ConvertXToDVD 6 Stopprd Working
BlackKnight8
Post by BlackKnight8 »
This program has been working fine till a couple of days ago, now it just won't open.
It says, A problem has stopped the program opening, but it doesn't tell me what the problem is.
I've tried re-installing it from the disc, but it just comes up with the same screen.
Hope you can resolve this.
Regards.
Re: ConvertXToDVD 6 Stopprd Working
Has your system been updated?
You might need to remove all traces of CxDVD, reboot, then reinstall and use your key to activate.
