The encoding engine already has support for CUDA (Nvidia proprietary) but has no support for OpenCL yet (or am I mistaken?).
I can't find it anywhere in the settings.
the DXVA2 support relates to decoding only using a GPU.
http://developer.amd.com/tools-and-sdks ... g-app-sdk/
http://developer.amd.com/resources/hete ... encl-zone/
OpenCL is royalty free and would allow users with AMD graphic cards to use their GPU's to offload some of the encoding.
Feature Request: ATI OpenCL support
Re: Feature Request: ATI OpenCL support
added as an official feature request
http://bugs.vso-software.fr/view.php?id=7603
problem has since been solved in our most recent versions
Hi Claire,
With OpenCL is indicated that the GPU is used but which is not so..
The new structure in the driver of AMD does not support OpenCL anymore.
Here is only VCEEnc 3.05 (latest version) about AMF (AMD Advanced Media Framework) is open source
I write VSO this again and again, why does nobody believe it?
No vendor uses OpenCL for AMD cards because it is simply ineffective.
With OpenCL have a fps of 29, without (CPU) 110 -120 fps.
Maybe look in the direction in the future
Best regards,
Cherryman
EDIT:
With the answer from Claire the support for AMD VCE is to come is my question here done
is not solvedClaire wrote:problem has since been solved in our most recent versions
Best regards,
Cherryman
EDIT:
