Trying to write on 8.5GB DVD+R DL
robertg_s
Post by robertg_s »
I am trying to burn a project on 8.5GB DVD as it recommended I use a DVD-9 it has worked in the past but I get the following:
Init DVD+R Dual Layer: Layer change set to LBA 1826592 (3.48 GB.)
Laser Power Calibration Failed: OS error: The request could not be performed because of an I/O device error
Write speed set at x4.0 (5540 kB/s)
layer break set by filesystem builder at 1826592
Available write speed: x6.0 (8310 kB/s) *, x4.0 (5540 kB/s), x3.0 (4155 kB/s)
Media ID: RITEK-S04-42
Layer break is proposed in cell boundary at Titleset #1, PGC #1, Cell #6, vobu #17983, sector #1826592, at time 02:29:51
Scanned files #11, folder #2 - total size 5061560320 b. (4.71 GB.)
Inserted media type : dvd+r dual layer
Volume ID: 6429
Folder: C:\Users\Robert\Documents\ConvertXtoDVD\6429\
Write started
DVD Video burn process started
Writable disc dvd+r dual layer inserted. Ready to write
Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
Drive has Serial ATA physical interface
New Drive selected : [D] HL-DT-ST DVD+-RW GU90N A1C3 (SATA)
I was hoping someone might have an idea on what I should do or just scrap this movie? If you require more information I will try to get it.
Robert
Re: Trying to write on 8.5GB DVD+R DL
Hi, the only comment i can make (because i rarely burn dual layer media) is use high end quality.
Verbatim or Taiyo Yuden (sold online) never seen in local store here.
These 2 brand media has never failed me in decades...
https://www.bestbuy.ca/en-ca/product/ve ... 2/12296753
AZO die is one if the best I hear, why Verbatim are expensive but worth every $$
https://www.duplication.ca/Verbatim-8X- ... -50pk.html
Media code (MID): MKM-003-00
robertg_s
Post by robertg_s »
Thanks Cougar I had some Verbatim 8.5 GB DL DVDs here tried and it worked that time. I had used the Fuji DVDs before and they had worked before. But thanks to you I got it done and will not be burning movies that require dual layer again any time in the immediate future, but will use only the Verbatim if I do.
Take care and stay safe.
Robert
Verbatim DVD+R DL is the only reliable double layer DVD media out there. If Taiyo Yuden makes DVD+R DL, which as far as I knew it didn't, that would probably be quality media, too. I also had good results with TDK's, but I don't know if they still make them. For over 10 years, I've used mostly Verbatim DataLife Plus (NOT the Life Series you find stores. Those are junk.) testing 2 other kinds here and there. The Office Depot ones were unreadable after a year but as I said the TDK ones were still good after a few years.
I'm a beta tester of ImgBurn, and a good majority of the problems we see on the forum there are from cheap (Usually CMC like the Life Series.) double layer DVD media.
