Why "CopyTo" Context Menu in VSO Media Player 1.3.7.467?
saad
Post by saad »
I just installed your Media Player. I noticed that it has created a Context Menu for your CopyTo program. I uninstalled your Media Player and the "CopyTo' context Menu was gone. By the way, I never had your CopyTo program installed on my system. Please see the attached snapshot.
saad
Re: Why "CopyTo" Context Menu in VSO Media Player 1.3.7.467?
Post by saad »
I downloaded the version 1.3.7.467 from the main VSO Media Player download link. The info is incorrect & still shows 1.3.5.461. It's supposed to be 1.3.7.467.
Thanks for reporting these two things.
The version number has now been updated.
saad
Post by saad »
By the way download showing wrong installation-size. It is 19.4 MB not 13 MB.
will be fixed, thanks
saad
Post by saad »
The "CopyTo" context menu still shows up in the latest version of VSO Media Player. If you use this for advertising purposes, you should think of a better way.
