ReMux Mode taking an hour per film?
BenieUK
Post by BenieUK »
Should it really take this long from 2 HDDs in RAID0 to a SATA 3 SSD ?
Also video is coming out 1920 x 1088.. and in AVI mode it allows you to pick a sub but its not in the AVI as it would have to be re-encoded..
Re: ReMux Mode taking an hour per film?
hi,
it s the first remux profile and is in beta stage, subtitles are not yet managed.
Enabling the preview will decrease remuxing speed because input video must be decoded.
have you tried to do a remux with preview disabled?
thanks
BenieUK
Post by BenieUK »
Hi, Yes preview is already off when it starts the remux, but have just found out if you turn preview on then back off it speeds right up!
Before i was getting 48 Fps now with preview off 1250 Fps... it only takes a couple mins BUT it never finishes? Just says remaining 2 seconds but stays like that .
Thank You
Confirmed your problem that it never finishes just remains at 1second remaining. Will be corrected soon.
http://bugs.vso-software.fr/view.php?id=4836
All problems (preview & muxing process never finished) are fixed in last beta version (1.2.1.21) :
http://forums.vso-software.fr/blu-ray-c ... s-f36.html
Thank you for your help!
0xdeadbeef
Post by 0xdeadbeef »
Tried 1.2.1.21 today with Inception and ReMux mode never finished (3 seconds left) although the MKV seems to be complete.
BTW: there should be an option for the ReMux mode to convert e.g. DTS HD tracks.
As a side note: I also tried the Cuda 1080p conversion but it stopped immediately. It only worked when I also enabled Cuda decoding in the advanced settings...
