Save ConvertXtoDVD Project
Peg
Post by Peg »
I hit "SaveConvertXtoDVD Project", and accidentally hit "Remember My Choice"!
Now the program will never let me close with saving my project! I have to go to Task Manager and end the program manually.
How can I change this? I don't want to RESET MY VSO DEFAULTS, because I've made a lot of tweaks to it. I just want it to stop remembering my choice!
Re: Save ConvertXtoDVD Project
Which version are you using ?
How did you get to "Remember My Choice" In which menu ?
wtin
Post by wtin »
Download the latest version (or the same) and reinstall it. Choose the option(s) of clearing the settings.
I did this once a while ago.
Ch3vr0n
Post by Ch3vr0n »
clearing the settings is exactly the same as "VSO defaults". Afaik the setting under Global Settings > Visual Interface > "remember advanced check statusses" is the proper one. UNTICK that one, and the dialogue should pop up again next time. You can then redo it, the proper way :)
Desktop: Project Phoenix
