Will not exit "Burn engine" window.
lasitter
Post by lasitter »
Just downloaded, installed and registered Video Encoder, and converted one video with the option to output ISO. Conversion seems to have gone perfectly, and the .ISO was created, but now no matter how many times I hit Cancel/Yes, my only way out was to kill the process. Ideas?
Should I try the beta?
Win7 Pro x64.
Re: Will not exit "Burn engine" window.
I would, since the production version is sometimes a few mini released behind the ßetas, and the latest ßetas has lots of fixes in them.
I always run the ßeta to see if the issue is still there and if it is, I know it still needs to get fixed :)
This is a bug unfortunately.
The reference is http://bugs.vso-software.fr/view.php?id=7882
(check for bug 7882 to be fixed in the history/ change log)
if you want to connect to the bug site create a new account ... it is a different database than the forum.
