Unable to create ISO Image
pepero_boy
Post by pepero_boy »
Hi everyone!,
Well, my problem is as follows:
I used to select "ISO image in working folder" option in "Burn result to DVD" in the Burning tab in Settings, but now it doesn't work anymore, I select it and click OK, and when reopen the tab to check if changes have been saved, my DVD RW Drive appears selected again instead.
What do I do? I don't want to bur them directly with ConvertXtoDVD, my DVD Writer is kind of "special" and it works well just with IMGBurn =/
That's everything.
Thank you in advance~ ! :B
Re: Unable to create ISO Image
You are using ConvertXtoDVD? You posted in the DVD converter section instead of ConvertXtoDVD.
Are you using the latest version? In version 4.1.19.365, you need to check Add "ISO FIle" destination to drive list
and also Burn result to DVD or as an ISO file in working folder
