Aspect ratio still not working with fixed resol. (BluRay)
mue.mat
Post by mue.mat »
Hello
I've just tried out new version 2.0.0.21. Unfortunately cutting movie from the bottom still doesn't work. The problem still exists if I use a fixed resolution format (Blu-ray...).
When I use mkv container, aspect ratio works fine and keeps original movie resolution.
Please fix the bug with fixed resolution BluRay-format.
Thanks a lot
mue.mat
Re: Aspect ratio still not working with fixed resol. (BluRay
What is your source file format?
mue.mat
Post by mue.mat »
mkv, 1280x546, 24.0, Planar 4:2:0 YUV
mue.mat
mue.mat
Post by mue.mat »
Thank you!
With new version 2.0.0.22 "keep video aspect ratio" setting is now working fine if using fixed resolution output profiles (DVD, Blu-ray, AVCHD...).
Regards, mue.mat
Hello mue.mat,
Thank your for your help on this feature request...
FYI I will change this setting from boolean option to a new video fit method "User (keep aspect ratio)"
