Blu ray menu
calcu007
Blu ray menu
Post by calcu007 »
I creatde a blu ray and used simple menu. The menu dont work in my software blu ray player, it freezes. I tried black mirror temple and same problem
:crash_log='C:\ProgramData\VSO\VSO Video Converter\1\Log\VSO Video Converter 1_crashlog_.20140428.012025.666.log'
:library=false
:app_version=1.2.0.15
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
04:23:38.389 Info Total converted files size: 1.74 Gb.
04:23:38.027 Info Menu built successfully
04:18:41.978 Error [muxer][bd]: H.264 bitstream malformed, no startcode found, use the h264_mp4toannexb bitstream filter (-bsf h264_mp4toannexb)\n
04:18:37.631 Info Building TITLE menu
01:32:05.877 Info BD menu template: Default, simple menu
04:01:20.787 ------------ File encoded successfully: 00001.m2ts - c:\users\alexis\downloads\torrents\caribbean-032614-569-hd\032614-569-carib-high_1 - (HD structuresBlu-ray 1080p)
04:01:20.754 Info Menu built successfully
03:55:27.921 Error [muxer][bd]: H.264 bitstream malformed, no startcode found, use the h264_mp4toannexb bitstream filter (-bsf h264_mp4toannexb)\n
03:55:20.071 Info Menu built successfully
03:48:30.893 Error [muxer][bd]: H.264 bitstream malformed, no startcode found, use the h264_mp4toannexb bitstream filter (-bsf h264_mp4toannexb)\n
03:48:20.620 Info Menu built successfully
03:41:23.379 Error [muxer][bd]: H.264 bitstream malformed, no startcode found, use the h264_mp4toannexb bitstream filter (-bsf h264_mp4toannexb)\n
03:41:14.158 Info Menu built successfully
03:34:36.536 Error [muxer][bd]: H.264 bitstream malformed, no startcode found, use the h264_mp4toannexb bitstream filter (-bsf h264_mp4toannexb)\n
03:34:34.919 Info Menu built successfully
03:32:34.344 Error [muxer][bd]: H.264 bitstream malformed, no startcode found, use the h264_mp4toannexb bitstream filter (-bsf h264_mp4toannexb)\n
03:32:32.416 Info Menu built successfully
03:31:41.766 Error [muxer][bd]: H.264 bitstream malformed, no startcode found, use the h264_mp4toannexb bitstream filter (-bsf h264_mp4toannexb)\n
03:31:40.595 Info Building ROOTCHAPTERS, menus using template: Default, simple menu
03:31:40.404 Info video #1 - Processed video frames: 254573 (101932 frames encoded, 0 frames dropped, 0 frames duplicated)
01:32:07.175 Info h264: using hardware decoder adapter #0 - NVIDIA GeForce GT 745M , vendor 0x10DE (NVIDIA), device 0x0FE3, revision 161
01:32:06.818 ------------ +-> [audio #2 - ac3 audio, 48000Hz, 2 Ch., 192 Kbps [un]]
+-- [audio aac main audio Stereo, 48000 Hz, 170 Kbps]
+-> [video #1 - h264_cuda video, 1920x1080, yuv420p, 16x9, 24.00Fps, 8640 Kbps [un]]
+-- [video dxva2 h264 1920x1080 16:9 yuv420p, 59.94 fps, 5001 Kbps]
Output file: C:\Users\Alexis\Documents\VSO Video Converter\Yui Kyono, Maki Takei\BDMV\STREAM\00001.m2ts
Input file: c:\users\alexis\downloads\torrents\caribbean-032614-569-hd\032614-569-carib-high_1.mp4
Video filters used:
- DeInterlace filter: FFmpeg
- Scale filter: linear (vso). Fit method: automatic (Padding: top: 0, bottom: 0, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
01:32:06.813 Info Chapters to generate: 14
01:32:05.970 Group ******************** Yui Kyono -> ********************|GK_CONVERT_SESSION|
04:18:37.210 ------------ File encoded successfully: 00000.m2ts - c:\users\alexis\downloads\torrents\carib-042614-589\042614-589-carib-high_1 - (HD structuresBlu-ray 1080p)
04:18:37.171 Info Menu built successfully
04:13:28.451 Error [muxer][bd]: H.264 bitstream malformed, no startcode found, use the h264_mp4toannexb bitstream filter (-bsf h264_mp4toannexb)\n
04:13:23.686 Info Menu built successfully
04:06:40.584 Error [muxer][bd]: H.264 bitstream malformed, no startcode found, use the h264_mp4toannexb bitstream filter (-bsf h264_mp4toannexb)\n
04:06:34.851 Info Menu built successfully
03:59:15.831 Error [muxer][bd]: H.264 bitstream malformed, no startcode found, use the h264_mp4toannexb bitstream filter (-bsf h264_mp4toannexb)\n
03:59:05.209 Info Menu built successfully
03:49:14.848 Error [muxer][bd]: H.264 bitstream malformed, no startcode found, use the h264_mp4toannexb bitstream filter (-bsf h264_mp4toannexb)\n
03:49:04.108 Info Menu built successfully
03:39:55.755 Error [muxer][bd]: H.264 bitstream malformed, no startcode found, use the h264_mp4toannexb bitstream filter (-bsf h264_mp4toannexb)\n
03:39:44.072 Info Menu built successfully
03:35:12.950 Error [muxer][bd]: H.264 bitstream malformed, no startcode found, use the h264_mp4toannexb bitstream filter (-bsf h264_mp4toannexb)\n
03:35:06.434 Info Building ROOTCHAPTERS, menus using template: Default, simple menu
03:35:05.718 Info video #1 - Processed video frames: 258710 (103588 frames encoded, 0 frames dropped, 0 frames duplicated)
01:32:07.003 Info h264: using hardware decoder adapter #0 - Intel(R) HD Graphics Family, vendor 0x8086 (Intel), device 0x0A16, revision 9
01:32:06.122 ------------ +-> [audio #2 - ac3 audio, 48000Hz, 2 Ch., 192 Kbps [un]]
+-- [audio aac main audio Stereo, 48000 Hz, 169 Kbps]
Output file: C:\Users\Alexis\Documents\VSO Video Converter\Yui Kyono, Maki Takei\BDMV\STREAM\00000.m2ts
Input file: c:\users\alexis\downloads\torrents\carib-042614-589\042614-589-carib-high_1.mp4
Video filters used:
01:32:06.117 Info Chapters to generate: 14
01:32:05.940 Group ******************** Maki Takei -> ********************|GK_CONVERT_SESSION|
01:32:05.937 ------------ ***************************************************Menu settings end****************************************************
01:32:05.935 Info [ ] Loop playback
01:32:05.933 Info [x] Play titles one after the other
01:32:05.930 Info [ ] Don't create title menu for single video
01:32:05.928 Info [x] Return to title menu after titleset playback
01:32:05.926 Info [x] Skip root menu initially
01:32:05.924 Info [x] Auto-start playback
01:32:05.922 Info Template: Default, simple menu, contains 4 page(s)
01:32:05.920 ------------ **************************************************Menu settings begin***************************************************
01:32:05.918 Info Output target size : BD-25 (23000 MB)
01:32:05.916 Info Number of core(s) used for encoding : 4
01:32:05.914 Info Number of core(s) used for decoding : 4
01:32:05.912 Info [ ] Use 2 pass encoding
01:32:05.911 Info [x] Use best video quality settings
01:32:05.909 Info [x] Use hardware encoding (if possible)
01:32:05.907 Info [x] Use hardware decoding (if possible)
01:32:05.905 Info Max simultaneous conversions: 4
01:29:32.781 Group Blu-ray/AVCHD Video encoding session started at 1:32:05 AM: 2 sequence(s) to encode|GK_CONVERT_SESSION|
01:29:20.480 Info No disc in drive.
01:29:18.508 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
01:29:18.503 Info Drive has Serial ATA physical interface
01:29:18.500 Info New Drive selected : 0:0:0 - MATSHITA DVD-RAM UJ8C2 S 1.00 [D] (Scsi)
01:29:18.498 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
01:29:18.493 Info Drive has Serial ATA physical interface
01:29:18.488 Info New Drive selected : 0:0:0 - MATSHITA DVD-RAM UJ8C2 S 1.00 [D] (Scsi)
01:28:43.211 Info No disc in drive.
01:28:41.242 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
01:28:41.237 Info Drive has Serial ATA physical interface
01:28:41.234 Info New Drive selected : 0:0:0 - MATSHITA DVD-RAM UJ8C2 S 1.00 [D] (Scsi)
01:28:41.232 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
01:28:41.227 Info Drive has Serial ATA physical interface
01:28:41.222 Info New Drive selected : 0:0:0 - MATSHITA DVD-RAM UJ8C2 S 1.00 [D] (Scsi)
01:28:11.356 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
01:28:11.350 Info Drive has Serial ATA physical interface
01:28:11.347 Info New Drive selected : 0:0:0 - MATSHITA DVD-RAM UJ8C2 S 1.00 [D] (Scsi)
01:28:11.346 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
01:28:11.344 Info Drive has Serial ATA physical interface
01:28:11.341 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
01:28:11.333 Info Drive has Serial ATA physical interface
01:28:11.329 Info New Drive selected : 0:0:0 - MATSHITA DVD-RAM UJ8C2 S 1.00 [D] (Scsi)
01:28:11.327 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
01:28:11.320 Info Drive has Serial ATA physical interface
01:28:07.973 Info New Drive selected : 0:0:0 - MATSHITA DVD-RAM UJ8C2 S 1.00 [D] (Scsi)
^^^Repeated 2 Times in 3 second(s) 339 millisecond(s)^^^
01:21:17.988 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
01:21:17.984 Info Drive has Serial ATA physical interface
01:21:17.979 Info New Drive selected : 0:0:0 - MATSHITA DVD-RAM UJ8C2 S 1.00 [D] (Scsi)
01:21:17.977 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
01:21:17.950 Info Drive has Serial ATA physical interface
01:21:17.938 Info New Drive selected : 0:0:0 - ASUS BW-12D1S-U E102 [E] (Usb)
01:21:17.936 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
01:21:17.919 Info Drive has Serial ATA physical interface
01:21:17.915 Info New Drive selected : 0:0:0 - MATSHITA DVD-RAM UJ8C2 S 1.00 [D] (Scsi)
01:20:40.538 Info No disc in drive.
01:20:38.691 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
01:20:38.687 Info Drive has Serial ATA physical interface
01:20:38.683 Info New Drive selected : 0:0:0 - MATSHITA DVD-RAM UJ8C2 S 1.00 [D] (Scsi)
01:20:38.681 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
01:20:38.653 Info Drive has Serial ATA physical interface
01:20:38.642 Info New Drive selected : 0:0:0 - ASUS BW-12D1S-U E102 [E] (Usb)
01:20:38.641 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
01:20:38.637 Info Drive has Serial ATA physical interface
01:20:38.634 Info New Drive selected : 0:0:0 - MATSHITA DVD-RAM UJ8C2 S 1.00 [D] (Scsi)
01:20:38.598 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
01:20:38.594 Info Drive has Serial ATA physical interface
01:20:38.591 Info New Drive selected : 0:0:0 - MATSHITA DVD-RAM UJ8C2 S 1.00 [D] (Scsi)
01:20:38.588 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
01:20:38.560 Info Drive has Serial ATA physical interface
01:20:38.549 Info New Drive selected : 0:0:0 - ASUS BW-12D1S-U E102 [E] (Usb)
01:20:38.548 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
01:20:38.544 Info Drive has Serial ATA physical interface
01:20:38.541 Info New Drive selected : 0:0:0 - MATSHITA DVD-RAM UJ8C2 S 1.00 [D] (Scsi)
01:20:31.137 Info Using Advanced SPTI interface
01:20:31.137 Group Burn engine events
01:20:31.136 Info Total Physical Memory : 8075 Mb.
Available Physical Memory : 6018 Mb.
Memory Load : 25%
Available Virtual Memory : 3815 Mb.
Total Memory : 9355 Mb.
Available Memory : 7062 Mb.
01:20:31.136 Info Processor Intel(R) Core(TM) i7-4500U CPU @ 1.80GHz with 4 core(s) CPU
01:20:31.112 Info OS : Windows 8 (64 bits), Build 9200, service pack 0.0
file name : C:\Program Files (x86)\VSO\VSO Video Converter\1\vsoVideoConverter.exe
file version : 1.2.0.15
01:20:25.659 ------------ ************************vsoVideoConverter.exe:2700 Log session start 2014-04-28 at 01:20:25.619*************************
Re: Blu ray menu
In your computer does the menu freeze?
What is the brand and model of your player?
When exactly does it freeze?
calcu007
Re: Blu ray menu
Post by calcu007 »
When I hit menu in my computer it shows a lot of colors line pixelation, but not the menu. I had to close the program. I use Arcsoft TotalTheater 6 in my computer. With my TV I use panasonic dmp-bd871 and the menu dont loads. If I use black mirror with video I receive a black screen
Re: Blu ray menu
Edit - should be fixed 1.2.0.19 available here
http://forums.vso-software.fr/latest-be ... 17957.html
