ConvertXtoDVD V6 opens OneDrive?
NBTBRV8
Post by NBTBRV8 »
How can I stop OneDrive opening when I run ConvertXtoDVD? It pops open automatically.
Re: ConvertXtoDVD V6 opens OneDrive?
Have you saved or loaded something from OneDrive?
CxD is not using OneDrive, but if last folder is there then it might try to open it.
NBTBRV8
Post by NBTBRV8 »
JJ wrote:Have you saved or loaded something from OneDrive?
No I don't even have an account. When I click on "Add Video File" it opens Microsoft OneDrive with a popup window to login and the cloud icon appears in my system tray.
Someone has opened file/s from OneDrive, Windows and CxD keeps last opened folder.
It should go away if you simply close those login windows and select any video file that is in your computer to convert.
No need to burn, you can delete end result but next time it should open that folder instead of OneDrive.
NBTBRV8
Post by NBTBRV8 »
JJ wrote:Someone has opened file/s from OneDrive, Windows and CxD keeps last opened folder.
But I don't have a one drive login and have never used it.
Microsoft pushes OneDrive with Windows10 quite aggressively, every system has it and it tries to make you login.
You can disable it, open OneDrive icon from taskbar (beside clock) and unselect "start with windows".
NBTBRV8
Post by NBTBRV8 »
JJ wrote:Microsoft pushes OneDrive with Windows10 quite aggressively, every system has it and it tries to make you login.
It was already unchecked.
Support on here found that whenever I went to open any form of media it popped open. So I have uninstalled Onedrive and this appears to have stopped it.
Good that it got solved.
This means that OneDrive was set as default to open lot of media.
NBTBRV8
Post by NBTBRV8 »
JJ wrote:Good that it got solved.
Yes I couldn't find anywhere to turn it off as it wasn't set to run on start-up. So I just uninstalled it as I have never used it. It must have been a Windows 10 forced updated.
