ABC (AU) iView failing to download
This weekend I've just starting getting 'Download completed with error' when attempting to record from ABC (AU) iView. Is anyone else experiencing the same problem, or is just me?
Re: ABC (AU) iView failing to download
There has been reports of similar problems with BBC channels, seems that they switched to new type of encoding.
Problem is that VSO needs access to stream to be able to properly solve this, and these channels are country-specific so it takes time to use proxies etc. to get access to those.
Yep, the region locking is bit of pain. I'm not going to be able to help with a proxy, but I can perform a Wireshark capture if that would be of help?
it will be nice to have a wireshark capture
It will be no problem, where is the best place to send it?
in the forum you can add some attachments
Attached wireshark capture (abciView.pcapng) of the first 10 seconds of program http://www.abc.net.au/iview/#/view/80600949. There is quite a bit of chatter around my local network, but hopefully not too hard to identify the program.
- abciView.txt
- Rename from abciView.txt to abciView.pcapng
- (8.77 MiB) Downloaded 411 times
this server uses the HDS protocol but the encryption is not yet supported, maybe in the future...
