Problems with 1.2.1.19 & 1.2.1.21
jockmacmad
Post by jockmacmad »
Hi all
I just upgraded to 1.2.1.19 and have a problem. When I get to the settings pane the Video Quality: drop down is empty, selecting reveals there are no entries in it. IF I ignore this and hit and hit convert I get an error popup saying 'List index out of bounds (-1)'. If I hit okay the convert button disappears. I have tried changed just about all the settings to no avail.
I then installed 1.2.1.21 Beta and have exactly the same issue.
Can you help.
EDIT : Rolling back to 1.2.1.14 works again.
jockmacmad
Re: Problems with 1.2.1.19 & 1.2.1.21
Anyone ?
danielemccabe
Post by danielemccabe »
I HAVE THE SAME PROBLEM. i've tried uninstalling, everything i can think of. nothing works. can i have the old version back? itk worked fine. Really annoying.
MarkE
Post by MarkE »
I'm getting the same problem and also when programs starts up I get "list index out of bounds (2)"
is this problem solved in 1.3.0.1 ?
This should could be solved in 1.3.0.2 that is now available - please confirm.
