Newbie, is this the right product for me?
jimbro
Post by jimbro »
Hi All
I've been trawling around the web for a while trying to decide on which S/W to buy for my needs
I'm looking for something that can rip a Bluray to a single avi file for conversion to DVD
or
Can rip a Bluray to avi but is simple to use for converting to DVD
I use Nero 11 Platinum for burning and my basic setup is
Windows 7 Ultimate 64 bit
Intel i7-2600k Sandybridge
16GB HyperX RAM
Combo DVD/CD burner
8 x Bluray burner
so PC spec is not an issue
Do you think VSO Blu-ray Converter Ultimate will do the job?
Certainly seems to be lots of support via the forums if I have any questions
Re: Newbie, is this the right product for me?
Welcome to the forum.
Yes it will do the job, but you can also convert your Blu-ray directly to DVD instead of converting to an avi first.
jimbro
Post by jimbro »
Thank You Claire, sounds like this is what I've been looking for
Jim
jimbro
Post by jimbro »
Just ordered it and activated the downloaded SW
I'll try it out over the weekend
Be prepared for LOTS of questions :lol:
No, you will be fine, but of course we are here if you need help.
jimbro
Post by jimbro »
WOW, this SW rocks
Makes the whole process so simple(even I can manage it)
Also lets me utilise all 8 cores on my CPU so it's fast fast fast
Found a free utility for decrypting, DVDFab Passkey
It runs on the fly and just does the job
Thank You VSO
oh cool! Thanks for the feedback.
We are pleased to hear you like the software!
