2.00105 crashes with CUDA?
wtin
Post by wtin »
My computer:
ThinkStation
Xeon E5-2680 V3 (2 sockets, 24 cores, 48 logical processors)
128 G of RAM
Quadro K5200 Driver 30.0.14.7444 (11th May 2023)
Windows 11 22h2 22621.1992
ConvertXtoVideo 2.00105
This version fails on converting MP4 (downloaded with StreamFab 64 bit) with:
Hardware Optimizations: On
Maximum of hardware decoder: 2
CUDA Nb: 2
NVENC Nb: 2
Under conversion settings:
Number of used cores for decoding: 32
Number of used cores for encoding: 32
Maximum simultaneous conversion: 2
Minimum free memory: 200
Muxel buffer size: 310
Smart copy (under Blu-Ray): Disable - always encode
I tried different setting even turning off HW decoder off (use CPU only, and even to one CPU core at a time), the program crashes.
I suppose the upcoming 64 bit should fix this. Would love to beta test it as my computer is pretty maxed out for what it is.
Katia
Re: 2.00105 crashes with CUDA?
Post by Katia »
Need to see your log file and probably the source mp4 file to identify the reason. You can contact support for it at support@vsosoftware.fr
Also, do you have conversion fail during conversion or at the very beginning, before it starts? It's not the same thing.
VSO Support Team
wtin
Post by wtin »
hi Katia,
In the middle of the file. It was my fault for not being totally thorough about this. I uninstalled the program, and installed it back, and it still happened. Uninstalled again to rollback the activation, then I wiped the hard drive clean, and downgrade it to Windows 10. With it being the only program, I tried to play the source file with VLC player. Well, I could have kicked myself - it crashed in the middle of the file (play error), at the same spot, too. So it wasn't the 2.00105's fault at all.
Redownloaded it and it's fine. It's the Star Trek t.v. show. Their new one.
Now I have a clean Windows 10 (with just my programs that I really need instead of useless ones), and it's working fine.
Thank you for reaching out. Am looking forward to the next version.
Wtin
