Main title is doing English cast commentary
jallmitch
Post by jallmitch »
I have done about 20 different dvd's selecting the "Main" title, and never changing any of the additional settings. I have found 2 separate DVD's that have seemed to pull the commentary into the main movie by default. One one of the DVD's I unchecked the "Main" and selected the "Subtitle" movie and received the same result. I am using the latest version of DVD Converter & AnyDVD. Does anyone have any ideas on what could be causing this?
Re: Main title is doing English cast commentary
What is the version you are referring to? 1.4.0.8 or beta 2.0.0.10?
What are the names of the two movies giving you this problem? What format are you converting to?
If you do try the beta version 2 you can play in the preview the movie and during that playback time select the different audio and subtitle tracks, this will allow you to make sure the right one is selected before converting.
http://forums.vso-software.fr/dvd-converter-t14598.html
reported by jallmitch as fixed with version 2
