Convertxtodvd converts to small
Grandad1
Post by Grandad1 »
Im using Version of ConvertXtodvd 7.0.0.59 and try to convert 2 different MKV to Video_Ts Put the conversion on DVD 5 also try DVD 9 and manua on 4,300 GB but the result is always 2.71 GB.
My question how do i get it to let it convert it to a Full DVD 5
Re: Convertxtodvd converts to small
You get whatever output the software makes. As far as I know, there's no way to control the output settings so you get X size to increase or decrease file output size. And sometimes the software puts out smaller values. Sometimes, you'll feed it a really small file and get output that's DVD-9 size. It's down to the input file you use. How it was encoded, how many audio streams, it has, and how long a running time it has.
Grandad1
Post by Grandad1 »
Ok thanks fore the answer
