Player looses audio sync playing .avi files
rb07
Post by rb07 »
Using the latest available version (1.0.1.422, but reports 1.0.0.422 in 'About') the sound looses synchronization after playing most of an .avi file.
The sync is late by several (4, maybe 5) seconds, but sometimes is shorter. It happens suddenly, not on a file glitch, and late in the video (close to the end actually). Playing the file from the same position doesn't show the problem, i.e. only happens when playing the whole file, and no, I haven't tested playing the same file several times. I also don't know if its specific to a computer (it happened on an Atom based Netbook).
This has happened with at least 2 different .avi files.
Re: Player looses audio sync playing .avi files
Your problem sounds more like computer issue, most likely caused due lack of resources.
If you can't reproduce it then it can't be fixed, specially if it happens only sometimes with some files.
