Convert X to DVBD 6
vdbergha
Convert X to DVBD 6
Post by vdbergha »
If I own background image use for my menu and I convert it to a DVD has been replaced by the menu for a standard menu and my own menu disappeared. How do I fix it?
felicia
Re: Convert X to DVBD 6
Post by felicia »
vdbergha wrote:If I own background image use for my menu and I convert it to a DVD has been replaced by the menu for a standard menu and my own menu disappeared. How do I fix it?
Where do you set the background image?
vdbergha
Post by vdbergha »
as background image in a standard menu
vdbergha wrote:as background image in a standard menu
I think you should let Felicia know what procedure you have used to change the background.
