Question about audio quality
expanium
Post by expanium »
video audio 128 Kbit/s is equivalent to 128 Kbit/s MP3?
Gracias por responder.
Re: Question about audio quality
Are you talking about audio bitrate setting in custom profile editor?
If yes, this setting is a bitrate "by channel" value, that mean if you set it to 128Kb/s you will have a 256Kb/s audio stream for stereo.
PS: I will change the audio bitrate setting in custom profile editor because it seems that a lot of users don't understand how it works.
expanium
Post by expanium »
Gracias cedric,
Bearing in mind that 128 kbps is a mediocre quality, you should increase the bitrate.
Saludos!
Hello expanium,
"Bearing in mind that 128 kbps is a mediocre quality" : It seems you don't understand this setting...
Keep in mind that if you set bitrate setting to 128Kb/s (bitrate by channel), you will have 128Kb/s audio file for mono, but 256Kb/s audio file for stereo, 768Kb/s for 5.1 file.
