Error about halfway every time i try to burn.
shifterphights
Post by shifterphights » Thu Feb 02, 2017 2:19 pm
Pretty sure this is the log. I have tested the DVD drive and it plays DVD no problem and also have the best Verbatim discs before anyone suggest that. Is it the drive? Any help is appreciated.
2017-01-15 10:40:44 ---- ******************** Log session stop 2017-01-15 10:40:44.856 PID 9136********************
2017-01-14 14:13:05 Error BURN: WRITE FAILED: write error occured at 43.6 percent of the write
2017-01-14 14:12:43 Error BURN: Write error at 319216 (16) - Code 05 21 02 [Illegal request, Invalid address for Write]
2017-01-14 14:09:27 Info BURN: Lead-in burning time (mS) 51675
2017-01-14 14:08:35 Info BURN: Write started 731648 sectors to write
2017-01-14 14:08:35 Info BURN: Init success: DVD-R SAO
2017-01-14 14:08:35 Info BURN: Writing speed requested x8.0, effective x8.0
2017-01-14 14:08:35 Info BURN: Available write speed: 8x ,4x
2017-01-14 14:08:35 Info BURN: Media ID: CMC MAG. AM3
2017-01-14 14:08:35 Info BURN: Media type: DVD-R
2017-01-14 14:08:34 Info BURN: Scanned files #8, folder #2 - total size 1497317376 b. (1.39 Gb.)
2017-01-14 14:08:34 Info BURN: Inserted media type : DVD-R
2017-01-14 14:08:34 Info BURN: Write started
2017-01-14 14:08:33 ---- ***************** Encoding end **********************
2017-01-14 14:08:33 Info Disc name: "My DVD"
2017-01-14 14:08:19 Info BURN: Writable disc DVD-R inserted. Ready to write
2017-01-14 14:08:16 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2017-01-14 14:08:16 Info BURN: Drive has Serial ATA physical interface
2017-01-14 14:08:16 Info BURN: New Drive selected : 0:0:0 - hp DVDRW GUB0N UB00 [E] (Scsi)
2017-01-14 14:08:16 Info Burned folder: "C:\Users\John\Documents\ConvertXToDVD\The.Crash.2017.HDRip.XviD.AC3-EVO\", Min. media size 1.39 Gb.
2017-01-14 14:08:16 Info Total size 1427 Mb., Target size DVD5 4300 Mb., Occupation 33.21%
2017-01-14 14:08:16 Info Conversion completed in 00:16:55
2017-01-14 14:08:16 Info Rendering rate: 5.05 x Realtime
2017-01-14 14:08:16 Info DVD duration (incl. menus) 01:25:24 (~ 5124 sec.) - rendering time 00:16:55
2017-01-14 14:08:16 Info Generated duration 5124.80 sec., expected 5117.29 sec.
2017-01-14 14:07:34 Info P-SDT buffer Underflow 1 times, 1552 bytes peak
2017-01-14 14:06:58 Info Chapter #17 start at 80:0.295
2017-01-14 14:06:08 Info Chapter #16 start at 74:59.995
2017-01-14 14:05:11 Info Chapter #15 start at 70:0.196
2017-01-14 14:04:07 Info Chapter #14 start at 65:0.396
2017-01-14 14:03:02 Info Chapter #13 start at 60:0.096
2017-01-14 14:02:01 Info Chapter #12 start at 55:0.297
2017-01-14 14:01:03 Info Chapter #11 start at 49:59.997
2017-01-14 14:00:07 Info Chapter #10 start at 45:0.197
2017-01-14 13:59:12 Info Chapter #9 start at 40:0.398
2017-01-14 13:58:15 Info Chapter #8 start at 35:0.098
2017-01-14 13:57:15 Info Chapter #7 start at 30:0.298
2017-01-14 13:56:14 Info Chapter #6 start at 24:59.998
2017-01-14 13:55:13 Info Chapter #5 start at 20:0.199
2017-01-14 13:54:13 Info Chapter #4 start at 15:0.399
2017-01-14 13:53:14 Info Chapter #3 start at 10:0.099
2017-01-14 13:52:17 Info Chapter #2 start at 5:0.300
2017-01-14 13:51:21 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, 6 channels, 384 kb/s
2017-01-14 13:51:21 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=2-31, 6398 kb/s, pulldown: 23.976 -> 29.97 Fps
2017-01-14 13:51:21 Info Video processing: Pad (Left:0 - Top:60 - Right:0 - Bottom:60)
2017-01-14 13:51:21 Info Video processing: Fast linear (VSO) resampler (720*304)->(720*360)
2017-01-14 13:51:21 Info Chapter sequences require 338.13 Mb. temp space
2017-01-14 13:51:21 ---- ************ Source file #1 END DETAILS ************
2017-01-14 13:51:21 Info AUDIO Stream #2 [RAW COPY]: Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
2017-01-14 13:51:21 Info VIDEO Stream #1 : Video: mpeg4, yuv420p, 720x304 [PAR 1:1 DAR 45:19], 23.98 FPS
2017-01-14 13:51:21 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
2017-01-14 13:51:21 Info Logical file: C:\Users\John\Downloads\torrents\The.Crash.2017.HDRip.XviD.AC3-EVO\The.Crash.2017.HDRip.XviD.AC3-EVO.avi - 1 file(s) 1.38 Gb.
2017-01-14 13:51:21 ---- *********** Source file #1 BEGIN DETAILS ***********
2017-01-14 13:51:21 Info Video bitrate 0/6398/8816 Kbps (min/avg/max)
2017-01-14 13:51:21 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 16:9
2017-01-14 13:51:21 ---- ======================= TITLESET #1 =======================
2017-01-14 13:51:21 Info 2 Stream(s) found - est. duration 01:24:13.294, reference 01:24:13.294
2017-01-14 13:51:21 Info Opening file "C:\Users\John\Downloads\torrents\The.Crash.2017.HDRip.XviD.AC3-EVO\The.Crash.2017.HDRip.XviD.AC3-EVO.avi"
2017-01-14 13:51:21 Info [ ] Multicore support in resize
2017-01-14 13:51:21 Info Project size 4.17 Gb. (235.34 Mb. audio - 3.93 Gb. video)
2017-01-14 13:51:21 Info [ ] Don't fix audio gaps
2017-01-14 13:51:21 Info [ ] Engine Log
2017-01-14 13:51:21 Info [ ] 2-pass encoding
2017-01-14 13:51:21 Info Encoding preset: MP (Medium Projects)
2017-01-14 13:51:21 ---- ****************** Encoding begin *******************
2017-01-14 13:51:21 ---- **************** Menu settings end ******************
2017-01-14 13:51:21 Info [x] Don't create title menu for single video
2017-01-14 13:51:21 Info [x] Return to title menu after titleset playback
2017-01-14 13:51:21 Info [x] Skip root menu initially
2017-01-14 13:51:21 Info [ ] Play titles one after the other
2017-01-14 13:51:21 Info [ ] Loop playback
2017-01-14 13:51:21 Info [ ] Auto-start playback
2017-01-14 13:51:21 Info Menu fit: Text size reduced from 30 to 25 in style "title"
2017-01-14 13:51:21 Info Template: Black Mirror, contains 4 page(s), 15 customizable element(s)
2017-01-14 13:51:21 ---- *************** Menu settings begin *****************
2017-01-14 13:51:21 ---- **************** Burn settings end ******************
2017-01-14 13:51:21 Info Default speed selected: 2.4x
2017-01-14 13:51:21 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2017-01-14 13:51:21 Info BURN: Drive has Serial ATA physical interface
2017-01-14 13:51:21 Info BURN: New Drive selected : 0:0:0 - hp DVDRW GUB0N UB00 [E] (Scsi)
2017-01-14 13:51:21 Info [x] Delete DVD folder after burn complete
2017-01-14 13:51:21 Info [ ] Don't eject disc or open DVD folder in explorer, after burn complete
2017-01-14 13:51:21 Info SAO setting: Automatic
2017-01-14 13:51:21 Info [x] Burn result to DVD / as ISO file in working folder
2017-01-14 13:51:21 ---- **************** Burn settings begin ****************
2017-01-14 13:49:25 Info Folder C:\Users\John\Documents\ConvertXToDVD\Patriots Day 2016 DVDSCR x264 AC3 TiTAN\ has been removed
2017-01-14 13:49:25 Info BURN: WRITE SUCCESS: Disc written
2017-01-14 13:49:25 Info BURN: Finalization Time 00:00:34 - Total completion time 00:07:38
2017-01-14 13:48:50 Info BURN: Write finished in 00:07:03 - Finalization start here. Avg. burn rate 4.69
2017-01-14 13:42:17 Info BURN: Lead-in burning time (mS) 29699
2017-01-14 13:41:47 Info BURN: Write started 1220288 sectors to write
2017-01-14 13:41:47 Info BURN: Init success: DVD-R SAO
2017-01-14 13:41:47 Info BURN: Writing speed requested x8.0, effective x8.0
2017-01-14 13:41:47 Info BURN: Available write speed: 8x ,4x
2017-01-14 13:41:47 Info BURN: Media ID: CMC MAG. AM3
2017-01-14 13:41:47 Info BURN: Media type: DVD-R
2017-01-14 13:41:46 Info BURN: Scanned files #9, folder #2 - total size 2498054144 b. (2.33 Gb.)
2017-01-14 13:41:46 Info BURN: Inserted media type : DVD-R
2017-01-14 13:41:46 Info BURN: Write started
2017-01-14 13:41:45 ---- ***************** Encoding end **********************
Re: Error about halfway every time i try to burn.
Post by JJ » Fri Feb 03, 2017 6:19 am
Your writables are worst quality.
Try using better media.
