VSO wont open after windows 10 update
tewka
Post by tewka »
I woke up this morning to find VSO Downloader will not open. I checked task manager and did not see any processes running related to VSO. Tried to restart to no avail.
Benjamin
Re: VSO wont open after windows 10 update
Post by Benjamin »
Apparently the last update of Windows is not compatible with Winpcap driver, a Windows issue that should be fixed soon...
Uninstall manually the Winpcap driver then be sure to have the EVE driver installed.
Let us know if it was the problem.
tewka
Post by tewka »
Removed the wincap and still the program does not open, even when run as administrator. I did make sure to have the eve net driver installed. Thanks for the quick reply btw!
drrip
Post by drrip »
Not only the downloader but convertx to video, convert x to hd, dvd converter but convertX to dvd works. Another fine job by windows 10!!
tewka
Post by tewka »
Kinda stinks happening right when vacation kicks in. Hope its a quick fix.
Please take a look there:
vso-downloader-fail-to-start-after-last ... 18976.html
Maybe the last Nvidia driver update came with last Windows 10 update?
tewka
Post by tewka »
Works perfect now thanks guys!
