280 x 528 pixelsJJ wrote:Post log of conversion, and details of what type are your subs and video.
Subtitle : Srt
If I convert to DVD Video profile, the result subtitle is not looking good.
If I convert to a custom profile (DVD Video with merged sub), the result subtitle is good but looks so tiny. When I try to edit the subs parameters it will say "You can't change subtitle parameters when audio conversion profile is selected. Select another encoder profile to enable subtitle editor."
That is what I mean. Is there any solution?
You did not post conversion log.
That is required for proper analyze.
[quote="JJ"]You did not post conversion log.
That is required for proper analyze.[/quote]
Ok i try to convert a video with merged sub, and here the log file :
:crash_log='C:\Documents and Settings\All Users\Application Data\VSO\VSO Video Converter\1\Log\VSO Video Converter 1_crashlog_.20140624.074934.250.log'
:library=false
:app_version=1.4.0.2
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
07:50:27.181 ------------ +--> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch., 448 Kbps [en]]
+-[audio [eng] dts main audio 5.1 Ch., 48000 Hz, 768 Kbps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, 29.97Fps, 5450 Kbps [un]]
¦-[video h264 1280x544 40:17 yuv420p, 23.98 fps, 0 Kbps]
+-[subtitle 0:1:0 - srt 720x576]
Output file: D:\MOVIES\ON PROCESS\Tai Chi Zero (2012) DTS 5\VIDEO_TS\VTS_01_1.VOB
Input file: D:\MOVIES\DONE ON NEW\Tai Chi Zero (2012) DTS 5.1CH\Tai Chi Zero (2012) DTS 5.1CH.mkv
Video filters used:
- DeInterlace filter: FFmpeg
- Scale filter: windowed sinc lanczos (vso). Fit method: panscan (Padding: top: 0, bottom: 0, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 88, right: 88)
07:50:27.031 Info Added in conversion queue list...
07:50:26.872 Group ******************** Titleset #1 - ~98 min. File: "Tai Chi Zero (2012) DTS 5.1CH" -> VTS_01_1.VOB ********************|GK_TITLESET|
07:50:26.138 Group Conversion to "Custom profiles DVD NTSC 16:9 Dolby® Digital 5.1" started at 7:50:27 AM: 1 sequence(s) to encode|GK_CONVERT_SESSION|
07:49:42.090 Info Total Physical Memory : 2974 Mb.
Available Physical Memory : 1644 Mb.
Memory Load : 44%
Available Virtual Memory : 1879 Mb.
Total Memory : 7276 Mb.
Available Memory : 5703 Mb.
07:49:42.089 Info Processor Genuine Intel(R) CPU U4100 @ 1.30GHz with 2 core(s) CPU
Pipeline(s): 2 - parallelize up to 2
Supported instruction set: MMX,sse,sse2,sse3,ssse3 (slow)
07:49:42.059 Info OS : Windows XP (32 bits), Build 2600, service pack 3.0
file name : C:\Program Files\VSO\VSO Video Converter\1\vsoVideoConverter.exe
file version : 1.4.0.2
07:49:34.389 Group Burn engine events
07:49:34.250 ------------ ************************vsoVideoConverter.exe:2976 Log session start 2014-06-24 at 07:49:33.812*************************
:library=false
:most_recent=first
:status=started
:group_indent=4
Video filters used:
Memory Load : 44%
