Can't edit the DVD/Bluray menus' texts
minhcute
Post by minhcute »
Dear VSO Team
I can't edit the DVD/Bluray menus' texts in VSO Video Converter ( In ConvertXToDVD,I can do this very easy ).Can you surmount this small problem in the next version of VSO Video Converter ?
Re: Can't edit the DVD/Bluray menus' texts
I don't think any change soon will be done in the software for you to be able to do this.
It will be added in the future but I don't know in what form.
But we are aware of your request - thank you.
I am sorry. I might not have understood what you meant exactly, but you can change the name of the files as they appear in the menu by editing the name: right click or press F2, maybe this is what you wanted.
minhcute
Post by minhcute »
After viewing these pictures,you will understand what I wanna suggest for you :
Wait for your reply
Best regards
9
8
8
7
7
6
6
5
5
4
4
3
3
2
2
1
1
thanks for adding the additional information, that is what I had originally understood.
