Burning subtitles into video
jeffycu
Post by jeffycu »
I want to burn subtitles into a video file but do not want to re-encode the original format of the video. I have tried adding in the subtitles but I need to re-encode and the output file size is much larger than the original. Is this possible to do?
Jeff
Re: Burning subtitles into video
If you want to burn/merge the subtitle track on video, you MUST reencode it...
Please post your log file to see why the output file is larger than original.
jeffycu
Post by jeffycu »
HI Cedric,
Here is the log contents. As you can see the original size is 1.42Gb but after re-encoding this becomes 8.08Gb. Any advice would be appreciated.
:crash_log='C:\ProgramData\VSO\ConvertXtoVideo Ultimate\2\Log\ConvertXtoVideo Ultimate 2_crashlog_.20160503.194433.437.log'
:library=false
:app_version=2.0.0.11
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
19:49:10.246 Info H264 settings for stream #1: width=1480,height=1080,aspect=1/1,dar=37/27,b_factor=0,codec=h264_cuda,h264_profile=high,h264_level=auto,preset=veryfast,coder=1,me_method=5,flags=+loop+global_header,g=250,me_range=16,bf=2,time_base=1/24,b=9250000,keyint_min=250,bt=18500000,pix_fmt=yuv420p,gpu_id=0,threads=4
19:49:10.233 ------------ +--> [audio #2 - aac audio, 48000Hz, Stereo, 192000 bps, Audio volume: -30.0dB [English]]
+-[audio aac main audio 2 Ch., 48000 Hz, 96 Kbps]
+--> [video #1 - h264_cuda video, 1480x1080, yuv420p, 37x27, 24.00Fps, 9250 Kbps]
¦-[video h264 1480x1080 37:27 yuv420p, 24.00 fps, 1998 Kbps]
+-[subtitle 0:1:0 - srt 720x576]
Output file: C:\Users\Jeff\Documents\ConvertXtoVideo Ultimate\Son.of.Saul.2015.1080p.BRRip.x264.Hungarian.AAC-ETRG\Son.of.Saul.2015.1080p.BRRip.x264.Hungarian.AAC-ETRG.mp4 (MPEG-4)
Input file: E:\Downloads\Son.of.Saul.2015.1080p.BRRip.x264.Hungarian.AAC-ETRG\Son.of.Saul.2015.1080p.BRRip.x264.Hungarian.AAC-ETRG.mp4
Video filters used:
- DeInterlace filter: VSO
- Upscale filter: linear (vso), Downscale filter: linear (vso). Fit method: automatic (Padding: top: 0, bottom: 0, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
19:49:09.837 Group ******************** Son.of.Saul.2015.1080p.BRRip.x264.Hungarian.AAC-ETRG.mp4 (1h:46m:55s) -> Son.of.Saul.2015.1080p.BRRip.x264.Hungarian.AAC-ETRG.mp4 - MPEG-4 ********************|GK_TITLESET|
19:49:09.814 Group MP4 MP4 (H264+AAC)|GK_CONVERT_SESSION|
19:44:49.522 Info Total Physical Memory : 8191 Mb.
Available Physical Memory : 5590 Mb.
Memory Load : 31%
Available Virtual Memory : 3750 Mb.
Total Memory : 16383 Mb.
Available Memory : 13530 Mb.
19:44:49.521 Info Processor Intel(R) Core(TM)2 Quad CPU Q8300 @ 2.50GHz with 4 core(s) CPU
Supported instruction set: MMX,sse,sse2,sse3,ssse3 (slow),sse41
19:44:49.486 Info User OS: Windows 10 Pro, Microsoft Windows 10 (Build 10586)
file name : C:\Program Files (x86)\VSO\ConvertXtoVideo Ultimate\2\vsoVideoConverter.exe
file version : 2.0.0.11
19:44:37.093 Group Burn engine events
19:44:33.439 ------------ ************************vsoVideoConverter.exe:9288 Log session start 2016-05-03 at 19:44:32.844*************************
Hello jeffycu
If you want to reduce the output size, you just need to change the "Target size for single file output".
Enter an output size manually, or reduce the quality factor.
jeffycu
Post by jeffycu »
Thanks Cedric!
